Go Back  R/C Tech Forums > International Forums > Manila Racers
Electric Touring / On-Road RC >
Like Tree1Likes
Old 07-27-2007, 03:12 AM
  #17401
Mini Toink's Avatar
Trader Rating: 30 (97%+)
Originally Posted by Miguel
mukhang matinding technological advancements na ang nagaganap ah...sarap siguro ng lipo/BL...
kainggit naman...bka dalaw ako tom sa race mga sirs, goodluck sa lahat!!!
Wag ng padalaw-dalaw...maglaro na kasi!
See you tomorrow
Toink
Mini Toink is offline
Old 07-27-2007, 05:07 AM
  #17402
Lewd Skywalker's Avatar
Trader Rating: 14 (100%+)
Originally Posted by Xanavi_R34
oh okay... thanks... can I just give the specs of the lipo batt and the swallow charger and tell me any inputs or comments about them...
LIPO BATT: ung 4800 orion
SPECS: Length: 5.4" (137.5mm)
Width: 1.8" (45mm)
Height: .91" (23mm)
Weight: 10oz (285g)
Number of Cells: 2 cells in a 2S2P
Capacity: 4800mAh
Charge rate: 1C (4.8A)
Cutoff voltage: 2.7V per cell
Output voltage: 7.4V nominal
Continuous current: 15C=72A
Peak current: 30C=144A for 10 seconds
SWALLOW CHARGER: advance
Input Voltage 11-15V DC
Battery Type NiMH / NiCad / SLA / Li-Ion
Charge Mode NiMH/NiCad Charge/Discharge/Cycle
Charge Mode SLA/Li-Ion Charge/Discharge
Battery Cells NiMH/NiCad 1-14 Cells (1.2V-16.8V)
Battery Cells Li-Ion 1-5 Cells (3.4V-17.0V)
SLA 2/4/6/8/10/12 V Packs
Charge Current (ALL) 0.1-5.0A (100mA Steps)
Discharge Current (ALL) 10-1.0mA (10mA Steps)
Trickle Charge (ALL) 0-200mA
Diameter/Width 84mm
Height 23mm
Length/Breadth/Depth 117mm
Weight 370g
sir walang problema yang Swallow Advance charger mo. Just charge in Li-Ion/Poly mode, set mo to 2 cell (7.4V pack) and 4A charge rate. Just make sure yung settings and you'll have no problem with that charger. I'm using one also.
Guys, yung 4800 pack doesn't recommend charging more than 4A! Goodluck ha, di kami nananakot... we're just telling facts hehe
Lewd Skywalker is offline
Old 07-27-2007, 05:24 AM
  #17403
VooDooPH's Avatar
Trader Rating: 18 (100%+)
thought the recommended charging rate was 1C? so dapat 4.8A?
VooDooPH is offline
Old 07-27-2007, 05:46 AM
  #17404
Xanavi_R34's Avatar
maybe just to be safe...
Hey guys, thanks for your help, will do tell if what will happen... hehehe...
Xanavi_R34 is offline
Old 07-27-2007, 06:32 AM
  #17405
|JayFlores|2's Avatar
Trader Rating: 16 (100%+)
oh yes! astig usapan dito li-po racing na. kahit nimh parin ang pambato... see you all tom. salamat sabado na.. hehehhe
|JayFlores|2 is offline
Old 07-27-2007, 07:57 AM
  #17406
Trader Rating: 32 (100%+)
for TURBO 35 GFX users:
GFX LIPO UPDATE NOW AVAILABLE
The Turbo 35 GFX has been updated to include Lipo battery charging and discharging while still retaining the Nimh/Nicd operation.
-The program update is available for all GFX units as an upgrade. The unit must be sent back to our facility for reprogramming.
-Cost for the update is $50.00 plus shipping. We prefer to call you when it is done for payment. Visa/Matercard accepted.
-Units will also be tested for calibration and operation.
-A seven page addendum to the operating manual is included, please read it carefully before using the unit. You may also download it on tab below.
-Turn around time is approximately one week.
http://www.competitionelectronics.co...fx_update.html
also:
LIPO UPDATE FOR THE TURBO 35, TURBO 35BL, TURBO35BL STEALTH
TURBO 35 LIPO UPDATE COMING SOON-
Check back soon for availability. Your T35 unit will be upgradable to charge and discharge Lipo batteries while still retaining the Nimh/Nicd operation.
