Go Back  R/C Tech Forums > International Forums > Manila Racers
Electric Touring / On-Road RC >
Like Tree1Likes
Old 07-26-2007, 04:40 AM
  #17371
Big Daddy Cool's Avatar
Trader Rating: 15 (100%+)
robo/lewd: Promise, susubukan ko na talaga makalaro sa JP. Kahit once in a blue moon.
madda: di pwede..... gamit ko pang cycle eh. hahaha
Big Daddy Cool is offline
Old 07-26-2007, 04:52 AM
  #17372
Mini Toink's Avatar
Trader Rating: 30 (97%+)
Originally Posted by |JayFlores|2
toink: masama ata balak mo ah? musta na sa gngawa mo? hehehe
Wala naman akong balak na masama...gusto ko lang mag laro...kating kati na kaya!
Oks naman...bukas ko na tapusin, friday na ba?
Toink
Mini Toink is offline
Old 07-26-2007, 05:11 AM
  #17373
|JayFlores|2's Avatar
Trader Rating: 16 (100%+)
Toink
hehehe sakto friday night mo bigyan yan. para mabuhayan. sige kita-kits sa sabado. tagal nga eh..
|JayFlores|2 is offline
Old 07-26-2007, 07:04 AM
  #17374
Trader Rating: 32 (100%+)
sige kita-kits sa sabado(
inggit ako
pahinga muna sandali... mga pangbahay na gawain muna ako this weekend enjoy the races and goodluck to all
Rnold is offline
Old 07-26-2007, 04:39 PM
  #17375
Anyone know if Duratrax ICE charger is available locally? Saan kaya? Thanks.
Old 07-26-2007, 05:52 PM
  #17376
ROBORAT's Avatar
uuuuuy .... mag la-lipo! hehehe ... but unfortunately no its not available locally. i believe pitshop will have some of the yokomo chargers come in which are actually re-badged ICE's. in short, iba lang kulay at sticker!
gawa tayo dyna run/acto power class! imbitahin natin si doc robbie, si dale, si bobet, at si ronchie! hahahaha ....
ROBORAT is offline
Old 07-26-2007, 06:25 PM
  #17377
Trader Rating: 82 (100%+)
robo: mas sosy pa ng konti yung yoke version, naka backlight na (not avail sa ice) and may included temp probe (optional sa ice)
bdc: magandang version ng ice, yung checkpoint charger, 20 amps linear discharge (30 amp pulse yata) compared sa 10 amps sa standard ice. saka mas mataas pa ang amp rating for the motor run feature of brushed motors i think pwede rin to mag 2C charging sa lipo, para mas mabilis mag charge at para mas mabilis din masugak, bwahahaha si bmmer naka ganito, kunin natin sa pit table nya pag nakalingat
punta ka HK, hanap ka dun ng lipo charger pero text ka muna bago ka umalis ha
isa pang ok na lipo charger yung orion flight advantage, $80 lang. tamang tama to sa lipo but medyo bitin for nimh or nicad kasi 5 amps ang max charge rate
marvi is offline
Old 07-26-2007, 06:34 PM
  #17378
ROBORAT's Avatar
Here's a post i came accross on in one of the htreads here. Pretty well said and puts the whole LiPo thing in perspective. In short, there is no advantage to LiPo over NiMh in terms of power output - in fact in certain instances (like stock as already mentioned before), NiMh still has a slight edge.
"NiMH packs peak out at 9+ volts, and LiPo stops at 8.4. LiPo batteries hold their voltage under load much better, but stock racing doesn't seem to create enough load to make a difference, so NiMH has a slight edge in stock. It's not huge, but it's there. It begins to matter a lot less in faster classes like mod, or if minimum weight rules are revised.
For me, competitive as I am, I'd still rather use LiPo, and try to make up for it with driving and setup......"
with more and more bog name manufacturers (even Losi and Schumacher are releasing their own packs) coming into the LiPo arena, this is a testament to them realizing its going to happen and they are embrasing the technology given its benefits to rc and racing in general.
that being said, karrera na!!! see you guys tomorrow at the track!
ROBORAT is offline
Old 07-26-2007, 06:53 PM
  #17379
Swift and Sleek's Avatar
Smile SAN KAYA AVAILABLE TO LOCALLY?
OR ANYSUGGESTIONS FOR A HIGH QUALITY ESC'S
Attached Thumbnails Electric Touring / On-Road RC-vfs-2.gif
Swift and Sleek is offline
Old 07-26-2007, 07:04 PM
  #17380
Lewd Skywalker's Avatar
Trader Rating: 14 (100%+)
Pinaka advantage lang sana is WEIGHT kung hindi masyado yung higher voltage output. Pero I see in regulated races na kailangan may minimum weight requirements so bale wala din. Sa R/C flight yun ang pinaka advantage ng Lipo over other battery types.
Maganda yan, dami magla-lipo... makakakita na tayo ng sumasabog sa pit, pag nagbanggaan dalawang kotse masusunog hehehe...
Lewd Skywalker is offline
Old 07-26-2007, 07:19 PM
  #17381
tantalus007's Avatar
Trader Rating: 17 (100%+)
talaga lang ah... makikita natin yan tom...
Toink
kung anu-ano kasi tinuturo mo kay toink...
wala namang takutan...
see you guys tom with your new BL's, lipos, brushed mod motors and matched packs...
tantalus007 is offline
Old 07-26-2007, 08:06 PM
  #17382
marvi/lewd/robo: Saan ba nakakabili ng used ammo boxes? Yun daw ang magandang storage case ng lipo. Para kahit natutulog ka sa gabi, di ka magworry na masunog bahay mo kung mag-act-up siya. Hehehe.
Robo: Naku, malalabo na mga mata ng matatandang yun! kidding!
Old 07-26-2007, 08:12 PM
  #17383
ROBORAT's Avatar
hehehe ... yan ang pag iisip na nakaka sagabal sa pag accept sa lipo. lithium polymer and lithium ion cells are used in other applications such as your avreage cellphone. di naman kayo natatakot na masabugan ng cellphone diba? kahit binabagsak bagsak niyo pa. besides, kaya nga may hard case para at most less prone to combustion since less oxygen to facilitate this. at worst a damaged pack with swell up.
but if you want to be extra safe, those amo cases na dating ginagawang tool box is good. or baka may sentry safes kayo diyan sa bahay, dun niyo nalang i-store kung napapraning kayo.
ROBORAT is offline
Old 07-26-2007, 08:16 PM
  #17384
ROBORAT's Avatar
swift and sleek: try mo action hobbies sa fort. alam ko they have the hara version of that .... pareho lang yun, iba lang casing. 2.1 or 2.2 na ata version nila. not sure, mejo out of the know na ako sa brushed escs ngayon since i went brushless. i would actually suggest na mag brushed/brushelss esc ka na like the Novak GTB or the LRP Sphere. furute proof ka na niyan since you can run any motor with thse escs. just a suggestion for you to consider.
thanks,
Gerry
ROBORAT is offline
Old 07-26-2007, 08:20 PM
  #17385
rough512's Avatar
hehehe ... di naman kayo natatakot na masabugan ng cellphone diba? kahit binabagsak bagsak niyo pa. besides, kaya nga may hard case para at most less prone to combustion since less oxygen to facilitate this.
takot ako sa battery pack ng sony vaio na laptop
rough512 is offline
