Go Back  R/C Tech Forums > International Forums > Manila Racers
Electric Touring / On-Road RC >
Like Tree1Likes
Old 11-24-2009, 09:49 PM
  #25381
mitch, ang ganda ng T3. definitely better looking than the 416. balik xray kana? hehe
rccartips is offline
Old 11-24-2009, 10:03 PM
  #25382
robo sabi ni rnold 1420.
Old 11-24-2009, 10:06 PM
  #25383
VooDooPH's Avatar
Trader Rating: 18 (100%+)
Originally Posted by CobraSVT
Whoa!!! 100 watts. Maka hanap nga. Masubukan din yung flat tip.
Thanks RCManila..!!
BTW. Goot pala ang tatak nung gamit kong soldering Iron.
Newstar 100W ang gamit ng marami (Green handle). make sure the tip is clean when soldering (wipe with a slightly damp piece of cloth or sponge). For connecting to pieces (i.e. wire and deans connector), i find its easier when i pre-tin both pieces before soldering them together.
VooDooPH is offline
Old 11-24-2009, 10:12 PM
  #25384
rough512's Avatar
mas mura sa landmark hardware section kesa sa SM, ace, and tru value Yung newstar 100 watts.
for soldering lead, electroloy brand works fine for me.
rough512 is offline
Old 11-24-2009, 10:20 PM
  #25385
RCManila's Avatar
Trader Rating: 19 (100%+)
Thanks RCManila..!!
Very Goot yan soldering iron mo sir. Like what VooDooPH says, pre tin both ends before soldering them both would be best. Clean tip makes your soldering job a master piece
Originally Posted by A X O
gamit kayo ng dalawang soldering irons, sabay nyo gamitin para mabilis madikit yung wires at para maiwasan uminit yung board. kakailanganin nyo nga lang ng apat na kamay.
Kapatid! Mukhang naka istraw ka nanaman ah!
Asim ng itsura eh noh?!
Tsk! Wala na tayo budget para mag new kit. Hanggang tingin na lang.
RCManila is offline
Old 11-24-2009, 10:24 PM
  #25386
RCManila's Avatar
Ayus yan!!!
Yung layout ba is yung current layout or meron bagong layout na ilalatag?
Gulo ba? Puro layout yung nasabi ko
Edit: I would suggest using the current layout, its really good for stock racing.
Suggestion lang naman po
RCManila is offline
Old 11-24-2009, 11:25 PM
  #25387
Originally Posted by ROBORAT
HERE WE GO GUYS!!!
Get your touring cars ready, we're going SPEC RACING @ JP RACEWAY!!!
[B]
Siyempre yung sa A-Main mas sosi ang meal set, pero ok pa rin yung sa B-Main
A-Main Podium
1st Place - Angus Beef Set (gusto ko 'to!!! hehehe)
2nd Place - Seafood and Beef Set
3rd Place - Beef Set
B-Main Podium
1st to 3rd Place - Fat Beef Set
And take note, no added cost for race fees! Still the usual P350 club race fee will apply.
Race format/rules:
Qualifying: 3 five minute qualifying runs, best run counts (not best lap)
Finals: Triple Mains - Best Two Count. In case of tie, best run determines winner.
Chassis/Kit: Any Brand 4wd Electric Touring Car.
Weight Limit: 1420grams with transponder (race ready)
Motor: 13.5 BL .... 23T brushed motors also allowed
Body: Any brand, 4 door 190mm Touring Car/Sedan
Tires/Inserts/Rims: Any Brand
Batteries: LiPo and NiMh allowed
So spread the word, and see you all this Saturday at JP RACEWAY!
Race starts at 2pm!
This should also be a good warm up for upcoming races like the Futaba Cup and for those heading to BKK for the HPI Challenge.
MAY KARRERA NA, MAY CHIBUGAN PA!!! ... kung manalo! hehe
Hi mga boss!
just wanted to ask if open pa po ung race this coming Saturday. I would like to join kaso wala akong kilala sa inyo. baguhan lang ako eh
also wanted to ask if my motor is qualified. im running tt01 on type RR na motor so im not sure if pasok siya.. and ung batt ko is run off the mill lang na 1600mah+cheap charger. pwede na kaya to?
thanks.
nu-b is offline
Old 11-25-2009, 04:55 AM
  #25388
tantalus007's Avatar
Trader Rating: 17 (100%+)
Originally Posted by nu-b
Hi mga boss!
thanks.
yes, youre very much welcome to join the race this coming saturday, the more the merrier!!!
and another yes, qualified yang motor mo to join the race, 23t yang type RR ng tamiya...
regarding yung battery not sure kung kayang makatapos nian for a 5 minute heat... try mo na lang before the race mag practice runs para malaman... next in line in your shopping list is a decent charger for lipo packs...
see you this coming sat...
tantalus007 is offline
Old 11-25-2009, 04:58 AM
  #25389
OTSO-OTSO!!!
OTSO-OTSO!!!
WILD!!! wild talaga sa asim... nakakaluha!!! WILD!!!
Old 11-25-2009, 06:09 AM
  #25390
bigz's Avatar
nde yata naka istraw. seryoso ata eh. d nag react.
bigz is offline
Old 11-25-2009, 06:19 AM
  #25391
A X O's Avatar
Trader Rating: 51 (100%+)
Totoo yon. Walang biro, Yan Ang tech tips. Tonong nyo pa sa Tatay-tatayan ng Anak ng hapon.Hahaha
A X O is offline
Old 11-25-2009, 08:13 AM
  #25392
RCManila's Avatar
Nakakaluha ba? T3 na!!! WoooHooo!!!
RCManila is offline
Old 11-25-2009, 08:16 AM
  #25393
RCManila's Avatar
Naku! Hindi aamin yang batang yan...
Dalawang soldering iron? hehehe... Next time mag solder ka kapatid pa sampol naman Honestly, hindi pa ako nakakakita nyan...
RCManila is offline
Old 11-25-2009, 02:51 PM
  #25394
Trader Rating: 32 (100%+)
Originally Posted by bigz
boss rnold, pwede ba adapt nalang natin yung club race rules sa weight ng kit using lipo? 1420 ata kami eh. para la na hassle mag dikit pa ulit ng weights.
Rnold: you may want to consider lowering the weight limit already for the 13.5 class to 1420grams. we've already started to do this for the club races starting last week and will do so again this saturday in keeping with the move internationally to accommodate LiPo better. this helps improve car balance, logevity of electronics and tires. just somthing you may want to consider.
for silver can, maybe 1500grams is fine as i assume there are more tub chassis kits there which are naturally heavier and may be more of a challenge to bring down in terms of weight.
just my 0.02 cents...
Originally Posted by jonp
Rnold: Is the new weight limit of 1420grams approved for the Futaba Cup? I hope so, kase many of us adjusted our kits already...and since this is the new international standard...sana ok na sir.
rnold: ay offical confrmation on the requested 1420g weight limit for open stock? would be good if you could give feedback so the racers can prepare this weekend since there is a race which many will be attending also to get ready for the Futaba Cup ... (and the shabu shabu of course!)
guys, sorry for the late reply. 1420g will be the weight limit for the open stock. thanks for your suggestions!
Rnold is offline
Old 11-25-2009, 03:35 PM
  #25395
neil4wd's Avatar
Trader Rating: 20 (100%+)
Kinda heavy for GULAMAN?
Or is that the number of those round things in the GULAMAN per scoop?
neil4wd is offline
