Go Back  R/C Tech Forums > International Forums > Manila Racers
Electric Touring / On-Road RC >
Like Tree1Likes
Old 05-02-2009, 02:44 AM
  #23941
Originally Posted by pitshop
COOOOOOOOOOOOOOOMING UP!
Next week ba?
JPRacing is offline
Old 05-02-2009, 03:22 AM
  #23942
Originally Posted by neil4wd
cheech...yep I go to JP.
No referrals or membership required, just a passion for RC. They open at 10am and stay open as long as there are racers on track. Tues to Sun. Closed on Mondays.
Track fees only apply to racers that use the track and it's good for the entire day even if you step out for a bite to eat. Drinks are available onsite but you will have to bring lunch or order delivery from any of the surrounding fastfood shops. Guests and family members are very much welcome...and if they get hooked to the hobby, so much the better.
Just drop on by and look for Ramil and he'll take care of you.
I think ROBORAT is organizing a practice-race for May 1. You're very welcome to join in or even just drop by and get to know the guys if you have time. Just keep checking this thread for details.
HTH
master, san nga po pala tong jp race track? sorry mag uumpisa palang po at naghahanap palang mapapag practisan..
lui11 is offline
Old 05-02-2009, 04:36 AM
  #23943
Bago mag kanto ng C5 at Ortigas ave patungong Eastwood. Huwag kang sumampa sa over pass papuntang Eastwood. Sa kanan ka lang at makikita mo yung asul na gate pagkatapos ng construction site sa kanan mo.
JPRacing is offline
Old 05-03-2009, 01:36 AM
  #23944
noted sir.
lui11 is offline
Old 05-03-2009, 01:53 AM
  #23945
ROBORAT's Avatar
thanks! kelan dating niyan? 2 for me please and since associated ang order mo sir, paki sabay na rin 'to ....
at ito ....
ROBORAT is offline
Old 05-03-2009, 02:52 AM
  #23946
keisuke's Avatar
Ok news update hahahahaha.....
mukhang sa RCS ang TAC natin ah.... pero hindi pa daw sure... under negotiation pa... hahhahahah.
Alf, sabi sakin nung isa kong nakilala binubuksan daw nlia motor heheheh...
keisuke is offline
Old 05-03-2009, 03:28 AM
  #23947
lhengevolution4's Avatar
Default Tanong lang po mga sir
Sir, a good day to all! Ask ko lang if open pa ang TIR? And if...saan ang location nito? Thanks RCTech guys!
lhengevolution4 is offline
Old 05-03-2009, 07:17 AM
  #23948
alecladanga's Avatar
THANK YOU!!!!
alecladanga is offline
Old 05-03-2009, 08:22 AM
  #23949
bmmer701's Avatar
Trader Rating: 17 (100%+)
so di na carpet? ayos toh hahaha
bmmer701 is offline
Old 05-03-2009, 10:04 AM
  #23950
keisuke's Avatar
Could still be carpet daw. Still under discussion. Problem with carpet is the rain since RCS is outdoors.
keisuke is offline
Old 05-03-2009, 10:32 AM
  #23951
Xanavi_R34's Avatar
Sir Rnold, hindi po ba pwede gamitin ung BL Unit ng Tamiya sa Open 23t Stock which in fact it is equivalent to a 23t brushed motor.
Xanavi_R34 is offline
Old 05-03-2009, 11:07 AM
  #23952
pitshop's Avatar
Trader Rating: 56 (98%+)
NEW SHIPMENT FROM MUCH MORE RACING
POWER MASTER WORLDS EDITION
POWER MASTER MINI
DIFF MASTER
TIRE MASTER (warmers)
FANS
TRACTION COMPOUND
HIGH CAPACITY IGNITERS
CONNECTORS/ADAPTERS
DISH WHEELS
TIRE INSERTS!!!
AND LOTS LOTS MORE
CHECK EM OUT AT THE SHOP!!
pitshop is offline
Old 05-03-2009, 03:47 PM
  #23953
Tommi Makkinen's Avatar
Trader Rating: 28 (89%+)
not really... while meron sila outdoor na tarmac track, kaya nila i-convert yung isang indoor pit area nila to be an indoor tarmac or carpet track. kasi yung TAC sa Thailand nung 2001 and 2003 was held at an indoor track that RCS setup before.
nung 1999 kasi na-rain out kami kaya yung 3rd final heats di natapos...
Tommi Makkinen is offline
Old 05-03-2009, 07:52 PM
  #23954
VooDooPH's Avatar
Trader Rating: 18 (100%+)
i think a couple of the guys are using the Tamiya BL unit already for the open 23T races in TAC.
VooDooPH is offline
Old 05-03-2009, 11:02 PM
  #23955
ROBORAT's Avatar
pitshop: if i may suggest, rather than the Reedy 5000s, yung 4900s nalang! eto oh ....
http://www.redrc.net/2009/01/reedy-3...-lipo-battery/
the Reedy 4900s, still pack the same C-rating (35C) and only sacrifices 100Mah of capacity. 4900s should be more than enough to run even with the hottest mod motors anyway as we run Orion 4800s up to almost 9mins with a 4.0 motor.
and consideration kasi dito is the height of the battery hard case. here's a comparisson of the Reedy 5000, Reedy 4900 and Orion 4800:
Reedy 5000 - height: 25mm (http://www.rcplanet.com/ProductDetai...Show=TechSpecs)
Reedy 4900 - height: 23.2mm (http://67.199.85.166/main/productdet...&category=NULL)
Orion 4800 - height: 23mm (http://www.horizonhobby.com/Products...rodID=ORI14000)
given today's touring car's have differnent bulkhead and upper deck heights, the bigger 25mm Reedy 5000s may have trouble in terms of fitment. On the TC5R particularly there should be no problem on clearance but other cars like the xray 008 may have issues. so you may want to consider specifying the Reedy 4900s EFRA/BRCA packs instead as it will give the same perfromance of the 5000s with a better spec case. just somthing you may want to consider.
ROBORAT is offline
