Go Back  R/C Tech Forums > International Forums > Manila Racers
Electric Touring / On-Road RC >
Like Tree1Likes
Old 06-10-2007, 07:31 PM
  #16816
Mini Toink's Avatar
Trader Rating: 30 (97%+)
Originally Posted by VooDooPH
SPECS: Length: 5.4" (137.5mm)
Width: 1.8" (45mm)
Height: .91" (23mm)
Weight: 10oz (285g)
Number of Cells: 2
Capacity: 3200mAh
Charge rate: 1C (4.8 amps)
Cutoff voltage: 2.7 volts per cell
Output voltage: 7.4 volts nominal
TOWER HOBBIES PRICE: $84.99
Width: 1.8" (45mm)
Height: .91" (23mm)
Weight: 10oz (285g)
Number of Cells: 2
Capacity: 3200mAh
TOWER HOBBIES PRICE: $89.99
what's the diff?
The price?
Toink
Mini Toink is offline
Old 06-10-2007, 07:36 PM
  #16817
babytoy101's Avatar
Width: 1.8" (45mm)
Height: .91" (23mm)
Weight: 10oz (285g)
Number of Cells: 2
Capacity: 3200mAh
Width: 1.8" (45mm)
Height: .91" (23mm)
Weight: 10oz (285g)
Number of Cells: 2
Capacity: 3200mAh
what's the diff?
kulay ng label.....
babytoy101 is offline
Old 06-10-2007, 08:02 PM
  #16818
Trader Rating: 82 (100%+)
lewd: ilan mm yung sobra sa height? what if tanggalin mo yung lower batt tray, tapos i-strapping tape mo yung batt sa upper deck? then lagyan mo ng 3M tape yung ilalim ng batt para wag mag scrape?
yung orion platinum pa lang ang nagagamit ko
voodoo: same battery yan, different labels lang
also, yung nasa charge rate niya, dapat 1C (3.2amps), not 4.8amps. yung 4.8 amps pang 4800mah mag 4800 ka na, baka bitin yan sa low turn mod
marvi is offline
Old 06-11-2007, 03:02 AM
  #16819
|JayFlores|2's Avatar
Trader Rating: 16 (100%+)
fred: laro kana ksi ulit dami parin BD boys! and the car is very capable in mod. ayaw ko sa toyota alabang, bali-balita nga tambay raw kayo duon? with the HOT girls..
mitch: dinaga nga ako nun sabado! wahaha thanks again sa motor you should try to use it and feel the SPEED!
tantalus: ayt, heram ulit shims sa last round. kung okay lang
josh: still in need of black grease? ask toink and weinner alam nila san pwede kumuha. unlimited supply pa!!
|JayFlores|2 is offline
Old 06-11-2007, 03:08 AM
  #16820
ROBORAT's Avatar
nice race day as always! good to see old faces back in open mod ... namely Lewd and Rnold. .... and looks like we'll have a new convert from the nitro world too! hehehe ... may paparatzzi pic pa sa baba! huli ka! hahaha
jay: nice one. wel deserved! kaw lang ang consistent sa finishes for the others race of attrition ang kinalabasan! HAHAHA lahat ata ng iba panay dnf! ... tuloy tuloy mo na yan! sa 19T pukpokan ulit!
JP: thanks for the lunch! good to see you at the track. cant wait for your gear to arrive! masaya 'to! hehehe
highwayman/tutoy: natawa ako sa last heat ... isa isa kayo nag laglagan! sa totoo lang, muntik na rin ako! isipin niyo, one lap after the race was over my camber link fell off ... hahaha muntik na rin ako madali! hahah ... at least alam ko na kung ano problema ng auto ko the whole .. yun lang pala yun! di ko kasi na thread lock. tsk tsk tsk ... bobo ko!
tonik: now you know why we rave so much about mod! speeeeeeeeeeeed!!!
lewd: oi! walang doctoran ng my lipo packs ha! as in hangan 2S-1P lang tayo! lumalamang kayo ha! di pa nga legal nag iisip na kayo mag buo ng lipo freak packs! tsk tsk tsk ... sige kayo, baka i-limit ni mang yan sa pre-built packs with clear specs in the packaging ... bili nalang kasi ng orion or peak!
