Go Back  R/C Tech Forums > International Forums > Manila Racers
Electric Touring / On-Road RC >
Like Tree1Likes
Old 07-13-2011, 04:21 AM
  #29311
VooDooPH's Avatar
Trader Rating: 18 (100%+)
open to side bets na to?
VooDooPH is offline
Old 07-13-2011, 05:44 AM
  #29312
Mark Flores's Avatar
Trader Rating: 28 (100%+)
Ano odds?
Mark Flores is offline
Old 07-13-2011, 06:11 AM
  #29313
Default pls help
mga sir,
ask ko lang po if pwede po yung futaba 2pl 2.4ghz, tower pro 9g and teu-101bk?
kasi po ung servo ko lakas ng glitch pag connect ko dito pero pag iba ang esc ok naman po.... pls help
tnx rc tech
carribean is offline
Old 07-13-2011, 07:53 AM
  #29314
Bwahaha!!!
now the question is.... WHO'S THE REAL FATHER!?
blankster is offline
Old 07-13-2011, 08:31 AM
  #29315
Originally Posted by blankster
Bwahaha!!!
Nobody knows except Wes said that he's going to shout "Who's yo Dadeh!!??"
to Step when he wins daw.
JPRacing is offline
Old 07-13-2011, 11:32 AM
  #29316
doen08's Avatar
Trader Rating: 38 (100%+)
Originally Posted by carribean
mga sir,
tnx rc tech
Boss wala kasing bec yung teu101. Kung ilang volts yung batt mo, yun din ang ibibigay nyang volts sa receiver and servo.
Ngayon baka di kaya ng receiver mo above 6v, kaya sya nagloloko. Check mo specs ng rx mo kung kaya nya above 6 volts. Pero ang alam ko pwede ang teu sa r603gf na rx.
Diba pang airplane yan servo mo? Try mo rin muna palitan ng servo. Baka di kaya ng servo yung voltage.
doen08 is offline
Old 07-13-2011, 08:25 PM
  #29317
Nako Wes...
Dapat talaga magka alaman na!
Old 07-13-2011, 10:03 PM
  #29318
ROBORAT's Avatar
Nasa Prospec Cup Update!!!
As of July 14, 2011
For the Super Stock Class (13.5)
!!!TIRE UPDATE!!! >>> Due to issues with customs, the availability of the proposed control tires has been delayed. As such, given that its only a few weeks away to test, THERE WILL NO LONGER BE A CONTROL TIRE RULE! SO IT'S OPEN TIRES!!! ... any 24mm rubber tires, rims and inserts will be allowed!
Class champion (regardless of chassis entry) will receive a SMC LiPo Pack c/o Pitshop!!!
Reminder to be early for the said race since it's a 1-day event. Take note that the following race schedule will be followed in order to manage the time.
*Note: scheds can be subject to change depending on actual number of entries per class.
TIME TO HIT THE TRACK!!! SET UP TIME NA!
ROBORAT is offline
Old 07-14-2011, 05:06 PM
  #29319
Voodoo, para sa iyo.
rccartips is offline
Old 07-17-2011, 11:30 PM
  #29320
cocojam's Avatar
Trader Rating: 47 (100%+)
@JP: Thanks so much Primo for helping us out with the suspension and tire set-up of Manito's TC6. If he had no classes today, we would have stayed much longer after seeing the difference during his last run last night. I couldnt wipe the grin off his face till this morning
Cheers!!!
cocojam is offline
Old 07-17-2011, 11:57 PM
  #29321
Cheers!!!
Manito + TC6 = VERY FAAAAASSSSSTTTT
Thanks also Sir JP for the setup!!!
Old 07-18-2011, 12:38 AM
  #29322
Cheers!!!
Nako! Si Boss Jp na nag set-up kay Manito...Nasa-Cup racers...look out for the fast guy behind you...might be manito...sneaky
jonp is offline
Old 07-18-2011, 12:40 AM
  #29323
Malapit na yan sumigaw...LAPPING! hehe
jonp is offline
Old 07-18-2011, 05:02 AM
  #29324
babytoy101's Avatar
Default BL motor temp
mga kapatid ano ideal BL motor temp kapag naka turbo raat boost?
gumawa kasi ako ng onboard temp probe... just need your suggestion for fine tunning my esc and motor set-up.
grabe kasi init eh. Sharing my onboard digital temperature probe.
pics.
babytoy101 is offline
Old 07-18-2011, 07:34 AM
  #29325
VooDooPH's Avatar
160-170degF seems to be the sweetspot for most motors
VooDooPH is offline
