Go Back  R/C Tech Forums > International Forums > Manila Racers
Electric Touring / On-Road RC >
Like Tree1Likes
Old 04-09-2012, 03:09 AM
  #30196
Tubalin's Avatar
Default help nmn po
gud day mga sir tulong naman po, last month i bought Ezrun 35A bl combo.when I test it, after a 3-4mins run nawala throtle tas after a minute umandar ulit i used turnigy 5000mAh medyo mainit po.ano kya po problema bkit ganun.salamat po in advance
Tubalin is offline
Old 04-11-2012, 06:20 PM
  #30197
FelixC's Avatar
Default lucena trip
boys up ko lang ulit just incase some racers still wanna join.
guys unfortunatelly due to late confirmation we have to move our summer outing on april 14 and 15. Instead our new outing date will be move to may 5 and 6 correction sat and sunday hehehe sorry. currenly i reserve 6 rooms. please register i can add more rooms if more peple will come. the more the merryier.
rooms
1) ralph l
2) stephen
3) AXO
4) VooDooPH +2
5) Gerome
6) Edward + 2
7)
this is the place your going to.
http://graceland.com.ph/
FelixC is offline
Old 04-11-2012, 07:09 PM
  #30198
cocojam's Avatar
Trader Rating: 47 (100%+)
Good day. Im not quite familiar with the EZrun but do check your gear meshing (baka tight) and your FDR (it might be too low) which could lead to an overheating of your ESC. It can also be that your battery's capacity (the C rating) is not high enough to supply the amp draw of your esc/motor combo thus leading to no throttle response till the battery is able to regenerate enough amps again. Just my two cents worth.
cocojam is offline
Old 04-12-2012, 09:02 PM
  #30199
Para sa mga hackers, enjoy!
+ YouTube Video
rccartips is offline
Old 04-13-2012, 06:49 AM
  #30200
Akina Racer's Avatar
[QUOTE=FelixC;10590530]boys up ko lang ulit just incase some racers still wanna join.
rooms
1) ralph l
2) stephen
3) AXO
4) VooDooPH +2
5) Gerome
6) Edward + 2
7) Rolly, Anton + 2
http://graceland.com.ph/[/QUOTE
Tara na!!!
Akina Racer is offline
Old 04-17-2012, 03:10 AM
  #30201
ROBORAT's Avatar
ANNOUNCEMENT:
NO CLUB RACE THIS SATURDAY, APR. 21, 2012.
However, stay tuned for upcoming race announcements soon, including the 2012 Summer Shootout!
ROBORAT is offline
Old 04-17-2012, 09:35 PM
  #30202
rking's Avatar
gusto ko sumama kaso di ko alam kung pwede.
rking is offline
Old 04-18-2012, 12:54 AM
  #30203
step's Avatar
@ wes, Sabi ni tim ano ba raw talaga difference ng 417 and 417x? Ano ba raw time mo nung sunday and ano raw time niya? (Whats my name? sabi ni tim and kim) hahahahaha........
step is offline
Old 04-18-2012, 08:38 AM
  #30204
Looks like I missed out on the fun last week
jonp is offline
Old 04-18-2012, 08:12 PM
  #30205
Faster than 1/8 nitro on this track. Wow. 1/10 pan (14.4sec) vs 1/8 nitro (15.4sec).
+ YouTube Video
"This PRO10 cars (235mm) are powered by brushless motors (3.5T-4.5T star or 6/7T delta) and lipo batteries with 7.4V and 4800 - 6000 mAh. The tires mostly used are GRP foam tires (F: Purple, R: Magenta)".
Old 04-19-2012, 01:39 AM
  #30206
ROBORAT's Avatar
Here it comes! The HOTTEST race this summer!
THE 2012 RIDE RACING SUMMER SHOOTOUT!
June 2 & 3, 2012 --> SAVE THE DATES!!!
GENERAL RULES & GUIDELINES
RACE FEES:
P1,600 per entry. This includes 1 Set of Ride Racing Pre-Mounted Tires
P1,000 for additional set of pre-mounted tires purchased during the race weekend.
(note only two sets of tires maximum per class/entry)
We will advise when the Ride Racing Pre-Mounted Tires will be available but inital word is that these will be in by end of this month at Lil's Hobby Center. This should give ample time for the racers to test the tires within the month of May prior to the big day! Please await announcements and details on this.
SUPER STOCK CLASS:
Chassis: Any Brand 1/10th scale, 4wd Touring Car Chassis Only
Motor: Any Brand, 13.5 Brushless
ESC: Open - with (or without) Boost
Batteries: LiPo 2S, 6 Cell NiMh/NiCd Only
Weight: 1,400 grams (with transponder)
Body: Any 4-door touring car/sedan body, 190mm only. Roof/Wing Height and Wing Cord will be measured (Body Jig will be made available)
Tires: Hand Out Ride Racing Pre-Mounted Tires
OPEN MODIFIED CLASS:
Motor: Any Brand, Modified Brushless Motor (only 9.5 turns and blow Sensored Motors are allowed)
ESC: Open
ADDITIONAL RULES:
1) Only the prescribed Ride Racing Pre-Mounted Tires will be allowed for this race. Each Racer is only allowed to run a maximum of two sets of tires for the entire race event -- from the first round of qualifying to the finals. Tires of each participant will need to be submitted to the race director/officials on race day prior to race start for proper tagging/marking.