ROBORAT is offline
Old 06-11-2007, 04:42 AM
  #16821
Lewd Skywalker's Avatar
Trader Rating: 14 (100%+)
Width: 1.8" (45mm)
Height: .91" (23mm)
Weight: 10oz (285g)
Number of Cells: 2
Capacity: 3200mAh
Width: 1.8" (45mm)
Height: .91" (23mm)
Weight: 10oz (285g)
Number of Cells: 2
Capacity: 3200mAh
what's the diff?
Pareho lang nga, same manufacturer - KOKAM din. Parang di pwede yan (3200mAh) gamitin sa hot mod motors (BL or not), kung 20C @ 3200mAh thats only around 64A continuous draw, walang punch.
Robo> Just planning to use our old helicopter lipo packs pero dahil low capacity lang (2100s, 3200s,) di kaya ibigay yung current draw ng low-turn motors kaya kailangan i-parallel (2-series 2-parallel) to make 7.4V 4200mAh or 6400mAh which is basically same rating as those pictured above. Medyo mahal kasi yung mga lipo binebenta pang kotse eh. Probably dahil sa hard case needed for protection. Dilikado lang ganitong lipo (no hard case), kapag na hard impact yung oto sasabog na
Marvi> Pwede din siguro, pero kailangan ko itaas ride height ng kotse otherwise mauubos yung lipo at baka sumabog yun habang humaharurot sa back straight hehe. Hari ka pala ng alabang gals ha!
Lewd Skywalker is offline
Old 06-11-2007, 05:54 AM
  #16822
lewd/jay: alabang "girls"
lewd: ganun ba? hehe, kala ko ilang mm lang ang difference. wow, 6400mah, enduro pack yan! pangmatagalan
robo: wala naman doctoran sa lipo as long as 7.4 volts yan, kahit ilang patong patong, capacity lang ang tataas kuha na ng lipo! kung may weight limit sa races, i think maglalabas ang orion ng weighted lipo pack para di na kailangan ng extra ballast im sure sa ilalim ng pack naka concentrate yung weight para lower CG.
marvi is offline
Old 06-11-2007, 06:40 AM
  #16823
ROBORAT's Avatar
lewd: kaya mag ipon nalang para sa lipo made specifically for surface. in the end, before it all becomes legalized, im sure they will all have to conorm to the same spec ... kahit sabihin niyo pang parehong voltage and resulta. and likely, the orion specs will be the basis.... sure bol yan. IFMAR has a tendency to favor big manufacturers who have already invested big amounts in new technology ... isang example diyan is BL. kaya legal ang sensored systems kasi the two big names in surface electronics focused on sensored systems - LRP and Novak. .... sayang, yung 2K na ginastos mo sa motor, pang dagdag mo na sana sa lipo packs! hehehe joke! you are in a good position since you are just getting back into on-road. kami napa gastos na sa old school equipment, at least ikaw pwede ka na mag invest in the future proof equipment. kaya spend wisely kapatid!
marvi: di mo na kami kelangan i-convince! actually kaya nga napag uusapan ang lipo kasi nag agree na si pitshop gumawa ng lipo class. kaya wala ka nang excuse na di maglaro ng on-road. pero im sure, next excuse mo is ... "ay sabado? di ba pwedeng sunday and karrera?" .... hehehe nakikita ko na! ... pero tama ka about the weighted orion packs. meron din lalabas na weighted battery tray ang losi para magamit pa rin ang current orion packs with no problem.
