Go Back  R/C Tech Forums > International Forums > Manila Racers
Electric Touring / On-Road RC >
Like Tree1Likes
Old 09-23-2008, 06:24 AM
  #22201
tantalus007's Avatar
Trader Rating: 17 (100%+)
Originally Posted by Mitch Sy
Kung gusto mo ng meant to be burned...yung isang tao dyan madami...B.I. eh
oo... si N.A. marami nian... Natural Ashes... BI talaga yun...
tantalus007 is offline
Old 09-23-2008, 07:28 AM
  #22202
meikelumb's Avatar
Default 2008 North-Luzon Championship
2008 North Luzon Championship
let's do online registration for the Silver Can, M-Chassis, Stock 23 Classes here. please add your details (frequency, PT):
Silver Can Class
1.Neil Severino/2.4Ghz
2.Felix Chua/ 40.710
3.Rough 29.905
4.Alfonso Ramos/2.4Ghz (Not yet sure)
5.Joel M 26.995
6.Nikki Esteban
7.Dennis Ventura 26.995
8.Ernest Tortuga/2.4Ghz
M-Chassis Class
1. Joel M 27.255
2. Michael De Guzman 27.145
3. Dennis Ventura 26.995
4. Noel Irrabagon
5. Simon Javate
6. Tin-Tin Esteban
Stock 23 Class
1.Alfonso Ramos/2.4Ghz
2.Neil Severino/2.4Ghz (if there's no quorum in Silver)
3.Ernest Tortuga/2.4ghz
meikelumb is offline
Old 09-23-2008, 07:40 AM
  #22203
alecladanga's Avatar
toink and voodooph:
i can't play this saturday pala, may lakad kami ni commander...
sa october na ako ulit takbo
alecladanga is offline
Old 09-23-2008, 08:26 AM
  #22204
Mitch Sy's Avatar
Trader Rating: 8 (90%+)
Looks like some yummy upgrades for Xray T2'008
303071 Belt Tensioner Set T2'007, T2'008
Smart, easy-to-use XRAY Belt Tensioner Set for controlling center drive belt
tension and twisting. High-quality components include CNC-machined
lightweight alu mounting post, high-speed ball-bearings, and mounting
hardware.
Fits: XRAY T2'007 and T2'008.
305136 T2'008 Alu Solid Axle Driveshaft Adapters (2) - Hard Coated
CNC-machined diff drive shaft adapters for XRAY T2’008 Composite Solid
Axle, made from premium lightweight Swiss 7075 T6 aluminum.
The alu driveshaft adapters for the front solid axle are a direct replacement
for the stock composite versions but with increased the strength and
lifespan.
The modular design of the front solid axle allows for easy removal and
servicing. Internal slots key to drive shaft pins require use of driveshaft
blades #305241 (included), enabling direct power transfer to the wheels and
eliminating excess play between the outdrives and drive shafts. Set of 2.
Precision machined with highest tolerances using premium fully-automatic
German CNC-machines. High-quality hardcoating is done at XRAY’s own
in-house fully-robotic hardcoating line, ensuring a perfect hardcoated
surface every time.
Fits: XRAY T2'008.
305341 T2 Drive Axle - Lightweight - Hudy Spring Steel™
Super-lightweight drive axle for XRAY T2, CNC-machined from world-
renowned, top-secret HUDY Spring Steel™.
Strategically machined for toughness and light weight without compromising
strength. Reduces rotating weight by up to 35% over standard outdrive.
Fits: XRAY T2, T2R, T2'007 and T2'008.
Mitch Sy is offline
Old 09-23-2008, 09:22 AM
  #22205
Default added
Silver Can Class
3.Rough 29.905
5.Joel M 26.995
6.Nikki Esteban
9.Dex Camba/Fasst 2.4ghz(if sched is free)
M-Chassis Class
1. Joel M 27.255
4. Noel Irrabagon
5. Simon Javate
6. Tin-Tin Esteban
Stock 23 Class
white_fang is offline
Old 09-23-2008, 11:07 PM
  #22206
pitshop's Avatar
Trader Rating: 56 (98%+)
hopefully october available na yan mga new parts for xray
baka pag naisipan ko pati hop up ng ibang brand paratingin ko rin hehe
pitshop is offline
Old 09-23-2008, 11:36 PM
  #22207
Mitch Sy's Avatar
AYUS!!!
Yung kit mo buo na ba? Kelan ba maiden run nun? Baka manuklaw yan ah!
Mitch Sy is offline
Old 09-24-2008, 02:17 AM
  #22208
sir pa help nmn po, is there a dealer of duratrax vendetta here in pinas??
pa help nmn po san may hobby shop meron, ung meron sanang parts support..
tnx mga sirs..=)
hotrob is offline
Old 09-24-2008, 03:10 AM
  #22209
rough512's Avatar
ako din may tanong.
standard ba yung mga balancing plugs na ginagamit sa mga Lipo packs? i.e. yung imax B5 charge kaya nyang i-balance charge ang SMC, Orion, UNI etc packs?
rough512 is offline
Old 09-24-2008, 03:55 AM
  #22210
Koya Dale.com's Avatar
Originally Posted by bmmer701
oo nga po laro na po ulit
no budget and time pa e
may laban pa ba SD?
Koya Dale.com is offline
Old 09-24-2008, 04:06 AM
  #22211
rough512's Avatar
Dale : kung ikaw siguro gagamit may laban pa. hehehe.
rough512 is offline
Old 09-24-2008, 04:45 AM
  #22212
ROBORAT's Avatar
dale: MANUELA BOYS & GIRL!! .... ako rin gumagana pa pala account ko dito! .... taena, inuman tayo nila ted, kentot, jr, vj, nani at si mon! mga members ng club manuela! hahaha .... sami na rin ni ted si chucky "dreyfus" lidell! langya yon, di nagsasabi!
.... ano balita mga boys???
ROBORAT is offline
Old 09-24-2008, 05:22 AM
  #22213
Mitch Sy's Avatar
Ayus yan! Sa race track kayo mag reunion para masaya
Eto...tigang sa karera! Kelan ba ang iyong pagbabalik?
Kung sakaling mag reunion kayo sa track nyan...baka manginig si bmmer nyan! Baka pagkamalan kayo ni bmmer na dart board nyan
Mitch Sy is offline
Old 09-24-2008, 05:30 AM
  #22214
Regional Moderator
rajS's Avatar
Trader Rating: 35 (100%+)
Originally Posted by rough512
ako din may tanong.
Rough:
Orion- bullet connectors ang gamit mo 4mm sa main line and 2.5mm sa middle line(bridge of cell 1&2)
SMC - deans ang main line tapos balance taps is chinese standard na 3 pin plug
Most modern chargers : imaxx / hyperion use the chinese standard refer to the pictures para claro.
Pack on top uses hyperion balancer
Pack on bottom uses chinese standard balance taps (SMC/GE/HIMODEL/DUALSKY/ETC)
To answer your question:
Your balance charger can charge any lipo pack, but... you must have the appropriate balance lead to charge specific packs since there are several standards amongst manufacturers.
Attached Thumbnails Electric Touring / On-Road RC-pict8432.jpg
rajS is offline
Old 09-24-2008, 05:36 AM
  #22215
rough512's Avatar
rajs : ok thanks. Imax B5 yung kukuning kong charger. Baka may alam ka pang nagpapasok ng saddle Lipo packs katulad kay jobo_ph?
rough512 is offline
