Go Back  R/C Tech Forums > International Forums > Manila Racers
Electric Touring / On-Road RC >
Like Tree1Likes
Old 11-25-2009, 03:39 PM
  #25396
neil4wd's Avatar
Trader Rating: 20 (100%+)
FUTABA CUP 2009 - EP RACE
Date: December 5, 2009
Open Practice and Registration: 8:00am to 11:00am
Race Time: 11:00am - 6:00pm
Registration: 600 pesos
Additional Entry: 200 pesos
Categories:
- Mini Class
- Open Stock 23T/13.5 Class
- Open Silver Can Class
General Regulations:
Mini Class
1. The allowable chassis for this class are: M-03 (Including M-03R), M-04 and M-05.
2. Tamiya and After-Market Hop-Ups are allowed. However, the main gear, counter gears and pinion should be Tamiya.
3. Any Tamiya or After-Market mini body is allowed.
4. Any 6-cell NiCd and NiMh, Lipo or Tamiya LiFe allowed.
5. Any brand "mini" rubber tire allowed.
6. Only Legal Tamiya Sport Tuned Motor can be used.
7. Cars must meet a minimum weight of 1200 Grams with transponder.
8. Open gearing.
Open Stock 23T/13.5
1. Any 4WD EP chassis.
2. Any 23T Brushed, 13.5T Brushless and Tamiya 12T Brushless motors allowed.
3. Any 24mm rubber tires with 24mm wheels allowed
5. 190mm 4-door touring sedan and Tamiya gt/sedan/rally/sports bodies only.
6. Cars must meet a minimum weight of 1420 Grams with transponder.
Silver Can Class
2. Only 2 vents legal Tamiya Silver Can motor allowed.
6. Cars must meet a minimum weight of 1500 Grams with transponder.
Race Regulations:
Mini, Open Stock 23T/13.5 & Silver Can
Qualifying Heats - 3 rounds 5 minutes per heat
Qualifying Regulations - The pole position will be awarded to the driver with the best run (e.g. most no. of laps and with the fastest time)
A-Main Finals - 3 rounds 5 minutes per heat
B-Main Finals - 2 rounds 5 minutes per heat
Finals Heats Regulations:
- The best two results from the 3 heats will be used to calculate [accumulated points] and crowned champion
- Points are awarded according to position: 1st=1 point, 2nd= 2 points, 3rd= 3 points and so on.
- In the case of two or more drivers having equal point totals, the driver with the most no. of laps will be the winner
- If a draw still results, the driver with the best total time from the best two results will be the winner
- If a draw still results, the drive with the 3rd best result will be used to determine the winner
Trophies
A-main - 1st-3rd placers of all classes and 1st place winner in the B-main class
neil4wd is offline
Old 11-25-2009, 04:03 PM
  #25397
mitsubishi's Avatar
bdc : ei, magdala ka ng coleman para me pa take home ka ng black gulaman...
mitsubishi is offline
Old 11-25-2009, 04:36 PM
  #25398
ROBORAT's Avatar
mikey: you can do it like randy pike demonstrated but the thing is yung gaps sa soldering posts ng RX8 are much wider than those in the RS PrOTEC hehe ... to use his term, you'll probably have to "mash" the wires a bit flatter to make the slot. ako personally di ko na sinuot sa slot. i filled the slots with soldering lead tapos nakapatong nalang yung pagka solder ko ng wires sa ibabaw ng posts. just use a good hot solder like the newstar 100w iron voodoo and the others mentioned. yan din gamit ko. painitin mo lang ng husto yung iron and it will be plenty hot to do the gob. remember, wag ibabad yung solder ng matagal sa soldering posts coz it will heat up the esc and mess up the board/circuitry/fets inside. kung hirap na hirap ka gawin, try dropping by action hobbies and have jerome help you out. he does good clean solder jobs as well but for a fee. pero sigurado ka naman sa gawa niya kung di ka pa confident masyado sa pag solder ng RS mo. hope this helps ....
nu-b: more than welcome kayo sir. punta lang sa track sa sabado bago mag 2pm para maka register. yung RR allowed yan sa super stock class. yung sa batts, kagaya ng sinabi ni tantalus, check mo nalang kung abot ng 5 mins na run. see you sa track sir!
tanta: t3 na! hehehe .... it's easy to drive!!! di ba kupz?? pero seryoso, mukhang malupit ang auto na yan.
rcmanila: fight pa rin sa sabado .... bye bye na nga lang sa duo. bad trip talaga pero think of it this way, ikaw na actually pinaka swerte sa motor na yan. ako nga di umabot ng isang race day naghingalo na im sure may mahihiraman ka diyan pards. tapos order nalang tayo. wachutink?
jay: hardworking ah! ok yan .... sabado pahinga naman at rc na!
kupz: it's easy to drive! wag kang gamowl!!!! solid yun kagabi pare. naiyak ako katatawa!
