Go Back  R/C Tech Forums > International Forums > Manila Racers
Electric Touring / On-Road RC >
Like Tree1Likes
Old 06-27-2004, 08:40 PM
  #2191
ROBORAT's Avatar
BLP: when i borrowed Jason's Core Based 9x2 last week, i geared it 8.59. I would start with that with the revolution since both are essentially based on the same motor (armature and can) with just a different endbell. Yup, im getting a revolution as well. still deciding what wind - either a 10x2 or 9x2 ... so far im leaning towards a 10x2 since i still have a 9x2 Kr which i can always turn to if i need my car to be extra ballistic.
ROBORAT is offline
Old 06-27-2004, 09:04 PM
  #2192
paulc's Avatar
Default Re: Re: mensahe...
Originally posted by tabs
pre, sorry, who are you? i dont know you. what are you talking about? sinong bakal boys are you referring to??
paulc is offline
Old 06-27-2004, 10:01 PM
  #2193
evaa's Avatar
Originally posted by Balugz
Mas curious ako doon sa motor and batt. Paging Kulit & Evaa, wats ur secret?
batt secret? borrow the best battery out there tapos charge mo ng 10amps tutal, di naman sa iyo e.
evaa is offline
Old 06-27-2004, 10:04 PM
  #2194
highwayman's Avatar
Default Re: tanong lang mga sir
Originally posted by kuuipo
11 t motor and 27t motor gamit ko sa losi xxx-s, anong pinion gagamitin ko?
11T 90 spur / 21 pinion
monster 90 / 24
highwayman is offline
Old 06-27-2004, 10:12 PM
  #2195
highwayman's Avatar
EVAA : ... im never lending you my batts
BLP : i agree with robo... complete rebuild.
gomez : stock set-up works... stick with it first, your driving was pretty good last sat., i think the set-up works for you.
striker : laro tayo uli!
Old 06-27-2004, 10:30 PM
  #2196
lem2's Avatar
Default Looks like. . . . .
I missed a lot last saturday!!!!
Oh well could not do anything, daughter is sick
Bgomez: galing ng CGM noh!!! And stock set up works!
BLP: may revolution ka na!!!! kakatakot na pinag uusapan ninyo, di na ako makakahabol sa inyo!!!!!
Lmagnum: alang hiyang doctor yan!!! Para akong bumili ng KIT!!! but, seriously, salamat kahit masakit na masakit sa bulsa!!!!!
Pisthop: sir, sorry ha, have the money dami lang talaga aberya.
EVAA: kay kurips ka humirap mabaityun-- charge natin ng 10amps!!!!! mag papahiram yun tutal birthday niya sa sabado!!!
lem2 is offline
Old 06-27-2004, 10:41 PM
  #2197
rough512's Avatar
May tinutumbok ka?
8 amps lang naman pinang-charge ko sa batts mo a. buti nga 8 amp pa kasi pagkatawid na pagkatawid ng finish line eh biglang nag-drop na yung batts.... as in tumigil na... hindi yata kasi charged yung pinapahiram mo sa kin that time eh....
It's not the motor, it's the charging current that does the job
Joke lang sir...
rough512 is offline
Old 06-27-2004, 10:47 PM
  #2198
joelt's Avatar
ROBO - Tenks again for the gearing tip.
HMAN - Let's see what will happen (again) this Sat. Pag sablay pa rin, hope you don't mind my taking up your offer of giving my Pt a once over.
STRIKER - Mod ka na sir!!! Matibay naman ang fish mo eh, given the fact that it scored several perfect 'tens' hitting the fence without any damage. May island hopping pa sya in between.
LEM2 - Nde ko idea yung Revolution sir. Si ITIM ang may sala dun. For the weekend, the original intention was to make KURIPS spend a lot lang (para sa 50th bday nya). Eh na-carry away itong si ITIM sa pagterno terno ng gamit. So lahat kami tuloy, napabili nung motor.
. . . . In a way, buti na lang din at hindi ka nakapunta. For sure kasi na humaba din yung pagka sponsor mo sa notebook ni PITSHOP BOSS.
BLP
joelt is offline
Old 06-27-2004, 10:55 PM
  #2199
lem2's Avatar
Default BLP
BLP
Scared na talaga ako, mga wild na motors ninyo!!! Good na din eh mukhang ako pa ang pinakamahaba sa notebook ni Pitshop boss!!! Mababawasan na yun sa Sabado----- who knows baka makisabay din ako sa inyo!!!!!
Sa pagkuha lang ng revolution ha---hindi sa bilis!!!
Lem
lem2 is offline
Old 06-27-2004, 11:45 PM
  #2200
S-T-R-l-K-E-R's Avatar
BLP
yup yup yup ngayon nakita mo na yung tibay ng fish!!! isipin mo nga glitch sa infield - then jumping the island and cleared the width of the far straight. then upon hitting the fence holding on for about 2 secs. before landing sa rocks. damage = zero!!
pero looking at the brightside atleast na prove ko yung theory ni kurips na di takaga makakapreno yung kotse kapag nasa hangin o kaya habang nag cacartwheel!!!
S-T-R-l-K-E-R is offline
Old 06-28-2004, 01:42 AM
  #2201
ROBORAT's Avatar
BLP: iba din talaga if you do a "thorough" rebuild. as in check and clean everything. cleaning is a major thing. i literally scrub my motors clean especially the hoods! di kasi nalilinis ng mabuti yung motor with just motor spray. hood alignment is another major thing. as in i took the time to really ensure they were aligned with wear on the brushes being straight down the middle. last but not the leat - gearing! gear down, run a few laps and see how the power is. dont finish a whole pack! just get a feel if you still get the power you want despite the lower gearing. after a few laps, i you feel you need to adjust your gearing, do so. i suggest you get a different size spur gear para you can get the in between ratios. somtimes kasi changing one tooth is too big a jump. i feel that's the case even with 64 pitch gears. kaya now i have both a 100 and 106 tooth spur. nakukuha ko na rin yung in between ratios. madali lang naman mag palit ng spur sa CM eh. somthing you might want to try lang ....
ROBORAT is offline
Old 06-28-2004, 05:26 AM
  #2202
kupz's Avatar
ROBO: This saturday, practice na talaga! set up na natin losi! Problem is wala na ko tires
kupz is offline
Old 06-28-2004, 06:10 AM
  #2203
silver_spo0n's Avatar
Arrow T1R set-ups
team xray,
pm nyo naman sa kin ang magandang set-up para sa xray T1R, 23turn motor gamit ko..
thanx
silver_spo0n is offline
Old 06-28-2004, 07:39 AM
  #2204
lmagnum's Avatar
kinuha ko na finally yung revolution! pero 10 x 1 na lng.
yung lathe sana kunin ko e, pero because i wanted the Yokomo-Sanwa-Revo Team to be the team to beat, yung revo na kinuha ko, hehe!
The Yokomo-Sanwa-Revolution Team members:
Ronald lmagnum - Chairman Shepherd
Joel BLP - ViceChair
Chris beowulf - Treasurer
Mang pitshop - Sponsor
Still open for membership. membership fee - P500 only
pahabol lang: ViceChair! yung Team Lathe natin bka makalimutan mo ha!
lmagnum is offline
Old 06-28-2004, 07:53 AM
  #2205
lem2's Avatar
hindi pwede ako sumali!!!! K.O. gamit ko! Kita na langtayo sa sabado!!!! Tinganannatin kung kaya ngREVO mo yun Tamiya Motor ko
lem2 is offline
