Electric Touring / On-Road RC
hehe thanks na lang pero ayaw ko maglinis eh hehehe
Round 1 - APRIL 18, 2009
Race fee: 600 pesos first entry, 150 pesos succeeding entries
*NOTE: this is to cover for the maintenance of the motors which includes replacement of the brushes every after 2 race events
Qualifying - starts at 2pm (race track opens at 10:00am)
Race Director - Allan Colico/Yuichiro Takaya
1.) gt tuned hand-out motors cost php 1,100.00 each (inclusive of motor maintenance and brush replacements every after 2 race events)
2.) not allowed: comm drops, inox, water dipping, magnet zapping, etc. (pls use only break-in process of motor run-in)
3.) stop-and-go penalty to be implemented for rough driving
Originally posted by rnold....
The TAC Philippines Qualifying Championship 2009 - General Rules & Regulations, Race Procedures, Overview of Competing Classes and Official Motors
GENERAL RULES & REGULATIONS
Stock Touring Class (Rev.1 Feb-02-2009)
1. Tub Chassis kits only. Carbon plate double deck cars are not permitted in this class.
2. The allowable chassis for this class are: TT-01, TT-01R, TB-02, TB-02R, TB-03, TA-05, TA-05R and TA-05 IFS.
3. Any Tamiya Hop-Up is allowed as long as it is used as it was intended.
4. Only the *HANDOUT RC GT-Tuned Motor 25T (Item #53779) can be used.
5. Only CPR01 included in XB2 and TEU-101BK (#45029) are permitted to be used in this class.
6. All Tamiya gt/sedan/rally/sports bodies are allowed.
7. Only Tamiya 1/10 Medium Narrow Racing Slicks #51049 and Tamiya 1/10 Medium Narrow Racing Radial Tires #51023 can be used. (Should use foam insert included only!)
8. Wheels: Tamiya 24mm Wheels only.
9. Only the Tamiya 1600SP stick type battery can be used.
10. Clearance under main chassis parts must exceed 5mm before the race.
11. Cars must meet a minimum weight of 1450 Grams with transponder.
12. FDR will be implemented
GT Class (Rev.1 Feb-02-2009)
1. Only Tamiya 4WD Chassis can be used. The allowable chassis for this class are: TB-02, TB-02R, TB-03 TBEvo3, TBEvo4, TBEvo5, TA-05, TA-05R, TA-05 IFS, TA-05MS, TRF415 and TRF416.
2. Any Tamiya Hop-Up is allowed as long as it is used as it was intended.
3. Only the *HANDOUT RC GT-Tuned Motor 25T (Item #53779) can be used.
4. Any brand of ESC can be used.
5. All Tamiya gt/sedan/rally/sports bodies are allowed.
6. Only Tamiya 1/10 Medium Narrow Racing Slicks #51049 and Tamiya 1/10 Medium Narrow Racing Radial Tires #51023 can be used. (Should use foam insert included only!)
7. Wheels: Tamiya 24mm Wheels only.
8. Only the Tamiya 1600SP stick type battery can be used.
9. Clearance under main chassis parts must exceed 5mm before the race.
10. Cars must meet a minimum weight of 1500 Grams with transponder.
11. FDR will be implemented
F1/Lemans Class (Rev.1 Feb-02-2009)
1. F103 Tamiya Formula One chassis only (F103, F103RS, F103RM, F103RX and F103LM).
2. Any Tamiya and After-Market Hop-Ups are allowed.
5. Any Tamiya or After-Market F1/Lemans body is allowed.
6. Only Tamiya foam or rubber F1 tire may be used.
7. Tamiya F1 wheels only.
8. 6-Cell NiMH/NiCD and Lipo batteries allowed.