ROBORAT is offline
Old 06-11-2007, 06:51 AM
  #16824
robo: nga pala, if there will be a lipo class (separate from the 6-cell nimh/nicad class, right?), shouldnt the weight limit be lower to take advantage of the lighter batt?
naunahan mo ako sa excuse ko pero magta-tag-ulan na, goodbye muna sa outdoor race
marvi is offline
Old 06-11-2007, 07:09 AM
  #16825
tantalus007's Avatar
Trader Rating: 17 (100%+)
josh: naka-chamba uli spurs mo... babawi ang cavs... d ko lang alam kung kelan... nakakuha ka na ng greedy black grease??? kapag wala... may kilala ako na unlimited supplier at importer...
jay: sure... alang problema sa shims... use them as long as you want...
lewd: baka alabang ghouls...
robo: may lakad kasi si marvi kapag saturdays... kasama nia mga alabang "girls" nia...
tantalus007 is offline
Old 06-11-2007, 08:27 AM
  #16826
VooDooPH's Avatar
Trader Rating: 18 (100%+)
ngek! ganun pala yun. kala ko pwede na yung 3200 sa BL. hehehehehe!
oh well... ipon ipon pa rin.
VooDooPH is offline
Old 06-11-2007, 05:33 PM
  #16827
pre pag sobrang gaan na ng kotse, pag nilagyan ng winglets yan pwede nang lumipad off-road!
robo> for the meantime wala pang ipon, testing muna ng lipo using old packs... wag lang sana masunog habang nasa kotse hehe. emphasize pa din natin sa future users ng lipo - SAFETY. sobrang daming incidents na sa US (at dito) about lipo danger. madami nasunugan ng bahay, kotse at model ng dahil sa improper use ng lipo. di kasi nagbibigay ng lecture yang sila Vicky Belo at Dr. Calayan tungkol sa lipo eh, sila pa naman ang experts
tanta> sakto!
voodooph> OK yan sa 27 stock at 19T spec or brushless equivalent nila. Pero for MOD, sigurado sugak agad yan mga yan. I saw sa May 2007 magazine ng RC Car Action may mga 8000mAh packs na, pero walang hard case. Forgot the brand eh.
Old 06-11-2007, 06:46 PM
  #16828
Miguel's Avatar
di chamba un...puro bench players na nga pinaglaro panalo parin
Miguel is offline
Old 06-11-2007, 08:08 PM
  #16829
Mini Toink's Avatar
MaxAmps yung brand. I think they have the 4000mah, 6000mah & 8000mah (All 7.4v)
8000mah measures 44mm x 137mm x 26mm mukhang malaki for the current/new kits...marami siguro kailangan tabasin to use this.
6000mah measures 44mm x 137mm x22mm I think this is a perfect fit for current/new kits with low CG.
I maybe wrong...but I hope this helps
Toink
Old 06-11-2007, 08:37 PM
  #16830
ROBORAT's Avatar
lewd: i dont think you'll need 8000mah packs for our purposes. kahit kaya gamitin yung for longer runs, i wouldnt recommend it kasi ang kawawa naman sa ganyan mga electronix natin. sobra iinit with the heat it will generate when running over 5mins. baka sa stock class pwede pa mga 6 mins runs pero i wouldnt want to run more than 5 mins in mod. thremal or sunog katapat natin diyan. oks na yung 4800mah, more than enough na yun! ... pero tama ka ... matawagan nga si belo! hahaha .... ano ba ok na storage for lipo? dapat ata may fire proof box na pinaglalagyan pag nasa bahay! hahahaha ....
marvi: wag na muna natin problemahin ang weight limit siguro. lets just get the class up and running. madali nalang yun pag meron nang quorum sa lipo class ... and tanong is kung mabibilang ka ba namin as part of that quorum? hehehe ... sana pare! tigil mo na yang dirt racing! go speeeeeeeeeed! sayang 3.5 mo! hehehe laro ka na sana soon.
ROBORAT is offline
