Go Back  R/C Tech Forums > International Forums > Manila Racers
Electric Touring / On-Road RC >
Like Tree1Likes
Old 06-03-2007, 12:09 AM
  #16711
tantalus007's Avatar
Trader Rating: 17 (100%+)
Originally Posted by highwayman
hehe... that would be me... wasn't sure about the shock towers...
sorry sir, that wasnt you, what i meant was somebody bought an lcg shock tower by mistake and thought that it would fit the BD... and that would be me... must be the side effects of those san mig lights in our lhs...
hmmmm... secret practice??? wala bang controlled practice with the final layout? hehe...
controlled practice... hhhhmmmmm... that would be nice...
tantalus007 is offline
Old 06-03-2007, 12:46 AM
  #16712
diozxlive's Avatar
Default re
baka me magbebenta naman ng Front shock tower for LCG if nde nyo nagamit just pm me. thanks...
diozxlive is offline
Old 06-03-2007, 05:14 AM
  #16713
|JayFlores|2's Avatar
Trader Rating: 16 (100%+)
pa controlled controlled practice nalang pala ngayon. toink and tanta very high level na yan ng racing. baka ndi natin kayanin si toink lang may kaya.
|JayFlores|2 is offline
Old 06-03-2007, 05:27 AM
  #16714
Mini Toink's Avatar
Trader Rating: 30 (97%+)
Walang practice na nangyari...how I wish makalaro na ako anytime I want. Well, I guess this coming saturday na yung practice and race
Mukhang nag hahanda ka na talaga ah...pasulput-sulput ka na lang
Toink
Mini Toink is offline
Old 06-03-2007, 06:56 AM
  #16715
VooDooPH's Avatar
Trader Rating: 18 (100%+)
Originally Posted by ROBORAT
voodoo: how'd it go pare? ok ba BL? ready to race ka na! woooohoooo!
lewd: kamista jrxs mo? natakbo mo ba?
snaped a dogbone and the grubscrew holding the axle to the dogbone kept loosening up... even after i place thread lock (ung tamiya). also had some glitching problems. when the car was running ok, i was pushing on entry and the tail was too loose on power... wild talaga power ng BL... hahahahaha!
VooDooPH is offline
Old 06-03-2007, 06:58 AM
  #16716
VooDooPH's Avatar
Originally Posted by diozxlive
same na din po sa Yokomo LCG and BD parehas din ba shock towers and dampers nila? thankssss....
dampers are the same.
shock towers are different. if you use the BD shock tower you'd have to file the center piece off the BD shock tower. also, only the top 2 screws will match up with the bulkhead. its either you settle with just 2 screws holding your shock tower, or redrill new holes for the 2 other screws. hths.
VooDooPH is offline
Old 06-03-2007, 07:22 AM
  #16717
Trader Rating: 82 (100%+)
Originally Posted by VooDooPH
... even after i place thread lock (ung tamiya). also had some glitching problems...
bango nung threadlock no? sniffable
marvi is offline
Old 06-03-2007, 08:46 AM
  #16718
ricky_savage's Avatar
Default riaydh rc raceway
curious,
sa wakas may pang alis kati na rin ako d2 sa saudi
Attached Thumbnails Electric Touring / On-Road RC-image-098-.jpg
ricky_savage is offline
Old 06-03-2007, 08:49 AM
  #16719
Lewd Skywalker's Avatar
Trader Rating: 14 (100%+)
Ok na OK pre, sakto yung gearing. Ang tulin pala ng 19 turns??? hehe (nabibilisan na ako, di na kaya ng mata ko... pano pa pag MOD yari). Need to fine tune pa, the Sorex 36Rs needs to be warmed up kasi sa start madali mag-spinout but after some laps kapit na naman... sheeesh, kailangan yata talaga ng traction compound and tire warmers, gastos na naman
Will also change my steering servo (S-3050 sport digital), babaklasin ko muna yung S-9351 dun sa Serpent 710 ko. Will try to feel the difference (if meron). Grabe, kinakalawang na'ko pre hehe.
Marvi, Tommi: Just to really make things clearer, the Futaba HRS receiver WILL WORK with ANALOG servos. Just make sure the transmitter is set to FM mode, this way the HRS receiver will automatically shift to FM (not PCM, not HRS) mod and accept the signal and WORK with the ANALOG, or even with DIGITAL servo (but at slower transmission rate). Sana di kayo naguluhan OK?
Summary:
1. Futaba 3PK + HRS receiver will work with DIGITAL servos, in FM and HRS mode.
2. Futaba 3PK + HRS receiver will work with ANALOG servos, only in FM mode.
3. Futaba 3PK + PCM OR FM receiver will work with both DIGITAL and ANALOG SERVOS, in PCM OR FM mode of transmission.
4. ANALOG and DIGITAL servos wont work on conditions other than that specified above.
Guys, not been around the car hobby shops in Manila for a while. I'm looking for pit bags ba tawag dun? Dati kasi I just use Easy Store to pack my things and car to bring to the tracks. Paki recommend naman brand, which shop and how much. Kung pwede some list I can choose from. Many thanks and see you on Saturday.
Lewd Skywalker is offline
Old 06-03-2007, 08:58 AM
  #16720
Originally Posted by Lewd Skywalker
...Marvi, Tommi: Just to really make things clearer, the Futaba HRS receiver WILL WORK with ANALOG servos. Just make sure the transmitter is set to FM mode, this way the HRS receiver will automatically shift to FM (not PCM, not HRS) mod and accept the signal and WORK with the ANALOG, ...
lewd, pag nagkita tayo ulit, patulong magsetup ng radio sinabi rin sa kin dati ni kennethM na pwede raw mag work yung HRS pag naka FM mode. pero nung sinubukan ko sa kin, hindi gumana hindi ko na sinubukan ulit kasi baka masunog ko yung servo or rx. meron kasi akong analog servo na gusto itry, pero hrs na lang ang receiver ko
re. pit bags, try mo rin yung mga plastic rolling toolboxes, stanley medyo mahal (5k na yata), pero mas mura yung black and dekker, collapsible naman yun kaya kasyang kasya sa trunk
marvi is offline
Old 06-03-2007, 09:21 AM
  #16721
Default fdr
pwede po makitanong na rin...
ano po ba recommended fdr ng B/L set up?
naka mamba 5700 po ako
salamas
Old 06-03-2007, 10:16 AM
  #16722
Centerfire's Avatar
Trader Rating: 6 (88%+)
Minitoink : Bro! Binigay ko na kay Josh kanina yung para sa mga stuffs mo! thanks!
Centerfire is offline
Old 06-03-2007, 10:18 AM
  #16723
Miguel's Avatar
hehehe...parang plastic balloon... sniffable din ang cutix...
Miguel is offline
Old 06-03-2007, 11:15 AM
  #16724
Mini Toink's Avatar
Thanks pare!
Toink
Old 06-03-2007, 03:55 PM
  #16725
Default Help on: hpi r34 3 evo, nmmatay engine. overheat yata
aaa
kulapooot is offline