9. Cars must meet a minimum weight of 1000 Grams with transponder.
Open Stock 23T Class (Rev.1 Feb-02-2009)
1. Any 4WD EP chassis.
2. Only Tamiya 23T motors shown below are permitted to be used in this class:
Super Stock Type-R Motor ( #53476 ), Super Stock Type-S Motor (#49247), Super Stock Type-T Motor ( #53477 ), Super Stock Type-RR (#49260), Super Stock Type-RR/Gun Metal (#49288), Super Stock Type TZ ( #53696 ) Super Stock Type RZ ( #53697 ) Super Stock Type BZ (#53930)
3. Any brand of 24mm Rubber Tires and Tire Inserts allowed.
4. Any brand of 24mm Wheels allowed.
5. 6-Cell NiMH/NiCD and Lipo batteries allowed.
6. 190mm 4-door touring sedan and Tamiya gt/sedan/rally/sports bodies only.
7. Cars must meet a minimum weight of 1500 Grams with transponder.
“Mini” Chassis Class (Rev.1 Feb-17-2009)
1. The allowable chassis for this class are: M-03 (Including M-03R) and M-04.
2. Tamiya and After-Market Hop-Ups are allowed. However, the main gear, counter gears and pinion should be Tamiya.
3. Any Tamiya or After-Market mini body is allowed.
4. 6-Cell NiMH/NiCD and Lipo batteries allowed.
5. Only the RS-540 Sports Tuned Motor (Item #53068) can be used.
6. Clearance under main chassis parts must exceed 3mm before the race.
7. Cars must meet a minimum weight of 1200 Grams with transponder.
8. Up to 20T pinion gear (16T, 18T, 20T) can be used for M03 chassis. Up to 19T pinion gear (17T, 19T) can be used for M04 chassis, but in case of using 26D tire, only 17T pinion can be allowed.
Race Procedures
Qualifying races will be held in the following order
1) Stock Touring Class
2) GT Class
3) F1/Lemans Class
4) Open Stock 23T
5) Mini Class
Qualifying Regulations
Each class will have a 5-minute qualifying run with the no. of laps and time recorded.
Only the best run from the 2 heats will be used to determine standing for Finals.
The pole position will be awarded to the driver with the most no. of laps and fastest time.
Qualifying Race Starting Procedure
Each competitor starts from the designated area behind the start/finish line. Starting position will change for the 2nd qualifying heat based on the results of the 1st qualifying heat.
* Please follow the race organizers’ instructions regarding your vehicle grid position.
Finals Heats Regulations
Each Class: The top finisher in a race of 5 minutes.
・ Point system will be implemented in determining the winner.
・ The best two results from the 3 heats will be used to calculate [accumulated points] and determine the champion.
・ (Points are awarded according to position: 1st=0 points, 2nd= 2 points, 3rd= 3 points and so on)
・ The driver with the least amount of points will be crowned winner.
・ In the case of two or more drivers having equal point totals, the 3rd best result will be counted.
・ If a draw still results, the driver with the best time will be the winner.
Finals Heats Start Procedure
Each class: Competitors begin racing from a standing start once the buzzer has rang.
Stock Class : TT-01, TT-01R, TT-01E, TB-02, TB-02R, TB-03, TA-05, TA-05R and TA-05 IFS. The 1st place winner will be invited for Tamiya Asia Cup Championships 2009 in Bangkok.
GT Class : TB-02, TB-02R, TB-03 TBEvo3, TBEvo4, TBEvo5, TA-05, TA-05R, TA-05 IFS, TA-05MS, TRF415 and TRF416 can compete in this top class event. The 1st and 2nd place winners will be invited for Tamiya Asia Cup Championships 2009 in Bangkok
Open Stock : Any 4WD EP chassis can compete in this event. The 1st place winner will be invited for Tamiya Asia Cup Championships 2009 in Bangkok.
F1/Lemans : F103 Tamiya Formula One chassis only (F103, F103RS, F103RM, F103RX and F103LM). The 1st place winner will be invited for Tamiya Asia Cup Championships 2009 in Bangkok.
Mini Class : The allowable chassis for this class are: M-03 (Including M-03R) and M-04. Only for Philippine Cup Race . The winner would also be invited to the Asia Cup Championships 2009 in Bangkok but should bear all the charge including air ticket and hotel charge, etc.