2) These tires can only be purchased on race day at the track venue. A specified time slot will be allotted prior to start of the race for tire purchase, tagging and registration (so be early at the track).
3) Bodies must conform to the roof, wing specifications with the use of the on-site body jig at the track (same as MTCC).
4) Bodies, Tires and Weight will be inspected before each round of racing. Any violation will disqualify a racer from running that round.
NEW FORMAT RACE FORMAT:
1) 5 Rounds of Qualifying – After each round, racers will be ranked and assigned points corresponding to their overall finish within their respective classes (1st=0 Pts, 2nd=2 Pts, 3rd=3 Pts, etc..). Points from the best 3 rounds will be counted (drop 2 runs) and added up. This will then be used to seed the mains using the lowest aggregate/total scores result as basis.
2) Triple Mains/Finals – Best two to runs to count, scores of these rounds will be added up (1st Place = 1pt, 2nd Place = 2pts, and so on …) and lowest point total will be used to determine the winners of each class.
RACE SCHEDULES:
DAY 1: JUNE 2, 2011 – Saturday
9am – Track Opens
9am – 12:30pm – Open Practice, Registration Starts, Tire Issuance, Tagging/Marking
12:30pm – Registration and Tire Tagging/Marking Ends
12:30pm - Group/Heat Sorting and Posting
2pm – Tracked Closed/End of Open Practice
2:30pm – Start of Qualifying. 4 Rounds to be run on Day 1.
DAY 2: JUNE 3, 2011 – Sunday
9am – Track Opens
9am – 12:30pm – Open Practice, Registration, Tire Tagging/Marking (only for Racers who did not register on Saturday)
2:30pm – Start of Qualifying. Final Round of Qualifying** and Finals.
OTHER GUIDELINES & INFO:
1) TRACK LAYOUT: A new layout will be used for the 2012 RIDE RACING SUMMER SHOOTOUT. This layout will be made available ONLY on FRIDAY, JUNE 1st, starting 1pm in the afternoon.
2) PRACTICE TIME: Open Practice will be from 1pm to 10:30pm ONLY on June 1. At 10:30pm, the track will be closed and practice runs will no longer be allowed. Next opportunity to practice will be during Open Practice Time on Saturday and Sunday as posted above. Others who have the luxury of playing on weekdays or any other day will not have the advantage of added track time with the new layout.
4) TURN MARSHALLING: Just like all our big races, we will be requiring turn marshalling for this race! Looking forward to your cooperation as always.
5) ROUGH/UNSPORTSMAN LIKE DRIVING will not be tolerated. Penalties will be applied.
WHAT'S UP FOR GRABS???
1.) The 2012 RIDE SUMMER SHOOTOUT Title and becoming Manila's next Touring Car "Hot Shot".
2.) Trophies for all A-Main Finishers of the Open Modified and Super Stock Classes.
3.) Trophies for the B-Main Champions and Medals for 2nd and 3rd Place B-Main Finishers.
4.) Trophy for C-Main Champion
That’s it for now but stayed tuned for updates!
So, what are you waiting for, get your gear ready, head to JP Raceway for some set up and practice time, and spread the word!!!
IT'S RACE TIME AGAIN!!!
ROBORAT is offline
Old 04-19-2012, 06:38 AM
  #30207
step's Avatar
Yahoo summer shootout na
step is offline
Old 04-19-2012, 07:15 AM
  #30208
FelixC's Avatar
yahoo summer shootout na! practice na todo mga boys masaya nanaman ito. but before the big race. relax muna tayo, summer trip muna. may 5 and 6 saturday and sunday. meetup @ shell slt 7am. so far were 8 family. yun wala kasama pwede ko din provide. just let me know it advance
there are two bed configuration ONE QUEEN SIZE BED and 2 SINGLE BED PWEDE TAYO MAG EXTRA BED. 2500 FOR EACH ROOM.
PLEASE INDICATE WHAT BED CONFIGURATION YOU PREFER SO I CAN HAVE IT PREPARE
1) ralph l
2) stephen
3) AXO
4) VooDooPH +2
5) Gerome
6) Edward + 2
7) Rolly, Anton + 2
8)FELIX chua--2 signle bed
FelixC is offline
Old 04-19-2012, 05:18 PM
  #30209
Default no novice class
dalawang class lang walang novice/silver can class? why
vintage boy is offline
Old 04-20-2012, 02:23 AM
  #30210
alecladanga's Avatar
count me in sa summer shoot out! sana may hobbywing v3 na available dito by that time!
alecladanga is offline
