Go Back  R/C Tech Forums > International Forums > Manila Racers
Electric Touring / On-Road RC >
Like Tree1Likes
Old 07-18-2007, 08:53 PM
  #17296
Lewd Skywalker's Avatar
Trader Rating: 14 (100%+)
bmmer: thanks sa info Josh. Back to Tekin G9 ESC ako hehe
Robo: Novak told me to return the brushless set, send out to Novak factory. They advised on the symptoms I am getting, the ESC is failing. They requested me to send back the ESC along with the motor so they can check and replace with a new set, free of charge. Sagot ko nga lang shipping. Its good the really have this superb service. Buti na lang kilala pa din ako ni Charlie at Steve Weiss as matagal ko na kausap sila since I started using Novak 410-M1 and Digi-Peak about 15 years ago
Lewd Skywalker is offline
Old 07-18-2007, 09:10 PM
  #17297
rough512's Avatar
Okay yan sir lewd, bumawi ang novak sa service nila.
oo nga pala roborat, may nabasa ako dati dun sa electric forum na may promo yata ang novak. Pwede mong i-swap yung GTB mo for a spektrum-optimized esc, free of charge. Baka pwede mo nang isabay yung sa iyo. Sabi nila less prone to overheating yung spektrum version kasi mas mataas yung swithching rate nila.
rough512 is offline
Old 07-18-2007, 10:25 PM
  #17298
tantalus007's Avatar
Trader Rating: 17 (100%+)
robo: post mo na rin kung pano gumawa ng losi multi-diff...
lewd: konting tiis while your BL is away... balik brushed na muna...
tantalus007 is offline
Old 07-18-2007, 10:45 PM
  #17299
Originally Posted by ROBORAT
lapit na yan dumating!
Asa ka pa
JPRacing is offline
Old 07-19-2007, 01:10 AM
  #17300
Naku sir, wag niyo na ipadala unless kay Pitshop niyo pwede ipakisuyo (kung willing kayo maghintay). I sent out my BL set to Novak USA kanina, ang shipping charges (GDA) is P1,700 3-day delivery and tracked. Ang MAHAL!!! Pag UPS or FEDEX or DHL, P2k. Grabe!
Bmmer: Dapat yata I just bought a bnew LRP. Kakainis talaga electronics...
Tanta: Sige makikipa-cut na lang ako ng comm kung sino good soul meron dyan lathe. Hassle free ang BL kapag swerte ka, pag malas... ayan...
Old 07-19-2007, 07:21 AM
  #17301
Good day, i have a quick esc question, what's the difference, advantage and disadvantages of lowering/increasing esc drive frequency? i've noticed that at some frequency my motor would run cooler with less arcing and better top speed , and a total opposite with a different setting,
imel24 is offline
Old 07-19-2007, 09:18 AM
  #17302
mitch, miguel: kamusta mga ninja training sessions nio??? black belter na ba and matching black ninjas na ba kayo...
lewd: hintay ka na lang na bumalik yung bnew BL mo... for the meantime, ikot-ikot ka lang sa tracks... maraming kang mahahanap na merong good soul...
imel24: the higher the number (frequency), more run time, efficiency, less punch... the lower the number (frequency), less run time, less efficiency, more punch and more wear on your motor... when setting your esc look for these things; com wear, brush wear and run time... discoloration in the com and brushes is a result of too low a setting in the drive frequyency, wrong timing, or wrong brush set up... hth's...
Old 07-19-2007, 10:51 AM
  #17303
Mini Toink's Avatar
Trader Rating: 30 (97%+)
Ayun, hindi pa black belter...under training pa rin.
Lewd: Marami nga good soul dyan... Pero ingat ka din minsan meron dyan ligaw na soul
Toink
Mini Toink is offline
Old 07-19-2007, 08:18 PM
  #17304
|JayFlores|2's Avatar
Trader Rating: 16 (100%+)
imel sakto sabi ni tantalus but 1st things 1st get the right final drive ratio of your motor. the car should get the top end before you end the back straight of the racetrack. then play with your esc to get most out of your motor.
anyway, what motor are you using? if that is a stock motor(27t or 23t) and the final ratio is right no matter how you lower the drive frequency it should still burn good. This is the way i do it because with todays current cells efficiency isnt a problem anymore
hth's
|JayFlores|2 is offline
Old 07-19-2007, 08:24 PM
  #17305
Miguel's Avatar
Ayun nga, under training pa..onti pang unat tom...
Miguel is offline
Old 07-19-2007, 09:18 PM
  #17306
Trader Rating: 28 (100%+)
mitch: ligaw na soul? o ligaw na (masamang) damo? naku ang dami dyan
joji_say is offline
Old 07-20-2007, 05:59 AM
  #17307
toink/joji: ligaw? na soul?.. teka nag exist ba?
Old 07-20-2007, 07:46 AM
  #17308
Mini Toink's Avatar
Madami nga kaya ingat mga kapatid!
exist? hmmm... madaming existing stories kasi... does that count as existing??
Ready na ba mga EP peeps for July 28th race?? Tagal!!!!!
Toink
Old 07-20-2007, 08:17 AM
  #17309
toink: ewan. wahaha nakaka praning pagusapan. anyway, im all good basta karrera. btw, YGPM
tantalus: kamusta bisita mo? ganda nung black anodized case..
Old 07-20-2007, 08:43 AM
  #17310
Mini Toink's Avatar
Actually nakakatakot nga talaga... oh well papel! Karera na!!!
Kayong dalawa bumisita ah...hmmm...kamusta shopping?
Black anodized case? Ganda nga! Si tanta daming tinuturo kanina Pati yung mga nasaitaas ng stante pinaghihimas pa! Pero walang inuwi
Toink
