Go Back  R/C Tech Forums > International Forums > Manila Racers
Electric Touring / On-Road RC >
Like Tree1Likes
Old 07-10-2007, 09:41 PM
  #17206
xfire's Avatar
Trader Rating: 24 (100%+)
Originally Posted by |JayFlores|2
yes there is. too bad yan ang hindi ko na alam. anyway, i always charge my race packs at 5amp only and i find it sufficient for both modified and stock
i think meron thread sa international onroad section regarding the formulas.
I did research and found a battery charger calculator. Hope this would help others as well.
http://www.greenbatteries.com/batterycalc.html
xfire is offline
Old 07-10-2007, 09:49 PM
  #17207
tantalus007's Avatar
Trader Rating: 17 (100%+)
jay: ok pa naman yung kit ko... saka na lang ako magconvert kapag may mangyaring masama... pero tempting yung conversion mo...
bmmer: masaya kasi sa 27t...
voodoo: 4.5r na this coming sat!!!
tantalus007 is offline
Old 07-10-2007, 09:55 PM
  #17208
|JayFlores|2's Avatar
Trader Rating: 16 (100%+)
tantalus: makikita natin sa sabado kung okay kakaexcite cause bagong istura ng BD haha. I started with my old setup again and adjust from it.
xfire: ayt.
wednesday palang..
|JayFlores|2 is offline
Old 07-10-2007, 11:05 PM
  #17209
Mini Toink's Avatar
Trader Rating: 30 (97%+)
Anong conversion yan?! hmmm???
Wag mo batiin baka may mangyari ngang masama
Toink
Mini Toink is offline
Old 07-10-2007, 11:06 PM
  #17210
Mini Toink's Avatar
Originally Posted by bmmer701
talaga mag 27t ka? hmmm... bakit kaya....
wala pa din yung box
Puro kayo mag 27t ah! Ayaw nyo mod? Speeeed!!!
Box? Anong box yan? JukeBOX?
Toink
Old 07-10-2007, 11:20 PM
  #17211
VooDooPH's Avatar
Trader Rating: 18 (100%+)
josh/voodoo: salpak niyo na mga 4.5 nyo! hehehe
jay:
hahahaha! bahala na si batman! takot pa ako sa mod! medyo natrauma ata nung last mod race! if ever, kitakits sa 27T!
VooDooPH is offline
Old 07-10-2007, 11:51 PM
  #17212
Lewd Skywalker's Avatar
Trader Rating: 14 (100%+)
Toink
Meron ako conversion para sa iyo. Convert TC racer -> heli flyer
Lewd Skywalker is offline
Old 07-11-2007, 12:01 AM
  #17213
Originally Posted by xfire
Is there a formula for computing the charge time? My EXPRO II has a max charge of 5.5A only. Thanks.
eto sir alam ko:
time = capacity / charge rate
where:
time - in hour(s)
capacity - battery capacity in milliampere-hours (mAh); i.e. 3600mAh
charge rate - charger charging rate in milliamperes (mA); i.e. 5.5A = 5500mA
time = 3600mAh/5500mA = 0.655 hours, convert mo to minutes so x 60 = 39.3 minutes.
experts, tama ba ito hehe.
Old 07-11-2007, 12:17 AM
  #17214
bmmer701's Avatar
Toink
haha ok na mod na this sat tagal ng sat hehe...
bmmer701 is offline
Old 07-11-2007, 12:51 AM
  #17215
rough512's Avatar
Originally Posted by Lewd Skywalker
eto sir alam ko:
where:
time - in hour(s)
Sir lewd okay na yung formula nyo pero dagdagan pa natin ng 40 percent.
time = 1.4*capacity / charge rate
Xfire : not familiar with your charger. If it does not do peak detect, better buy a decent peak-detecting charger. Mahal ang battery pack
rough512 is offline
Old 07-11-2007, 01:41 AM
  #17216
xfire's Avatar
Using this link: http://www.greenbatteries.com/batterycalc.html , a 3600mAh charged on 5500mA came out as 0.8 hours or 48 mins. I'd assume that there is +/- 10% variance in minutes.
I'm using a TLP - Expro II
Feartures:
1) Charging 3000 Ni-MH Batteries at up to 5.5A
2) Charge 4-8 Cells at 0.5A - 5.5A
3) Peak Detector smart circuit with MOSFET pulse For Ni-cad or Ni-MH to 100% without overcharging
4) Lightweight Power-Switching technology unit and smart compact case design
5) Reverse Polarity protection system
6) Auto detect system for input source: 200V AC or 12V car battery
7) Discharging current is 4A, built-in cooling fan
8) Latest software for peak charge, discharge, FUZZY LOGIC and three cycles functions.
Is the above specs sufficient?
I'm new to NI-MH. Came from NI-CDs. Didn't know that time calculations are needed for charging.
xfire is offline
Old 07-11-2007, 03:01 AM
  #17217
rough: thanks pare sorry I sorted the formula out based on theoretical linear charging lang (that is saktong 3600mAh yung capacity). tama there's additional time to consider since most batteries are underrated i.e. the 3600mAh pack could accept charge as much as 4000mAh. a 2400mAh nicd pack could sometimes accept upto 2800, yung IB4200 ko charges about 4500mAh kapag sobrang depleted. thanks again bro.
Old 07-11-2007, 03:07 AM
  #17218
Alfonso_R's Avatar
Not sure of what pinion size used in 105 spur but CO27 motors usually runs good on an 6.4 to 6.6 FDR
Hope that helps. See you saturday!
Toink
Originally Posted by Xanavi_R34
alfonso R.
37t pinion ang kelangan mo para makuha ang 6.4 FDR... pero actually 6.38 sya, but if you round it off, 6.4 na sya...
HTH's
oh ok guys thx 4 the tip
see u guys on sat
Alfonso_R is offline
Old 07-11-2007, 07:05 AM
  #17219
highwayman's Avatar
what layout are we using this saturday?
highwayman is offline
Old 07-11-2007, 07:13 AM
  #17220
jay: old setup??? pwede ko ba gamitin yung setup mo nung last race... minus the trailing edge...
toink: ok yung idea ni lewd... magandang conversion yun para sayo...
bmmer: dumating na yung box of goodies mo???
highwayman:
good question... sana old ep layout ang gamitin... yung ginamit nung clash for cebu races ni pitshop...
