Go Back  R/C Tech Forums > International Forums > Manila Racers
Electric Touring / On-Road RC >
Like Tree1Likes
Old 08-20-2008, 04:44 AM
  #21931
|JayFlores|2's Avatar
Trader Rating: 16 (100%+)
ayaw ko nun.. masyado halimaw. wala nun pinapahanap mo. iba meron eh... baka lang gusto mo pressurized
|JayFlores|2 is offline
Old 08-20-2008, 05:13 AM
  #21932
bmmer701's Avatar
Trader Rating: 17 (100%+)
Originally Posted by oldskul
may race na ulit sa saturday!!!
Date: August 23, 2008 (originally scheduled on August 16)
Race Start: 2pm
Classes:
Open Stock 23T Class
-Any 4WD EP chassis
-Any brand stock 23 turn motor (brushed motors only)
-24mm rubber tires only
-6-Cell NiMH/NiCD and Lipo batteries allowed
-Tamiya GT bodies or 190mm 4- door touring sedan body allowed
-Weight limit: 1,500g with transponder
Open Modified Class
-Any 4WD EP chassis
-Brushed/Brushless motors allowed
-6-Cell NiMH and Lipo batteries allowed
-190mm 4- door touring sedan body only
Food and drinks will be served. Beer and cigs too!
Trophies for top 3 winners.
Race fee: 500 pesos – 1st entry
200 pesos – 2nd entry
Just heard from arnold Ride layout sa Sat.
bmmer701 is offline
Old 08-20-2008, 08:52 AM
  #21933
Trader Rating: 32 (100%+)
Dear TAC Members,
Until now we received following questions. Please forward this Q&A to your drivers and kindly advise them to study the rules well in advance.
*BUGGY CLASS
Q1: Can TRF501x plastic parts be used in DB01? (I noted that some parts of
TRF501X can be used but not in list , because of different materials)
A1: OK. We added #51272(C parts), #51275(F), #51278(K) and #51279 (R).
*STOCK CLASS
Q2: Can #51201 Ferrari F430 Body shell be used in Stock class this year ?
Last year was allowed, but this year it is missing from the parts list.
A2: #51201 can be used in Stock Class. You can use bodies from; (1) supplied in kit box of the base car (2) compatible Spare Body
sets
*The arrangement such as Mini body on TT01 can not be allowed. IFS
bodies can only by used with IFS chassis, TB-03 chassis and TT01 with combination of instructed parts.
*If the body is compatible, tire walls should be set within body width.
*Modifications such as making hole on the body in order to avoid damper stay can not be accepted.
Q3: How do you differentiate between TT01 and TT01E? (if I using TT01
gearcase ,with TT01E upper deck , is it ok?)
A3: The car do not need to be an exact TT01 / TT01E. So it is OK. You can
use TT01 parts for TT01E, you can use TT01E parts for TT01. But please make sure to use parts in combination if it is instructed in the Parts List.
*4WD GT CLASS
-TA05 standard model
Q4: Can I use the TRF416 hubs/uprights/axels (the ones like IFS/IFS-R)
A4: OK. We added 51332 and 51333 to the list.
Q5: #53988 37T pulley
A5: OK but you have to use #53989 & #54045 together.
-TA05 IFS
Q6: 37T pulley as in IFS-R
A6: Same as above
Q7: 2007 NSX shell / ARTA Shell
A7: OK. Please refer to the basic policy mentioned in Q2.
TB03 :
Q8: Can I use below parts?
1. EVO4 Suspension mounts - No. actually they can be attached, but it
is not proper use. (indicated angle will be incorrect). Please use TB-03 Sus. mounts.
2. Short/std Reverseable arms - OK. Please check 53899 / 53928 in
revised list.
3. Only 3 shells available, what about the rest? - Normal touring
bodies on Low chassis (IFS, TB-03) will be allowed. Please follow the answer for Q2.
4. Optional wing set - OK. You can use #53371, #53470 or #53604, or
kit-supplied wing. (please do not use wings taken from other kits)
5. General parts like blue ti screws, other length ti turnbuckles,
5mm alu balls, 5mm shim set, etc - "Color variation" parts can be used as long as original parts are OK. But we afraid we do not have Blue Titanium Screws in our line.
