Go Back  R/C Tech Forums > International Forums > Manila Racers
Electric Touring / On-Road RC >
Like Tree1Likes
Old 07-05-2004, 07:39 PM
  #2356
rough512's Avatar
Pweedee!!!
basta 10 years to pay ha?
rough512 is offline
Old 07-05-2004, 07:57 PM
  #2357
Trader Rating: 82 (100%+)
BLP: glad to help ano yung kinuha mo, yung all silver-colored na bit (yung parang US brand na multiple sided cutting edge) or yung kulay red na may wax sa dulo? di pa kasi ako nakakagamit ng all-silver na bit, kindly post feedback kung OK yung cut.
BALUGZ: sa PS1, gamit ko dati 1+ yr. old loose 2400 sanyos, kaya pa naman mag 7 minutes sa type RR, approx 5.5 to 6 ratio sa TA04. not sure sa 19T, baka kaya mo idaan sa gearing
marvi is offline
Old 07-05-2004, 08:05 PM
  #2358
rough512's Avatar
Marvi.
5.5? sa 23T? ibig sabihin hindi pa pala ako overgeared sa 5.8 using 27T!!!
O'rayt!!!
rough512 is offline
Old 07-05-2004, 08:08 PM
  #2359
joelt's Avatar
MARVI - Ala na silang stock nung silver. Either that or the guy behind the counter didn't notice it. Ang naibigay lang nya sa akin were the red ones.
. . . . Sayang I would have wanted to try the silver one you mentioned too. Just as happy though na may nakuha akong red ones.
Salamat ulit.
BLP
joelt is offline
Old 07-05-2004, 08:15 PM
  #2360
ROUGH: 5.56 actually (120spur / 46pinion) wierd nga ng 23t ko, parang lumalakas pa sa acceleration habang gumagamit ako ng mas malaking pinion baka malapit na to sa huling hininga niya kaya ganon
BLP: ayos last week andun ako, puro silver yata meron sila, wala naman nung red
marvi is offline
Old 07-05-2004, 08:25 PM
  #2361
joelt's Avatar
ROUGH - Ano ba ang gamit mong 27T? 5.8 seems a little tall kasi eh. Check out your comm and brushes to verify this. Kung mapula ang comm mo, chances are, overgeared ka na.
Personally for Capitol, I'd only go as far as 6.2 for the likes of a P2K2 or Core Stock and 6.8 or 7.0 for the likes of a Monster. For 19T's, I'd go as far as 6.2 for the Chameleon and about 6.0 for the Quad Mags.
Pdeng mahina na yang motor mo because of several things - burnt brushes, a comm needing a cut, misaligned hoods, spent magnets or batteries that lack the necessary voltage.
In my case, ang suspetsa ko ay magnets. My monsters don't peak as high as they used to anymore eh, and I've read in some of the threads that magnets of the Monster don't really last that long.
BLP
joelt is offline
Old 07-05-2004, 08:31 PM
  #2362
Balugz's Avatar
Trader Rating: 16 (100%+)
Maganda pa rin ba yung numbers ng 2400 mo when you last use it? One more question regarding tamiya parts, please check my attachment. Meron ba nabibili sa Lils TRF damper rod guide & o-ring? Tnx.
Attached Thumbnails Electric Touring / On-Road RC-oring.jpg
Balugz is offline
Old 07-05-2004, 08:34 PM
  #2363
Balugz's Avatar
Default Re: Re: Battery Q
Originally posted by tatalope
ako 19T gamit ko s offroad s JP using 2400mah nkktpos nmn sobra pa! eh ang laki ng JP.. pero sympre pg ptapos n un heat medyo humihina n un
Anong 19t motor gamit mo, Reedy o Trinity? Magkano ulit bili mo sa 2400 mo, 270 o 275 ba?
