Go Back  R/C Tech Forums > International Forums > Manila Racers
Electric Touring / On-Road RC >
Like Tree1Likes
Old 07-29-2007, 03:11 AM
  #17416
VooDooPH's Avatar
Trader Rating: 18 (100%+)
Originally Posted by Lewd Skywalker
Sorry medyo late na ito, napansin ko lang sa gilid nung 4800 pack, DO NOT CHARGE MORE THAN 4 AMPS
OMFG!!!!
VooDooPH is offline
Old 07-29-2007, 06:12 AM
  #17417
Lewd Skywalker's Avatar
Trader Rating: 14 (100%+)
Voodooph: Oks lang yan bro, its still 1C eh. Basta remember as follows:
- charging at higher current MAY degrade performance and shorten battery life, no harm in charging at lower rates, pero it takes too F long
- make sure you're not over geared, check your Lipo temperature after the 5 min run, should not be more than 60degC. Optimal temp should be around 40-45 degC after a 5 min run. LiPos are more sensitive to heat than SubCs.
- be sure not to over-discharge, don't let the battery voltage go below 3V/cell (that is 6V for a 2-cell 7.4V pack). Actually pwede naman upto 2.75V/cell pero sobrang sagad na yun, I won't recommend. Better invest in the LiPO Smart Stop (cut-off) if your ESC isn't equipped with one.
- let it cool after a run, esp. if you're going to charge it again
- use the right charger, and make sure you're charging with the correct setting
- never drop it, kahit naka-case yang mga LiPo natin manipis pa din yung plastic and you can dent the soft insides.
- IN CASE, napansin ninyo lumobo or umiinit ng todo yung pack, ilayo ninyo to a safe place then dispose properly. kung tuloy-tuloy lumolobo yung pack, lumayo na kayo hehe fireworks yan for sure after awhile
Now I have experienced LIPO and BL in r/c cars... I can definitely agree that these technologies will be the future of R/C car racing. Sigurado yan, madami pang lalabas kanya-kanyang pakulo mga manufacturers.
Kokams (other than Peak/Orion), MaxAmps, ThunderPower, etc. yan ang mga aabangang brands sa LiPoly.
Tagal naman ng next race Anyone care to practice runs this coming weekend? Gawa tayo mini-race, kahit pindot system lang (laptop + software)
Lewd Skywalker is offline
Old 07-29-2007, 06:59 AM
  #17418
Trader Rating: 82 (100%+)
..Pre bakit yung mga EP chassis ngayon nagmumukhang nitro na (side belts) hehe
hehe, yung xxxs, single belt. yung mga bagong labas ngayon na touring, dual belt. ito naman, triple belt iniba nila yung layout ng chassis, dati naka 4x2 central batt to.
top view of the magic ep touring
Attached Thumbnails Electric Touring / On-Road RC-img_0537.jpg
marvi is offline
Old 07-29-2007, 06:02 PM
  #17419
ROBORAT's Avatar
Lewd: glad you're happy with the lipo/BL combo ..... i am too! definitely! this is the way to go. now i can concentrate more on my car rather than battery and motor maintenance inbetween heats. Sarap talaga!!! as for lipo being advantageous, i wouldnt say that. i agree though about the wieght thats why many races abrouad that allow lipo have imposed a 1500gr weight limit to neutralize that. with wieght being controlled, the playing field becomes fair. actually, as mentioned to you last sat, i think the car being too light weight does have some negative effects on the car's overall traction and stability. mine felt as though it was floating through the corners, a little less planted as the car throws its weight around. im actually looking forward to adding the lead weights to see how it improves the car.
... but i still thing from a strictly power output perspective, theres no clear advantage between lipo and nimh. fresh and good quality nimh packs really have insane voltage as well. when my nimh matched packs were new, my car was "balistic" too. when i switched to lipo i think they are just about the same. in fact, definifely mas malaki pa ang difference ng loose nimh vs matched nimh .... but we never had issues having them run together.
anyway, lets not belabor the point .... alam na ng lahat yun. now its time to charge up those packs and go racing!!! woooohoooooo!!! SARAAAAAAP!!!!
ROBORAT is offline
Old 07-29-2007, 07:30 PM
  #17420
Robo: Sa MOD I talagang walang clear advantage, lamang lang ng Lipo would probably be sa spec class. Lalo sa stock. Mataas talaga (8.4v at full charge) and halos linear ang discharge curve ng Lipo so advantage yun sa classes na iyon.
Kung power to weight ratio pag-uusapan, lamang talaga. Pero you have to tune your car na on-rails talaga para masulit yung advantage na ito. Though when regulations are applied, talagang fair and square na yan. Hmm... pwede pala sa r/c drag race maka-lamang diba Voodooph??? 4800Lipo + 3.5R or 2.5R!!!