-Estimated release date is 10-07.
-Units must be sent back to our facility for the update.
-Estimated cost for the update is $50.00 plus shipping.
File Type: pdf
Rnold is offline
Old 07-28-2007, 05:27 AM
  #17407
VooDooPH's Avatar
hope somebody can bring this in...
could be better since no further modifications are needed, unlike the orion balancer.
VooDooPH is offline
Old 07-28-2007, 06:11 AM
  #17408
Trader Rating: 82 (100%+)
another touring car in the works centered battery, triple belt
team magic ...
Attached Thumbnails Electric Touring / On-Road RC-img_0520.jpg   Electric Touring / On-Road RC-img_0517.jpg   Electric Touring / On-Road RC-img_0521.jpg   Electric Touring / On-Road RC-img_0510.jpg
marvi is offline
Old 07-28-2007, 07:32 AM
  #17409
yan_1700's Avatar
Default pitbull
hi to all...
just need some information about my pitbull charger(blue/version 1)...
i have a battery holder(for AA) with 2100mah 8 pcs sanyo AA batts, i wanna charge this with pitbull.. but when i charge it...the pitbull says LO AMPS or LO VOLTS
whats the problem?
ano po dapat gawin?
thanks...
yan_1700 is offline
Old 07-28-2007, 07:46 AM
  #17410
porshaa's Avatar
Default help in cycle settings
i want to use my cellmaster to cycle my intellect 4200 and 3600 batts. what should my settings be?
on ctx charge? what should be what?
porshaa is offline
  #17411
Sorry medyo late na ito, napansin ko lang sa gilid nung 4800 pack, DO NOT CHARGE MORE THAN 4 AMPS
Sabado na nga, sarap! Kahit di natuloy karera. Sulit yung punta natin. Next time EP practice sessions weekends (pag walang race), we'll talk more on this soon. Abangan...
team magic ...
Pre bakit yung mga EP chassis ngayon nagmumukhang nitro na (side belts) hehe
Old 07-28-2007, 09:26 AM
  #17412
lewd: thanks for the food good thing rin at up and running na ang novak GTB/4.5r combo mo! setup pa sa JRXS-R atleast box stock feel mo na. see you soon
....oh men lahat ata were charging 4.8?
Old 07-28-2007, 05:18 PM
  #17413
Jay: Welcome pre. Sa uulitin, basta ba ganun kabait ang mga manufacturer ng equipment natin eh, laging may free food sa tracks Sino susunod?
Toink: Salamat sa set-up tools at sa tips. Pasensya na sabi ko sa'yo newbie eh. Dati camber, caster at toe lang ginagalaw ko sa oto ko eh Ride height? basta walang gasgas sa chassis OK na yun
Robo: Thanks sa set-up tips. Ngayon ko na na-appreciate yung combination ng BL at LiPo. As I said, mas matulin talaga yung LiPO vs. NiMH 'coz of the weight. Pag may winglets yung body pwede nang lumipad haha Set-up pa'ko for mod, will maintain this car for mod wala ng tanggalan
Old 07-28-2007, 10:26 PM
  #17414
Originally Posted by yan_1700
hi to all...
whats the problem?
ano po dapat gawin?
thanks...
charge at 0.8-1.5amps this will be the only ideal charge rate for AA 8cells config because if you will increase the charge rate the power supply will have a hard time supplying the right voltage for the charger being used and with regards to your delta peak start with .03mv, that's what i do with my AA tx pack before.
temp cut off - 50degC
6cells
5.0amps
03mv
i always use linear charge with my batts. (4200 and 3600)
Old 07-28-2007, 10:38 PM
  #17415
Mini Toink's Avatar
No problem pare anytime basta ba sama mo na yung engine at electronics eh
Dapat siguro kay ROBO ka tanong ng setup...baka mali pa masabi ko sayo eh
Ride Height mga 8 para sure walang gasgas...pede pa sa mga jump jump yan
Thanks sa lunch pare!
Toink
P.S. Thanks Charlie!!! :P
