Go Back  R/C Tech Forums > International Forums > Manila Racers
Electric Touring / On-Road RC >
Like Tree1Likes
Old 08-18-2009, 03:16 PM
  #24796
Tommi Makkinen's Avatar
Trader Rating: 28 (89%+)
Originally Posted by Rnold
the weight limit for those who will be using the normal transponder is originally at 1500g for the gt class.
with the addition of optional use of personal transponda, they changed the weight limit to 1530g instead wether you are using a normal or personal.
so, same same
ah... so desuka
domo arigato, Rnold-San
Tommi Makkinen is offline
Old 08-18-2009, 05:40 PM
  #24797
neil4wd's Avatar
Trader Rating: 20 (100%+)
rnold/oldskul...I have a "phone-in" question from one of our viewers (si papa Edward). Is the FDR for Super Stock a "minimum" ie you can gear higher or is it a "fixed" FDR? Based on some of the TAC stories I heard from the other guys it's the former.
The term used in the R&R is "limited", to my mind that also implies it's a "minimum" setting.
Gracis.
neil4wd is offline
Old 08-18-2009, 05:53 PM
  #24798
neil4wd's Avatar
Oh crap...I just realized now. With the TB03 relegated to "out-of-box" parts I gotta find me a set of stock CVA dampers. I sold off the TB03's set.
neil4wd is offline
Old 08-18-2009, 09:59 PM
  #24799
bigz's Avatar
Originally Posted by A X O
mga dung, ang gogolo nyu naman, basta mag kitakits tayu sa sabadu at bahala na magkapisti-pisti ang mga pisting Is Ar Bi (SRB)
SWAK tu sa sabadu kaya kailangan poti ang kaha para mukhang kyubul.
naku, kyubul. anu ba kolay na wala sa bilyar? pakolay ako ng iba. hahahaha!!!
bigz is offline
Old 08-18-2009, 10:30 PM
  #24800
Trader Rating: 32 (100%+)
Rnold is offline
Old 08-18-2009, 10:32 PM
  #24801
kirizutochan's Avatar
Neil: I believe you can't change the FDR anymore. Last year is a different story because they did not impose a spec gearing for the stock class. If it says use a 22T pinion then you are limited to that only or you can try using a 21 and risk being DQ'd. Maybe they will allow you to go 1 tooth down, maybe not but definitely not BIGGER. And when they say "OUT OF THE BOX" it literally means out of the box. So using the option springs like blue, red, white is most likely NOT ALLOWED.
PS: I think the 22T pinion is the one included in the box hehe and you CAN'T use the high torque servo saver either!
kirizutochan is offline
Old 08-19-2009, 12:23 AM
  #24802
A X O's Avatar
Trader Rating: 51 (100%+)
hahaha. natawa ako dun ah.
A X O is offline
Old 08-19-2009, 01:35 AM
  #24803
so apprarently they want to encourage the use of TT-01 in super stock class while strangling the inherent advantages of the TB-03...
does the TB-03 really have that much of an advantage?
Old 08-19-2009, 07:00 AM
  #24804
neil4wd's Avatar
kiri...if that's the case then I really am wondering what kind of a layout their gonna use that'll "equalize" the 3 cars.
neil4wd is offline
Old 08-19-2009, 07:55 AM
  #24805
bmmer701's Avatar
Trader Rating: 17 (100%+)
hehehe malalaman natin kung ano layout yan hehehe
bmmer701 is offline
Old 08-19-2009, 12:15 PM
  #24806
oldskul's Avatar
the long-awaited results from Rounds 8. sorry about the delay guys, life gets in the way.
Results of Round 7
Stock Touring Class
1st Place – Neil Severino
2nd Place – Jomil Dela Cruz
3rd Place - Alfonso Ramos
Formula 1 Class
1st Place – Joel Mangilit
2nd Place – Edward Angtuaco
3rd Place - Raymund Aguilar
4WD GT Class
1st Place – Anton Ramos
2nd Place – Tutoy Aldaba
3rd Place – Christian Saplala
4th Place – Arnold Dalusung
5th Place – Norman Cruz
6th Place – Gian Sibayan
Open Stock 23 Class
1st Place – Josh Castro
3rd Place – Anton Ramos
4th Place - Gian Sibayan
5th Place – Hirano
6th Place – Arnold Dalusung
7th Place - Norman Cruz
Results of Round 8
Formula 1 Class
2nd Place – Raymund Aguilar
3rd Place - Neil Severino
4th Place - Edward Angtuaco
5th Place - Jason Dela Cruz
6th Place - Allan Colico
4WD GT Class
1st Place – Tutoy Aldaba
2nd Place – Norman Cruz
4th Place – Christian Saplala
5th Place – Arnold Dalusung
6th Place – Jomil Dela Cruz
Open Stock 23 Class
1st Place – Alfonso Ramos
2nd Place – Anton Ramos
3rd Place – Mitch Sy
4th Place - Tutoy Aldaba
5th Place – Edward Angtuaco
6th Place – Jason Dela Cruz
The series overall results will be posted soon.
oldskul is offline
Old 08-19-2009, 09:03 PM
  #24807
Akina Racer's Avatar
Originally Posted by oldskul
the long-awaited results from Rounds 7 and 8. sorry about the delay guys, life gets in the way.
Results of Round 7
Stock Touring Class
3rd Place – Jason Dela Cruz
Formula 1 Class
3rd Place - Max Park
4WD GT Class
3rd Place – Norman Cruz
5th Place – Gian Sibayan
6th Place – Max Park
Open Stock 23 Class
2nd Place – Gian Sibayan
3rd Place – Alfonso Ramos
Oldskul: Correction... this seem to be the results of round 6, not round 7.
Akina Racer is offline
Old 08-20-2009, 01:02 AM
  #24808
shrewd's Avatar
penk pare! unlis mag snuukir ka..
shrewd is offline
Old 08-20-2009, 01:10 AM
  #24809
tantalus007's Avatar
akin na yung penk... bawal gaya-gaya... plurisint grin or yilu na lang kau!!!
jisi: musta kuskus piga... tanggal na ang lupa???
tantalus007 is offline
Old 08-20-2009, 01:34 AM
  #24810
ROBORAT's Avatar
siyeeeet! penk!
teka, konting patalastas, sino naka orion na 13.5? gearing niyo rin ba 3.8 to 4.0?
tanta: meron ka nang super-dee-duper pinon para sa sabado? kelangan malakihan sa 13.5 .... para kang naka dual ispur niyan!
ROBORAT is offline