Anyway let's not go about it baka ma-misinterpret at ma-protest ang mga naka-Lipo. Basta pare-parehong battery lang yan Nasa driving na lang daanin
Marvi: Pre siguro maglalabas din sila ng Lipo packs na naka 3x3 congfiguration
Mitch: Kaya naman pala di mo mai-set yung ride-height at droop ko eh, kapos yung shock length. Mas maiksi yung shock ball end nung JRXS kaysa sa Type R. Talagang di makukuha yung 4.5+3 at 4.5+4. Pwede na pre, sama lahat terms pa dun sa dati presyo
Old 07-29-2007, 08:33 PM
  #17421
Mini Toink's Avatar
Trader Rating: 30 (97%+)
TUKSO
Toink
Mini Toink is offline
Old 07-29-2007, 08:47 PM
  #17422
ROBORAT's Avatar
Lewd: actually, sa spec nga may konting lamang ang nimh .. but anyway, broken record na tayo niyo. sabak na! in the end, driver choice nalang yan and driving skill will still be the biggest factor.
mga EP boys: kung walang race this sat, at walang akong lakad, ep practis and/or mock race tayo sa JP. gusto ko pa mag set up while the track is warm. medjo malamig nung sat so malamang iba handling and i'll have to adjust my set up even more. konting tono pa .... di pa ako 100% hapi sa handling although much better na auto ko last sat.
ROBORAT is offline
Old 07-29-2007, 08:56 PM
  #17423
Tara praktis tayo... saan ba makakapag download nung race software na di-pendots? dati may ginagamit kami sa circle noong di pa uso yung AMB eh... pependot ka lang nung 1-10 pag daan nung kotse, tapos number/sticker lang nakalagay sa kotse mo... si JR o si Ramil ang pependot sa laptop hehe... will bring my PC...
Old 07-29-2007, 09:14 PM
  #17424
tantalus007's Avatar
Trader Rating: 17 (100%+)
lewd: thanks for the meal last sat... regards na rin kay charlie and novak...
toink: too bad you left early... hindi mo narinig fearless forecast ni jay... nagdilang anghel si motor master jay...
jay: el presidente ka nga...
robo:
kulang pa rin yung setup mo last sat??? what more pa kaya if you get an almost perfect setup for your kit...
tantalus007 is offline
Old 07-29-2007, 10:35 PM
  #17425
Mini Toink's Avatar
Abuh! Anong fearless forecast nanaman yan?! Nagdilaan kayo??
Toink
Old 07-30-2007, 12:24 AM
  #17426
oldskul's Avatar
You are cordially invited to the...
Rnold and Oldskul's Birthday Race
Tentative Date: August 11, 2007
Time: Track opens at 8am, Race Proper starts at 11am
Registration Fee: 700 pesos only, additional entry is 250 pesos
Includes: All-day buffet, softdrinks and beer will be served. Smoke all you can cigarettes too.
Classes:
-Tamiya Stock Touring Class (expert drivers are not allowed in this class)
-Open Stock 23T Class
-Open Modified Class
Regulations:
-Tamiya TT-01 Chassis only
-Mabuchi Silver can motor (2 vents only)
-TEU ESC only
-Only the following three kinds of tire can be used:
#50419 Racing Radial Tire, #50454 Racing Slick Tires, #50810 Racing Semi-Slick Tires
-Only Tamiya batteries allowed in this class (up to 3700mah)
-Weight limit: 1,450g without a transponder
-Any 4WD EP chassis
-Any brand stock 23 turn motor
-24mm rubber tires only
-6-Cell NiMH/NiCD and Lipo batteries allowed
-190mm 4-door touring sedan body only
-Weight limit: 1,500g without transponder
Open Modified Class
-Any 4WD EP chassis
-Brushed/Brushless motors allowed
NOTE: Use of Personal Transponders are encouraged and will be given a 50 pesos discount on race fee. Those who don’t have a Personal Transponder will have an additional 50 pesos on their race fee
We hope you can be with us as we celebrate our special day.
Attire: racing (joke)
RSVP: Oldskul – 0918 3453746
Rnold – 0920 9538177
layout to follow
oldskul is offline
Old 07-30-2007, 12:28 AM
  #17427
rough512's Avatar
ayos.
anong racing attire? complete with crash helmet ba?
rough512 is offline
Old 07-30-2007, 01:23 AM
  #17428
Classes:
Regulations:
-TEU ESC only
-Any 4WD EP chassis
Open Modified Class
-Any 4WD EP chassis
layout to follow
Yan OK. I'll not miss this race for sure. Count me in, malamang as open mod
Old 07-30-2007, 01:38 AM
  #17429
alecladanga's Avatar
Originally Posted by rough512
ayos.
rough, di pwede crash helmet, panty o kaya bra na lang sa ulo
see you guys on the 11th
alecladanga is offline
Old 07-30-2007, 03:29 AM
  #17430
|JayFlores|2's Avatar
Trader Rating: 16 (100%+)
Rnold/Oldskul: count me in. thanks for the announcement.
tantalus/toink: ndi pala totoo nangyari sakin. did a motor run yesterday and its good. brushes lang pala. next time ndi na ako magsalita sa huling takbo.
|JayFlores|2 is offline
