Go Back  R/C Tech Forums > International Forums > Manila Racers
Electric Touring / On-Road RC >
Like Tree1Likes
Old 08-01-2004, 07:57 PM
  #2626
ROBORAT's Avatar
tatalope: no prob pare! practis lang yan. just be patient at makukuha mo rin. regarding tires, i would not suggest na mag foam tires ka sa practice runs mo. kasi ang layo ng handling nya from rubber. pag dating sa race, maninibago ka pag gumamait ka na ng sorex. the best is to practice with the same gear that you will use when you race. otherwise medjo useless ang practice mo.
pitshop: ako kahit ano. basta annouonce nyo lang in advance para ma-block off ng racers ang schedule nila.
lem: as mentioned, im game for anything. ok din pag gabi or late afternoon mag umpisa para di masyado mainit. but mornign is fine. if i do run in saturday though, i dont think i'll run on sunday for the offroad race. one day lang per weekend ako. nami-miss ko pamilya ko pag two days ko di nakikita eh. tsaka djahe din sa kanila.
BLP: kung ginawa bang umaga makakalaro ka?
ROBORAT is offline
Old 08-01-2004, 08:05 PM
  #2627
rough512's Avatar
Originally posted by Baguhan Lang Po
ROBO - Buti ka pa at pde ka ng Aug 7. This coming weekend is surely a NOT POSSIBLE scenarion for me. . . . . . Kaya ipagdadasal ko na lang na umulan sana.
BLP
Sir, Bakit?
Nakausap nyo na pala si Tatalope, sya yung sinasabi kong web developer heheheh...
rough512 is offline
Old 08-01-2004, 08:09 PM
  #2628
tatalope's Avatar
PITSHOP: un binigay mo sakin gray un color eh d ko kabisado un but according to kurips by the feel of it hard daw.. un s knya red, soft daw... pero pareho kmi ng part ng tires n napupudpod agad.. anyway i'll just check it out once i drop by ur shop
MINIRACER: txt ako syo kgbi d k sagot suplado ka! isip ksi ko ng alternative n tires n makakatipid pg naglalaro tyo ng "flying stock" lng tulad nyn imbes n mgamit ko p s isang race un gulong ayun ubos na nsanay ako s offroad matagal maubos gulong.. un foam kc kht malapit n s rims pwede p din panglaro pg naubos pwede n din pang drift hehe ... un tires ko total of 2 races lng ubos agad! syet! d ko yata afford un 1k+ every 2 saturdays of practice lng pero pg race ok lng
ROUGH: more on the front-end ako ng web dev.. malayo s skills mo hehe... bkt d kyo tumakbo last sat??
haaay mukhang d tlga uubra ang pgtitipid s hobby n to.. kelangan mgtpid s ibang bagay para mkbili ng gulong!!
tatalope is offline
Old 08-01-2004, 08:32 PM
  #2629
Tommi Makkinen's Avatar
Trader Rating: 28 (89%+)
Originally posted by badboy
will this be TCS legal?
Possibly. but most likely this will be restricted to GT-1 Class
Tommi Makkinen is offline
Old 08-01-2004, 09:11 PM
  #2630
joelt's Avatar
TLOPE and MRACER - Ganyan ganyan din kami dati, tapos alaskahan pagdating sa RC Tech about it. . . . . Kaya nakikita nyo pa rin ngayon kung papaano apihin yung aming chairman na si ITIM at treasurer na si KURIPS. . . . . . Wait til you guys actually race together tapos ganyan din ang resulta hehehehe.
The important thing is you have fun and that you improve as time goes by. Yan din essentially ang turo sa amin ng mga beterano sa mga mata namin nuon na sila ROBO, KUPZ, MANGPIT, etc. . . . . Yyyeeepppp, masmatanda pa sa amin yung mga yun. Kung kami yung mga OLDIES, sila naman yung mga ANCIENTS.
ROBO - Baka maspwede ako if it were held in the late afternoon or PM. Activity here in the office starts Friday night kasi eh.
ROUGH - Tama na muna yung ikaw yung natrau-traumatize ko. Tsaka na si TLOPE kapag gradwyet ka na.
