Go Back  R/C Tech Forums > International Forums > Manila Racers
Electric Touring / On-Road RC >
Like Tree1Likes
Old 06-24-2011, 12:29 AM
  #29161
Originally Posted by ROBORAT
@mon: doen is right, sundays are always open for practice runs. actually, the track is open Tuesdays through Sundays, from 10am to 10pm. Hanapin niyo lang si Ramil ang pay the appropriate track fee and you can play to your heats content. ... rain or shine!
What's the approximate fee if I may ask?
PowerPee is offline
Old 06-24-2011, 01:41 AM
  #29162
VooDooPH's Avatar
Trader Rating: 18 (100%+)
P300 whole day kung walang race
Track fee varies if there are races though
VooDooPH is offline
Old 06-24-2011, 02:21 AM
  #29163
mon
Guide naman papunta JP if I'm coming from Robinson Galleria thanks in advance.
mon is offline
Old 06-24-2011, 06:43 AM
  #29164
Thanks VooDoo... By the way we're former Tamiya Manila teammates
PowerPee is offline
Old 06-25-2011, 03:21 AM
  #29165
+ YouTube Video
rccartips is offline
Old 06-25-2011, 03:39 AM
  #29166
doen08's Avatar
Trader Rating: 38 (100%+)
nice vid. ano gamit nila radial tires?
doen08 is offline
Old 06-26-2011, 12:31 AM
  #29167
CobraSVT's Avatar
Question lang po. Ano ang effect ng soft or medium tire insert sa 36r na slicks? Di kasi ako familiar sa tamang tire inserts.
We usually race on a dusty parking lot track with minimal traction and 43 to 45 deg temps.
TIA.
CobraSVT is offline
Old 06-26-2011, 01:04 AM
  #29168
alecladanga's Avatar
another piece for on-road enthusiasts and racers! shock rebound tool :-)
source: www.redrc.net
alecladanga is offline
Old 06-26-2011, 03:37 AM
  #29169
mon
Had a grand time at JP this morning mukhang mapapadalas ako dito thanks Ramil for the assistance.
mon is offline
Old 06-27-2011, 02:16 AM
  #29170
ROBORAT's Avatar
TIA.
@cobra: generally a softer insert generates more traction but heres always a trade off - it will heat up ur tires faster which ironically as you heat up your tires you will loose traction naman. Also, since there is more tire flex, it will wear your tires faster as well. Moe friction also means at a certain point you sacrifice corner speed. Stiffer generally does the opposite. So, choosing the right insert you need to consider track temps and how your tire performs through an entire race heat. Generally for the best of both worlds, we typically use medium insert.
ROBORAT is offline
Old 06-27-2011, 02:17 AM
  #29171
ROBORAT's Avatar
@mon: thats so good to hear sir! Sarap talaga mag rc!
ROBORAT is offline
Old 06-27-2011, 04:59 AM
  #29172
mon
Im using a 61T spur and a 28 pinion would the performance of my kit improve if I use a 55T spur and 25 pinion ?
mon is offline
Old 06-27-2011, 05:20 AM
  #29173
Plumber's Avatar
Smile
What chassis are u using/running with sir?
Plumber is offline
Old 06-27-2011, 05:22 AM
  #29174
mon
TT01 sir using a stock 540 motor
mon is offline
Old 06-27-2011, 05:41 AM
  #29175
CobraSVT's Avatar
Thanks sa info. Subukan ko yung SWEEP 40R with Med insert. Actually first time ko gagamit ng slicks sa TC5 ko. We usually use rally tires or radial tires sa parking lot racing namin dito sa KSA.
Salamats uli...
CobraSVT is offline
