Electric Touring / On-Road RC
@minami: thanks to the novice race/fresh blood that have come into the scene.... at mukhang mga adik sila tulad nina berkin, breyton and crew! hahahaha kaya sali ka rin dapat para masaya!
hehehe!
we'll be in JP this coming Thursday. Join us guys!
sirs,
pwede ba un body ng HPI or tamiya sa xray t3? http://www.hpiracing.com/hpibodies/
basta 190mm touring body ba ito?
won't change anything na since na tono mo na sya ng husto!
@robo just reading the thread, adik nga sila. ) hahaha will join the race on sat.
sirs,
tip sa set up: check mo pa rin every now and then ang setting ng auto. kasi just by merely running the car, things like camber, toe-in, droop, etc can change. mas lalo na kung mejo nabangga or crash. tapos yun na mention ko sayo na i-loosen mo ang top deck rin and lay it on a set up board for a few minutes nakaka tutlong to relax the chassis/upperdeck plates. then with the battery installed, put the car on your droop blocks under the front and rear bulkheads and the tighten the upper decks screws again. this usually helps solve most tweak problems a car may have.
eto settings na nilagay ko sa auto mo:
Ride Height: 5 front, 5.5 rear
Droop: 5 front, 4 rear
Camber: 1.5 front and rear
Pag nasanay ka na diyan ang you feel you can driver the car with a bit more aggressive, try adjusting your droop to 6 front and 5 rear para maging mas responsive ang kotse. Then you can play around with shock positions and spring rates. tanong tanong ka lang kung kelangan mo ng tulong. kita kits sa sabado!
@minami: mejo adik lang naman sila hahahaha ... sige bro, sabado kita tayo!
@robo - thanks! i'll try to remember that hehehe. Hopefully, di ko ulit mabaliktad yung arms
@berkin: hahaha ayos lang yan bro ... kahit si ralph nangyari na sa kanya yan. kakalito kasi yung reversible arms ng 417. kaya niya alam na dapat i-check yun, kasi speaking from experience yun! hahaha it happens to the best of 'em! by the way, ano handle ni ike dito sa rctech? Nag text pala siya sakin about my mini if it's for sale ... apparently i did not get to respond. thing is nabura ko na yung text and did not get to save his number. wow mali!
stormtrooper = ike = ...
@voodoo: thanks men!
@stormtrooper: paging ike! .... paging ike! bro, i can bring the mo5 to the track on saturday so you can have a look at it first had and see if it's something you'd be interested in .... that's if lalaro ka sa sabado at di ka lilipad kung saan saan hehehe .... text mo nalang rin ako ulit so i can store your number.
@stormtrooper: yan na! may chase down na tayong nakikita! hehehe exciting 'to! may target na si ike! hehehe .... regarding sa mo5, ok na pala you're all set. ok yan, at least may pang laban ka na na auto. at maganda pa excuse mo na pag gastosan yung "kit ng anak mo" hahahaha
@viralvariance: yes sir! any 190mm touring car body will fit a 1/10th scale electric touring car. wag lang yung 200mm kasi masyado malaki ... pang nitro yun. TC bodies are 4-door sedan bodies and HPI has a number of stuff there sa site nila. Pero mas maigi sir ang Protoform bodies like the LTCR or Speed 6 kasi maganda talaga sa handling. As you'll see, majority of the top international racers use these in just about any racing surface. Just something to think about.
@roborat: hahaha, yup i heard nga from voodoo na nangyari kay ralph yon.
HAHAHA! malas lang talaga si Stormtrooper, pag may big race...lumilipad. Pag kompleto kaming lahat..."nasisiraan"...that's why....na lang tawag namin sa kanya hahahhahaha!
Rains, Rob, Rodil and Migui - wag nyo na tuksuhin si Ike na sa B-main lang sya ha...let's support him!
@stormtrooper: don't worry, i'm sure this saturday champion ka na.
