Go Back  R/C Tech Forums > International Forums > Manila Racers
Electric Touring / On-Road RC >
Like Tree1Likes
Old 12-07-2007, 10:36 AM
  #19441
porshaa's Avatar
Need some stupid booty! im all set na...hehe!
porshaa is offline
Old 12-07-2007, 02:27 PM
  #19442
neil4wd's Avatar
Trader Rating: 20 (100%+)
kiriz...aha, so that's the secret speed sauce that you and Andrew use...hehehehe...thanks. BTW, I got my black can yesterday, hope you guys were able to get yours already.
porshaa...booty call so erli? Who's bed did you sleep in last night?
neil4wd is offline
Old 12-07-2007, 05:02 PM
  #19443
ROBORAT's Avatar
jay: oo, pero nahirapan ako hanapin talaga .... darkness lang kasi nakita ko eh ... hahaha btw, got my body prepped up na last night c/o ernie. electrnics are set, motors are set .... sana ako set na rin! hahaha see you tomorrow!
tanta: see you tomorrow! surprise us!
ISANG TULOG NALANG!!!!
Futaba Cup na!
ROBORAT is offline
Old 12-07-2007, 06:39 PM
  #19444
yan_1700's Avatar
Default ..
kainggit naman kayo...
booty call wtf its so early ah hehehehe
yan_1700 is offline
Old 12-07-2007, 06:52 PM
  #19445
MOTO's Avatar
Pota! kakaingit naman kayo. Dami kong trabaho eh di ako maka singit para kumarera. dadating din ako dyan!
MOTO is offline
Old 12-07-2007, 08:18 PM
  #19446
Alfonso_R's Avatar
FUTABA CUP PRE-REGISTRATION
Please indicate your name, class, frequency number, and pt number if you have one.
December 9, Sunday - EP Day
EP Open Black Can Class. Experts allowed!
1. Neil Severino - 2.4Ghz
2. Alexander Madamba - 40.815
3. Christian Saplala - 40.77/40.81
4. Andrew Saplala - Spektrum
5. Kristian Bernardo - Spektrum
6. Norman Cruz - 40.730
7. Felix Chua- 40.650
8. Joel Mangilit - 27.255
9. Fred Mina - 40.975
10. Alex Robertson P/T No 6572147, Spektrum (just in case)
11.Alfonso Ramos-15.650 (maybe)
EP Open Stock 23t Class
1. Gerry Soler - Spektrum
2. Erick Velasquez - 40.730
3. Jay "pink" Flores - Spektrum
4. Allan Colico
5. Fred Mina - 40.975
6. Arnold Dalusung - 75.590
7. NoeL Aldaba - Spektrum
Alfonso_R is offline
Old 12-07-2007, 10:44 PM
  #19447
yan_1700's Avatar
Default ..
12. Bryan Panaligan 40.69(maybe din!!)
4. Allan Colico
yan_1700 is offline
Old 12-08-2007, 12:35 AM
  #19448
kirizutochan's Avatar
yan: Anong maybe??? Bawal ang maybe!!!
kirizutochan is offline
Old 12-08-2007, 12:43 AM
  #19449
yan_1700's Avatar
Default ..
@kiri: esep esep pko
yan_1700 is offline
Old 12-08-2007, 12:59 AM
  #19450
neil4wd's Avatar
Bad yun...karera na lang.
neil4wd is offline
Old 12-08-2007, 01:12 AM
  #19451
jeda's Avatar
Tanong lang po. saan pwedeng mag pa design o pinta nang 1/10 car body. baka may pwede po kayong ma refer sa akin paki "pm" nalang po ako nang contact number at presyo sa bawat kaha,
balak ko pong mag pa design sa 4 na kaha nang kotse ko,
1 swift suzuki
1 nsx
1 esso
1 subaro
salamat po
jeda is offline
Old 12-08-2007, 02:21 AM
  #19452
Ask ko lang po, newbie here, may nakuha po kasi ako na TA05, tataasan ko po sana gearing sabi po sa lil's pwede yung pang TA04 kaya kumuha po ako ng spur na 120t and pinion na 43t, nung ilalagay ko po na hindi po magkasya yung spur po, may dapat po bang remedyo dun or hndi talaga pwede ung gear ng TA04, all stock po yung kit. What rin po ba recommended size ng pinion and spur gear nyo para bumilis lang po kit but using silver can motor only.
kidrrt is offline
Old 12-08-2007, 04:02 AM
  #19453
neil4wd's Avatar
Forgive me if the question is a bit basic...did you back off the motor? That's the only reason I can think of that will prevent the spur from fitting coz I'm assuming your gears have the same teeth size (pitch). If you did then perhaps the 120T is simply to big which leads me to your next question...
As to getting more speed..I'd suggest going to a smaller spur like the 112T or the 105T. I'm sure those will will fit coz I've used them with pinions bigger than the 43T. The masters here can correct me.
HTH
neil4wd is offline
Old 12-08-2007, 04:42 AM
  #19454
I don't think that a 120T spur will fit the TA05 chassis because the layshaft is very low. Pag masyadong malaki ang spur lilitaw na ito sa baba ng chassis which is bad. 105T is the best I think. With regards to what pinion you can use is virtually limitless, pwede kahit anong 64dp na pinion, whatever the brand basta nag-memesh ang gears.
Old 12-08-2007, 04:45 AM
  #19455
oldskul's Avatar
uy nabuhay! see you in next year's races. dadami pa namin ni robo! puro fun races, mga hindi nyo pa nagawa noon
oldskul is offline
