Go Back  R/C Tech Forums > International Forums > Manila Racers
Electric Touring / On-Road RC >
Like Tree1Likes
Old 08-12-2004, 09:40 AM
  #2956
Balugz's Avatar
Trader Rating: 16 (100%+)
Lem2,
I'm very delighted to inform u na ako na ang magiging bagong owner ng ultra limited edition M01 ni BLP. Of course I have to sacrifice my X3 in return. So far di pa naman sumisikip dibdib ko sa deal na yan. hehehe
Balugz is offline
Old 08-12-2004, 09:44 AM
  #2957
Balugz's Avatar
Originally posted by marvi
lem2: naunahan mo ko dun sa KO micro servo ni tarsier good to go na yung 1/12 ko, napaandar ko na sa bahay kanina. had to break a couple of 6-cell packs para makabuo ng 3 sets na 4-cell. kaso, mukhang di na ako tatapos ng 8 minutes kasi mahina na yung mga packs ko maski sa 1/10 stock. bahala na sa sat. hope it doesnt rain, gusto ko na magtest nito. rockwell pa to huli umandar re. evo3 parts via rainbowten, pass muna ako, ang mahal ng gearboxes aabutin ako ng 4-5k yata for a pair (front/rear) mas mahal pa sa rc ko
Meron naman Evo 4 nagtitiyaga ka diyan sa Evo 3. I know meron na 415 to replace my 414 but everytime na bibili ako panay walang stock.
Balugz is offline
Old 08-12-2004, 09:55 AM
  #2958
Trader Rating: 82 (100%+)
mahal ng evo4 21k yata. nakita ko yung box, may kasamang rims/tires/inserts, front 1-way (mukhang pareho ng sa evo3 but iba ang part no.), similar looking arms (sa 414 and evo3), 3pc shaft (similar to TC3, pro4, CGM/SD) and aluminum bulkheads. ganda ng bulkheads, split horizontally kaya pwede i-access ang diff from the top mukhang di na to magsisira ng 1way kasi naka "floating" shaft na.
kung 21k to, magkano kaya yung surikarn di bale, intay lang tayo ng ilang months, may 2nd hand na nyan
marvi is offline
Old 08-12-2004, 10:12 AM
  #2959
Balugz's Avatar
Bossing iba na yung suspension arms ng Evo 4. Same goes to the upright and c hub. Pwede pala silip sa box without even buying one.
BLP: Bossing ganito ba kaganda Abarth mo?
Attached Thumbnails Electric Touring / On-Road RC-abarth1.jpg
Balugz is offline
Old 08-12-2004, 03:53 PM
  #2960
miniracer's Avatar
Originally posted by Balugz
Lem2,
di sisikip dibdib mo dyan, yung X3 anytime may mabibibli yang tech limited MO1 maghanap ka wala ka mabibili. igawa mo na ng magandang display case.
miniracer is offline
Old 08-12-2004, 05:35 PM
  #2961
babytoy101's Avatar
ruf: baket walang pasok kagabi??
balugz: pre anong nangyari....... kala ko ba ikaw na kukuha ng only tek racin chassis kit ni blp?! ayun napunta 2loy kay lem!
marvi: evo4 drive train gaya lang yan sa baracuda, tsaka ang mahal na pala evo4..........matibay kaya?
mini: msta na!
babytoy101 is offline
Old 08-12-2004, 06:41 PM
  #2962
joelt's Avatar
BBTOY - Si BALUGZ nga ang kukuha nung ni kit, nde si LEM2. . . . Mukhang sumusobra na ata ser ang kakapanood mo ng cut scenes para nde maging Rated X yang mga ine-edit mo, ha?
BALUGZ - Yep, ganun ka detailed nga yung motor. The exhaust manifold and valve cover in the picture seems to have been chrome finished though. Nde ganun yung sa stock. I painted my exhaust white, as recommended in the manual. As for parts, I don't have D or C parts for the M chassis since nde naman ako nakaranas ng sira ng parts ng tamiya sa tibay. Yung mga sobrang parts na kasama ser ay yung mga tinanggal na original parts na pinalitan ng tech racing components. For the charger naman, paki sama sir yung original alligator clips for the power source since I use this to hook up to my power supply.
BLP
joelt is offline
Old 08-12-2004, 07:07 PM
  #2963
balugz: iba na pala yung arms looks very much like the old one, but with additional holes for the shocks and extra ribbing. akala ko, yung 415, evo4, 414, and evo3 have interchangeable suspension. yung c-hub, iba na nga, wala na yata yung butas for the optional torque rod.
ang lakas ng ulan kaninang umaga dito sa min, tapos umaaraw naman ngayon. sana naman wag ganito bukas. pag umulan ba sa umaga, madali ba matuyo yung capitolyo track kapag umaraw sa bandang tanghali? what time ka pupunta bukas? text kita bukas ng umaga para sa weather check ha?
babytoy: matibay siguro, pero pag may bumigay, mighty bond lang katapat nun kita ko sig mo, may barracuda ka na pala crush ko yung kotse na yan. sayang nga yung binebenta ni madda na R1, nag 1-day sale siya, kaso naunahan naman ako ni kennethM
marvi is offline
Old 08-12-2004, 07:18 PM
  #2964
kupz's Avatar
Default Re: UMARAW NA RIN SA WAKAS!!!!!
