Go Back  R/C Tech Forums > International Forums > Manila Racers
Electric Touring / On-Road RC >
Like Tree1Likes
Old 07-17-2007, 03:10 AM
  #17281
Alfonso_R's Avatar
sorry to the lue car that i hit last sat i dint notice it eh
nice race sat
Alfonso_R is offline
Old 07-17-2007, 08:48 AM
  #17282
Trader Rating: 32 (100%+)
10TH TAMIYA ASIA CUP, The Philippine Qualifiers 2007
JP Raceway Track Layout
NOTE: Race Track Layout will only be available on July 22 starting at 8:00AM
Rnold is offline
Old 07-17-2007, 02:23 PM
  #17283
Lewd Skywalker's Avatar
Trader Rating: 14 (100%+)
Ask ko lang po mga sirs ano FDR for the Tamiya 23T RZ motor? Thanks
Lewd Skywalker is offline
Old 07-17-2007, 07:39 PM
  #17284
FYI to all electric racers who want to practice on sat. There will be a nitro race on saturday.
JPRacing is offline
Old 07-17-2007, 07:41 PM
  #17285
highwayman's Avatar
Originally Posted by Mr. Shims
Guys theoritcal advice need help, let's say all you can adjust is ride height toe in/out and dampening...
what is the first to adjust? and whats the set-up for better exit speed, meaning more stable into corners needing to take out understeer. I'm trying to figure out old set up sheets and ive really drawn a blank. thank you any advice would be greatly appreciated.
for better exit speed and understeer --- i'd reduce rear toe-in first
for a bit more steering --- i'd raise the rear ride height a bit (.5mm increments)
assuming we're using 17lbs spring sa harap and maybe 14lbs sa likod and 40wt all-around, going to 45wt would also give better corner speed on long sweeping tracks.
hope this helps, and if im wrong, i hope the guys will correct me...
BTW, played with jayps last night, you guys thinkin of playing again?
highwayman is offline
Old 07-17-2007, 08:12 PM
  #17286
bmmer701's Avatar
Trader Rating: 17 (100%+)
not sure sa iba pero geared mine at 6.4 and 6.25 and 6.01 (isang run nga lang hehe) depende sa track layout. last time 6.42 gamit ko
bmmer701 is offline
Old 07-17-2007, 09:29 PM
  #17287
tantalus007's Avatar
bradir longtime Kamusta everybody?
whats up!?!?!? kelan balik nio sa rc scene??? rc na ulit!!!
as for you setup q's... i think highwayman has covered it all... total noob pa rin ako pagdating sa mga ganian...
tantalus007 is offline
Old 07-18-2007, 01:02 AM
  #17288
Good day, another setup question, whats are the effects of increasing and decreasing ride height? are there any alternative methods on how to measure ride height like using rulers maybe or coins?
imel24 is offline
Old 07-18-2007, 01:25 AM
  #17289
VooDooPH's Avatar
Trader Rating: 18 (100%+)
when i didn't have set-up gauges yet, i used 2 spurs stacked on top of each other to measure my ride height. hehehehehe.
for set-up tips, this might help:
http://www.teamxray.com/teamxray/sho...p?file_id=2525
VooDooPH is offline
Old 07-18-2007, 01:42 AM
  #17290
Mr. Shims's Avatar
My cousin is thinking of getting into the hobby and i suddenly reached a blank when the topic of set-ups came up i'll definitely have a little more time come august and if there's a chance that i can run a pack and see kung kaya pa maybe i can play (afford) it again see you guys soon!
Highway: Yeah wasnt able to pass by last nyt but august i'll be a regular (tuesdays)
Mr. Shims is offline
Old 07-18-2007, 03:12 AM
  #17291
Trader Rating: 82 (100%+)
robo, joji, etc: for your jrxs type R when using lipo ...
JRX-S Type-R Steel LiPo Battery Tray-LOSA4312
· Allows existing JRX-S Type R owners a direct fit option for standard LiPo battery packs
· Adds an additional 120 grams to offset the reduced LiPo battery weight
· The additional weight is place in the most ideal position possible ( placed directly in the center of the chassis and as low to the ground as possible
· Finished in an attractive gloss black and engraved with the Type-R logo
... very nice
Attached Thumbnails Electric Touring / On-Road RC-typertraybottom.jpg
marvi is offline
Old 07-18-2007, 06:07 AM
  #17292
ROBORAT's Avatar
marvi: yup! been waiting for the release of that weighted tray, finally out na. now question is how to get my hands on them! hahaha ... and some lipo packs too!
mga chopeto boys! balik rc na kasi!
ROBORAT is offline
Old 07-18-2007, 06:23 AM
  #17293
ROBORAT's Avatar
another tip for the losi boys who dont have access to the different spring tensions needed for asphalt racing ....
all you'll need is the ae shock retainers and your should be able to use longer shock springs like those from ae, rayspeed, and xray....
ROBORAT is offline
Old 07-18-2007, 07:01 AM
  #17294
Im glad I dont have that problem anymore
JPRacing is offline
Old 07-18-2007, 05:11 PM
  #17295
ROBORAT's Avatar
lapit na yan dumating! EP na!
ROBORAT is offline