BLP
joelt is offline
Old 08-01-2004, 10:47 PM
  #2631
Balugz's Avatar
Trader Rating: 16 (100%+)
Pare kung ubos kaagad sorex mo after 2 races lang, I don't think it will make any difference kung may makita ka mas heavy duty na slick tires. Siguro marami na yung 3 races kung sakali. I'm sure meron tips si Rough on how to minimize tire wear.
So far tatlong gulong nagamit ko sa mga past races/practice runs.
Sorex 32, Tamiya Type B, and Sorex 36(2nd hand). Limited run palang yung Type B and Sorex 36 kaya no idea kung mga ilan race kakayanin ng mga ito. Yung Sorex 32 naka 2 1/2 sa race and 1 practice run na. Mukhang pwede pa siya 2 to 3 race day on december.
Balugz is offline
Old 08-01-2004, 10:51 PM
  #2632
lem2's Avatar
Default TATALOPE
try using WD-40 on the tires 10 minutes before each run.
It sort of prevents undue wear on them, plus its also a good traction compound---- Not that you need traction compound at capitol. It works ry it!
lem2 is offline
Old 08-01-2004, 11:13 PM
  #2633
joelt's Avatar
TLOPE - As shared with you, one thing you can do is rotate your tires after every run. Malakas talaga ang wear ng right front, because of the direction the cars run and the layout. If you don't rotate, chances are that the tire on the right front of your car will wear more prematurely than the others. Next would be the right rear. In my case, I use about 1 set every month (4 weekends at about 6 to 8 packs per weekend).
You can expect the life of your onroad tire to be considerably shorter than offroad tires though.
BLP
joelt is offline
Old 08-02-2004, 12:15 AM
  #2634
rough512's Avatar
aba't loko ito a... anong ibig mong sabihin???
Tatalope : These are some tips to minimize tire wear.
1. Fly baby, Fly!!! the more time your car spends off the ground, the less wear on the tire...
2. Go slow especially around the corners This way you will minimize the cornering wear and tear. Go fast only on the straights. Using a johnson/mabuchi silver can motor will help you accomplish this.
3. as much as possible, keep your kit parked at the pit table. If you must drive, go to the driver's stand and ask the peson driving to let you test-drive his car.
rough512 is offline
Old 08-02-2004, 12:39 AM
  #2635
Default Duel? anybody up to it?
Hello friends. After almost one year of practicing with my super fast auldey tins, I have moved up the scale to 1/10. I got new 1/10 scale auldey 4wd shaft car (will post pics soon). I am pretty sure this can break the lap record in your track! I will be in your track this Saturday and you guys can aprroach me anytime and I can give you tips on how to make your cars fast. I am sure you will shift to the auldey brand when you try my car. See you guys at the track. By the way, my name is Al.
Auldey Boy is offline
Old 08-02-2004, 01:59 AM
  #2636
rking's Avatar
Auldey Boy: you speak with so much confidence, you must be really fassssttttttt
rking is offline
Old 08-02-2004, 02:14 AM
  #2637
tatalope's Avatar
Talking
guys tnx s mga tips lalong-lalo n kay rough! malaking tulong yan mga tips mo!
tlga palang magastos s gulong onroad
tatalope is offline
Old 08-02-2004, 02:47 AM
  #2638
joelt's Avatar
AULDEY BOY - Thanks. I'll definitely take you up on your offer on giving me tips on how to make my Yokomo CGM go faster, in order for me to possibly catch up with your Auldey.
. . . . Hope the tracks you were referring to was Capitol Speedway. Current lap record there is 12.8 secs. I'm normally there by 830am.
BLP
joelt is offline
Old 08-02-2004, 03:19 AM
  #2639
XTREMERCHOBBIES's Avatar
Arrow BRITISH ENGINEERING
The Schumacher MI2 box says it all. "The Unfair Advantage" and "The Most Advanced Touring Car... Ever?" Schumacher has thrown down the gauntlet to it's competitors before you even open the box.
Get the "UNFAIR ADVANTAGE" soon... only at XTREME RC HOBBIES!!!
to read more just click on the link below:
http://www.racing-cars.com/products....er=47127<br />
XTREMERCHOBBIES is offline
Old 08-02-2004, 03:28 AM
  #2640
lem2's Avatar
Default Re: Duel? anybody up to it?
Where did you buy your audley? Post pictures already really intrigued by it. did you have to assemble it? did it have a body? (painted or not)
Hope to see you on Saturday! BLP will welcome you!
lem2 is offline