Originally posted by Baguhan Lang Po
KUPZ/TATALOPE/HMAN/FBJ/MANGPIT - How was last night's run? Hope same conditions are in store for Saturday!!!
KUPZ - Musta Mi-2???
MOTO - Kitakits sa Sat. Labas mo na yang TC
mo!!!
BBTOY - Confirmed yun. Binebenta ko lang ng 4.5k yung CGM ko kay ROUGH. . . . . . . . 4.5k yung first give!
ITIM/KURIPS/LEM2/TAGA - Laro tayo Sat!!!!
BLP
ok naman siya, medyo lang masyado pa mabait. D ko pa ma set up kasi gabi. I wanna set it up this sat., if it doesn't rain of course, dapat race conditions, tanghali natin malalaman kung papalo! you've tried it naman , di ba? on your point of view, how was it? problema lang may corners na talaga ma feel mo front diff. Will try it with the one way soon.
kupz is offline
Old 08-12-2004, 07:46 PM
  #2965
joelt's Avatar
KUPZ - Kitakits tayo bukas then. Andun ako, rain or shine. As for the Mi2, same feedback essentially. Gusto ko syang ma-feel kapag naka one-way na, para malaman kung paku pa rin. Kung paku sya, time to leave my beloved Black Special at home for display purposes na lang, para magkaroon ng bagong pakner ang paborit kong CGM. . . . . . Kasalanan mo yan eh, kinumbinse mo kasi ako na magsanay ng naka one-way. Ayan, parang bitin tuloy sa akin ngayon ang handling ng car kung ala.
BLP
joelt is offline
Old 08-12-2004, 09:18 PM
  #2966
lem2's Avatar
Default Balugz
pass muna ako sa batts, mahal din aabutin. Pre sobrang sulit yan kit na yan---- just don't scratch it. Madami mga collectors item yan si BLP may ta03 na daid jun pa yan, TBevo na new in box and he has a kitthat is signed by someone.
BLP: hay naku-- mukhang malaki ang balak sa pagkuha ng MI2 ahhhhhh? hindi ko na kaya sumaby dyan to much for me!
MARVI: mas type ko pa din ang evo3 or 415 because it shares "75percent of its components with the tao4-R"(as quoted sa June issue na RCXtreme yun ha) so anytime may available na parts! Hmmmm dunno it I will junk my O4 or get a 415!! heheheheh ang nagagawa talaga ng u;lan--- maglinis ng kit, bumili ng kit and so on!! Kahit walang pambili-----
Yes actually di ko sana kukunin yun servo, I found out that my Futaba 9601 is busted so no choice!! Si missis ang nagbayad kaya okay lang!
KUPZ: sana tuloy tuloy na yun pagbalik mo sa RC
Pass ako this Saturday-- September pa ako. Hope the weather cooperates with all of you!
Silver_Spoon:
Peace and Happy Racing!
lem2 is offline
Old 08-12-2004, 10:12 PM
  #2967
Balugz's Avatar
Miniracer: Good point, yan din nga binubulong ko sa sarili ko eh.
BBtoy: Ako na ang magiging new owner nung kit. See u on saturday.
Lem2: Mahal talaga coz 260 pala hindi 360. Siguro kung sweswertehin, F103 na ang katabi ng M01 ko.
BLP: Don't worry doon sa charger, I'll include everything.
Marvi: Kaya nga naglabas ng suspension conversion kit for 415. Pwede mo rin bilhin yung conversion kit para sa Evo 3 mo para atleast Evo 3.5 na sya.
Balugz is offline
Old 08-12-2004, 10:19 PM
  #2968
joelt's Avatar
BALUGZ - For tomorrow nga pala, medyo discreet tayo sa pagkuha mo nung M01, ha. Kasama ko kasi si BLP Jr. eh. Huwag natin ipahalata yung transaction natin.
LEM2 - Esep-esep pa lang yung sir. Have to see the final outcome pa.
BLP
joelt is offline
Old 08-12-2004, 10:25 PM
  #2969
Balugz's Avatar
BLP
Hahaha!
Balugz is offline
Old 08-12-2004, 11:49 PM
  #2970
S-T-R-l-K-E-R's Avatar
Default new GTX
checkout what i have found on the other forums!!! looks nice!!!
File Type: bmp
S-T-R-l-K-E-R is offline