DALAWANG TULOG NALANG!!! SHABU-SHABU NA!!! WOOOOPEEEEE!!!
ROBORAT is offline
Old 11-25-2009, 04:51 PM
  #25399
ROBORAT's Avatar
rccartips: thanks for confirming
rnold: thanks for affirming
hehe hope to see you guys also this saturday if you're free. should be a good warm up for the futaba cup so everyone can get their car's ready. baka maka-chamba pa tayo ng shabu-shabu! heheeh
mitsubishi: magandang suggestion yan. pwede coleman na cooler dalhin ko? hahaha
ROBORAT is offline
Old 11-25-2009, 05:26 PM
  #25400
bam_cruz's Avatar
mga sirs ask ko lang if may naka sched na club race this sunday sa jP?
bam_cruz is offline
Old 11-25-2009, 05:52 PM
  #25401
RCManila's Avatar
Trader Rating: 19 (100%+)
Hanap hanap muna ng motor.
Anyone have a spare 13.5?
Order na!! Kanino ba tayo mag order? Kay Mr. Lee, Mr. Chan, Mr. Stormer or kay Tower Power? You choose we buy!
I don't think there's a club race on Sunday.
RCManila is offline
Old 11-25-2009, 06:49 PM
  #25402
tantalus007's Avatar
Trader Rating: 17 (100%+)
gusto mo hiramin yung team powers na 13.5... malakas pa siguro anghit powers nun... POTEC!!!
robo: yeah baby!!! yeah!!!
tantalus007 is offline
Old 11-25-2009, 06:52 PM
  #25403
Big Daddy Cool's Avatar
Trader Rating: 15 (100%+)
Robo/Mitsu: Heto ang coleman na dadalhin ko..... itim din..... just kidding.
Big Daddy Cool is offline
Old 11-25-2009, 08:47 PM
  #25404
bigz's Avatar
Naku! Hindi aamin yang batang yan...
Dalawang soldering iron? hehehe... Next time mag solder ka kapatid pa sampol naman Honestly, hindi pa ako nakakakita nyan...
nampo, totoo nga. sampol naman sa sabado, para d na apat na kamay pwede naman ata series yung dulo ng soldering iron para mainit.
bigz is offline
Old 11-25-2009, 09:04 PM
  #25405
bigz's Avatar
Originally Posted by Rnold
guys, sorry for the late reply. 1420g will be the weight limit for the open stock. thanks for your suggestions!
thanks sir.
bigz is offline
Old 11-25-2009, 10:14 PM
  #25406
ROBORAT's Avatar
pwede siguro i-tie strap ang tigalawang iron para dobol barrel ang dating! ay, pero matutunaw! .... CA nalang! wahahahaha HOT STUFF BABY! .... YEAH!!!
RCManila: kaw pare, kahit san! by the way, ano nga pala part number ng tamiya shims para sa steering rack? kelangan ko nun para sa BD5 ko!
tanta: meron ka nga bang austin powers na motor? paki dala para kay mits!
ROBORAT is offline
Old 11-26-2009, 02:17 AM
  #25407
RCManila's Avatar
53585 That's the part number you're looking for
Pwede ba ako gumamit ng limited edition na austin powers na motor or designed yun para sa isang tao lang?
RCManila is offline
Old 11-26-2009, 02:42 AM
  #25408
keisuke's Avatar
Originally Posted by A X O
Totoo yon. Walang biro, Yan Ang tech tips. Tonong nyo pa sa Tatay-tatayan ng Anak ng hapon.Hahaha
WAT DA PAK IS THIS!!!
DALAWANG TULOG NA LANG. MAKAKALARO NA RIN HAHA
keisuke is offline
Old 11-26-2009, 03:04 AM
  #25409
Eto daw raffle sa futaba cup.
rccartips is offline
Old 11-26-2009, 08:38 AM
  #25410
kupz's Avatar
Robo: Solid ba ang "Wag kang Gamol"? yang ang HIT ni Andrew E!!
RCManila: easier to drive + easier to drive + easier to drive = T3 na! kasi nakaka Times 3 na motor na nasunog mo with your current kit..Php 5K na lang..wag mo na ipukpok baka bumaba pa lalo presyo!!!! Basta ako solid TC5..do i have a choice? we'll see on Saturday kung ok ang TC5 with the current layout..di ko pa na try eh.
Tantalus: Vroooom Vrooomm
Keisuke: Shabu Shabu! Kitaro ! Yoshinoya!
Jay: race ka na staurday..i have a special shirt for you..
kupz is offline