Balugz is offline
Old 07-05-2004, 08:42 PM
  #2364
balugz: sumakit ulo ko sa attachment mo di ako sure kung meron nyan dito, better ask T. Mak. Tommi, where are you? baka pumunta ako sa makati this week, pwede ko rin i-check for you tapos ite-text na lang kita. yun pa rin ba no. mo?
nakalimutan ko na yung nos. nung batts, nabenta ko na rin kasi yun a few months ago i guess ok pa naman siya kasi tumatapos pa naman ng race pag stock. regular naman ang maintennance ko dun. the only reason i sold it is because kumuha ako ng 3300s para magamit ko for both stock and mod.
marvi is offline
Old 07-05-2004, 08:53 PM
  #2365
Balugz's Avatar
HAHAHA... Sorry yun lang picture nakita ko sa net. Yep same number pa rin. Regarding sa shock parts, diba pag binaklas mo yung TRF shock meron o ring tapos mga parang puting plastic bilog? Pagtinignan mo sa ilalim yung shock mo, makikita mo iyon.
Para di ka mahirapan, 53574 TRF Damper Rod Guide & O-Ring (4 sets) Salamat ulit.
Mahilig ka pala sa higanteng pinion. Meron ako dito fresh na fresh 48 & 49 baka gusto mo.
Balugz is offline
Old 07-05-2004, 09:12 PM
  #2366
rough512's Avatar
BLP > The motor's a P2K2 pro. I had high hopes for this motor. Siguro nasa 3-4 race days lang sya, since I only use it on big races. I'm gearing it 5.8 kasi iniiwan talaga sa straights. my T1's Xray is free enough. I can spin the bearings when I take them out of the car. The belt's loose and ontop of that, I'm using the low-ratio gears which are supposed to free up the drivetrain more.
Balugz > IN my TRF shocks, I removed the rod guides and replaced them with O-rings. Medyo tighter sya but it keeps the oil in and the dust out of the shock bodies better. Try mo, wet the O-rings with shock oil before installing.
rough512 is offline
Old 07-05-2004, 09:46 PM
  #2367
Trader Rating: 32 (100%+)
Default TRF Damper Rod Guide & O-Ring
53574 OP574 TRF Damper Rod Guide & O-Ring *4
available sa Lil's Makati... Php 200.00
Rnold is offline
Old 07-05-2004, 09:58 PM
  #2368
evaa's Avatar
Originally posted by Baguhan Lang Po
ROUGH - Good news tungkol dyan sa pag-taxi mo. May car loan dito . . . .
. . . . pde ka ng kumuha ng brand new na CGM, XXX-S, o TC3 kay MANGPIT pagpasok mo dito.
BLP
Rough: nabasa mo na msg ni BLP, so yung pinagusapan natin dati pwede mo nang gawin, hehe
Rough and BLP: di ba magkasama na kayo sa isang ofc? wentuhan na lang kayo sa isang coffee shop jan, mas mabilis pa response. jk
striker: hinahanap ko ung xray mo na nagiba d2 sa thread, naipost mo ba?
evaa is offline
Old 07-05-2004, 11:13 PM
  #2369
tatalope's Avatar
Default Re: Re: Re: Battery Q
chameleon 2 pro, 270 bili ko nun march pa sbi dun s store tataas na daw... pre mura n un gp3300 280 lng konti lng diff. un lng binili ko dati kc un chrger ko for nicd lng tsaka mahal p ata dati un 3300 eh
tatalope is offline
Old 07-06-2004, 01:44 AM
  #2370
joelt's Avatar
EVAA - Mas maganda yung nagpo-post na lang dito sa RC Tech . . . . nde obvious na nde pala trabaho ang pinag-uusapan.
ROUGH - Ano yung pinag-usapan nyo dati ni EVAA??? Baka lang kasi ginagawa ko na yung raket na yan dito, kaya busina muna kung sakali.
Seriously 5.8 is way too tall for your P2K2. Kuha ka ng putnam or paradigm brushes tsaka trinity red and green springs. Let's cut your comm, check your hood alignment, replace your brushes, and springs.
joelt is offline