Official Motors
*Please note that inspections will be very strict. Offenders will risk disqualification.
-Only official motors can be used in Qualifying and the Finals. Motors will be handed out as follows:
1. One GT-Tuned Motor (Item #53779) to each Stock Touring driver, GT driver, F1/Lemans driver and Mini driver.
-These motors will be specially marked and must be given back to the race organizers at the end of each race day. There is a probability that you will not be able to get the same motor the following race day.
-In case your official motors become damaged/unusable during the event, a replacement motor will be provided. However your recorded time will be unofficial and you will receive no points.
-Any driver who takes his official motor out of pit area will be disqualified.
For this year’s competition, we will also be implementing limits on Maximum Motor RPM and current consumption.
GT-Tuned Motor Max RPM: 19,500rpm
Measured with Muchmore Motor Master CXT Mode (7.2V).
The top finishers of each Qualifying and Finals Heat will have their motor’s Max RPM checked at the end of the Heat so the machine cannot be taken back to the pit area. If, 10 minutes after the Heat, the motor’s Max RPM exceeds the set limits, penalties such as disqualification of times may be given. Please note that the motor will be hot after running and will thus have 200-300 higher RPM.
There are no Max RPM limits placed on 23T motors. However, inspection of brushes and springs will be strict.
TAC 2009 - Bulletin #1
1. changing the battery connector of the Tamiya 1600SP battery to deans or any other type of aftermarket battery connectors is allowed
2. changing the bullet connectors of the Tamiya GT Tuned motor to deans or any other type of aftermarket motor connectors is allowed including directly hard-wiring it your esc but you need to resolder back the original bullet connectors when you return the motor after the race.
3. you can change the kit screws to a hex type, aluminum type or titanium type as long as they are tamiya brand. if you only have 1 or 2 screws that you changed we might allow it but you have to present it to the race organizer first for clarification.
NOTE: please don't hesitate to consult with the race organizers during the race
The TAC Philippines Qualifying Championship 2009 - Revised Qualifying Dates
Qualifying Round Qualifying Dates
Warm-Up Race April 4, 2009
Round 1 April 18, 2009
Round 2 May 2, 2009
Round 3 May 16, 2009
Round 4 May 30, 2009
Round 5 June 6, 2009
Round 6 June 20, 2009
Round 7 July 4, 2009
Round 8 July 18, 2009
Pre-Departure Race August 29, 2009
Race Procedures
2) GT Class
3) F1/Lemans Class
4) Open Stock 23T
5) Mini Class
Official Motors
Round 2 May 2, 2009
ayan ha, not allowed kahit anong spray for the motors... Tama ba sir Rnold? Meron kasing mga cleaner na may oily residue.
and for all the racers:
all the motors have been broken-in and dyno-ed already. we have the record of all its starting RPMs and all are within 18,000. there are no mutant super motors in this batch as none went above 19,000 RPM, and the variations and differences within hundreds of RPMs are grouped together in the same class. with a few more minutes of break-in time you could increase a more hundred RPMs but we do not expect any motor to go above 19,000 or 20,000 RPM or go below 18,000 RPM when we dyno the motors again after the race.
so, you can just concentrate on your driving now.
Sir rnold, just to clarify, your post mentioned an additional P50 to the entry fee for 2nd entry in the ST, GT, or F1 classes to cover for brushes and maintenance of motors. That means that a 2nd (or 3rd) entry would be P200 (instead of P150) is entry is in any of the classes mentioned?
But also mentioned was that the initial cost of the motors (P1,100) is already inclusive of motor brushes and maintenance. If the motor cost is already inclusive of the brushes and maintenance, why the additional P50 in the entry fee? thanks!
d lumusot yun kick-back ko
rnold, di ko padin maintindihan. is it 600 (1rst class) + 1,100 (1rst class motor) + 150 (2nd class) + 1,100 (2nd class motor, except sa open class)?
kaya pala mahal ibm
kaya pala mahal ibm
hindi ba pwede maski linisin lang sa compressor?
meron na po ba layout?