6. IFS alu. rocker - OK.
7. 416 Carbon uprights (front and rear) - OK. Please refer to Q4
*M-Chassis
Q9: #49468 (M-Chassis 11-S Wheel Silver*4)
which all the same as #49461,#46469 and #49470,only the Colour difference,
can it be accepted to use ??? .
A9: It is OK. "Color variation" parts can be used.
Best regards,
Tomomasa Hayashi
International Division
Tamiya, Inc.
File Type: zip
Rnold is offline
Old 08-21-2008, 12:29 AM
  #21934
oldskul's Avatar
To all winners of the TAC Philippine Qualifiers:
please attend the Rnold and Oldskul Birthday Race. the awarding ceremonies for the TAC will be held on this event also.
oldskul is offline
Old 08-21-2008, 02:59 AM
  #21935
tantalus007's Avatar
mala-halimaw din naman yung driver... ano meron dun??? magkano??? vrooomm psshhhttt!!!
si mr. evo x nagbreak-in na ng motor... balak ng ilatag yung bago niang ifs r msx evo...
tantalus007 is offline
Old 08-21-2008, 04:39 PM
  #21936
neil4wd's Avatar
Trader Rating: 20 (100%+)
ISANG TULOG NA LANG BOYS!
neil4wd is offline
Old 08-21-2008, 04:55 PM
  #21937
neil4wd's Avatar
Charge your batts.
Check your tires.
Tighten your screws.
Check your weight.
Cut your comms.
Clean your brushes.
Lube your bearings.
Check your belts.
Patch your bodies.
Test your charger and fans.
Inspect your chassis, suspension and gears.
Replace cracked or loose parts.
There...now you have no excuse not to be ready tomorrow.
ISANG TULONG NA LANG BOYS!
neil4wd is offline
Old 08-21-2008, 10:17 PM
  #21938
kakagaling ko lang dun mga ilang araw rin. may problema pa sa servo si mr. X.. pero llatag na balak ko nga pahiramin ng mod brushed.
Old 08-22-2008, 02:18 AM
  #21939
hindi mo nga daw tinulungan magmount ng gulong... sige pahiramin mo ng motor, ako na bahala sa esc pang brushed... baka masunog yung kania...
Old 08-22-2008, 02:42 AM
  #21940
suntok2's Avatar
Bradir puwedi na credit card sa Dogbone
suntok2 is offline
Old 08-22-2008, 04:01 AM
  #21941
sandrixx's Avatar
Default bradir!
todas na..., ayuzzzzzzz!!
sandrixx is offline
Old 08-22-2008, 05:38 AM
  #21942
hehe kaya na i-mount dun yun. dami pang mount ng goma dun! baka lifter pa ung chassis ng auto nya. hehehe
Old 08-23-2008, 07:11 AM
  #21943
Momo San's Avatar
Default Thanks to Rnold and Oldskul
Many thanks to the Birthday Boys Rnold and Oldskul for the Fun Race Today!
Sarap ng food! Si Oldskul mas gusto ko pag di nakainom dahil tahimik pag lasing
Good Luck also to the Tamiya Boys for their upcoming race!
Bring home the GOLD!
Momo San is offline
Old 08-23-2008, 10:49 AM
  #21944
Mark Flores's Avatar
Trader Rating: 28 (100%+)
BDC, natapos ko na paint F103RM ko. Thank you for the paint! Sabi mo post ko pag natapos.
Ayrton Senna, Mclaren Honda colors.
Electronics nalang pwede na tayo maglaro!
Attached Thumbnails Electric Touring / On-Road RC-f1.jpg   Electric Touring / On-Road RC-f12.jpg   Electric Touring / On-Road RC-f13.jpg
Mark Flores is offline
Old 08-23-2008, 10:55 PM
  #21945
Big Daddy Cool's Avatar
Trader Rating: 15 (100%+)
Mark: Nice! Decals/Stickers na lang kulang. I like your hop-ups. Sana ako din meron nun.
Big Daddy Cool is offline
