Go Back  R/C Tech Forums > International Forums > Manila Racers
Electric Touring / On-Road RC >
Like Tree1Likes
Old 05-25-2004, 08:39 PM
  #1636
Baluga's Avatar
Originally posted by evaa
balugs: did i read your post correctly? ur using sorex 32? wow
as regards tweak, pare in my experience mabilis talaga matweak 414, kaya nga bumigay ako jan, parang masyado siyang pang pro na kotse kasi hindi pwede mabangga or else tweak na.
i tried the kimbrough servo saver and it worked well till after mabenta ko ung kit, naikabit ko pa nga sa losi ko e, nung nabiyak na lang saka ko pinalitan. kung talagang nagloloko pa rin, i have a big servo saver here na ginamit ko sa 414 ko, i can lend it to u, itry mo, pag ok saka mo na bilhin sa akin.
try to stay away from the tamiya servo saver, masyadong mahina un e, also u can try the losi servo saver baka makatul;ong, talian mo lang ng zip tie na malaki para di bumuka.
Evaa & Roborat - Actually yung huling Kapitol race na sinalihan ko, I use type b on both qualifying heat tapos Sorex 32 sa 1st race heat coz it was a lot cooler when the stock race I was in started. In short, my car was more competitive after I switch to Sorex 32. Too bad nagkamali ako and lost a joint cup. Kaya pala lumiliko na yung kotse ko pag nag-aaccelerate.
Actually wala na akong steering issue w/ my 414. Sa 04 ko na experience yung problema sa steering.
Baluga is offline
Old 05-25-2004, 08:42 PM
  #1637
miniracer's Avatar
rough: xray pa rin so far ang pinaka mabait sa 4 na kotse na inenumerate mo, although thats just me, sa iba im sure iba ang sasabihin. im plannin on converting to short arms, konti na lang kulang kong parts, meron ka bang short ram mounts jan na extra? un ung aluminum na putol, kasi pag pillow ball di naman ginagamit yuyn e, let me know lang if you have, bilhin ko na lang sa u.
sir evaa, have you driven a short arm x-ray? curious as they say the short arms make the evo2 more aggressive. just want to compare to a losi xxx-s, since you said the xray is mas mabait sa xxx-s.
miniracer is offline
Old 05-25-2004, 09:09 PM
  #1638
rough512's Avatar
Default Re: Re: Re: Team Gudboys!
Originally posted by Baluga
Pare dinedma nyo naman sobra when I asked for race results. Pati sa txt dinedma nyo rin. Kahapon ko nga lang nalaman kay Rough na mas mataas daw yung qualifying position mo. Di nga lang nya sinabi na magkakatabi lang pala kayong lahat. hehehe
Balugs : Pre.. hindi naman sa dinedma, wala talagang nakakaalam kung anon yung kalalabasan ng race kasi nga inulan kaagad sa qualifying pa lang. Kung titingnan mo yung pinost ni mang, 2 qualifying lang yung valid kasi ang alam ko yung EP stock lang ang nakatatlong qualifying. Dun naman sa results namin, wag ka nang magtaka at tig-iisang DNF kaming tatlo sa 2 qualifying heats heheheh. Gaya ng sabi ni Liit, babawi na lang kami sa suso-nood hehehe
Roborat : thanks for answering my question.
Evaa : Sorry, wala akong nung aluminum na sinasabi mo. Hihintayin ko yung results ng conversion mo. Pa-test drive ha?
rough512 is offline
Old 05-25-2004, 10:00 PM
  #1639
Baluga's Avatar
Default Re: Re: Re: Re: Team Gudboys!
Tuloy na lang natin yung discussion about that topic pagnagkita tayo. Hmmpphh!!! Si babytoy babalitaan na lang tayo kung pwede sya linggo. Baka daw may pasok tao nya.
May continuation pa ba yung race of champion 2? Pwede pa kaya sumali at half the price?
Baluga is offline
Old 05-25-2004, 10:17 PM
  #1640
rough512's Avatar
Yep... may continuation yan based dun sa post ni Mang. Sali ka para sabay-sabay tayo sa likuran ng B-main.
rough512 is offline
Old 05-25-2004, 10:44 PM
  #1641
evaa's Avatar
i will try it on probably on the next race, got the short arm conversion already, ikakabit ko tonight probably.
xray and xxxs, personally mas gus2 ko xray. dont know lang pag nag c hub na rin ako ng suspension.
rough: got the short arm conversion na, hehehe. oks lang nakakuha ako sa action hobs kanina nung alum mounts, sure pwedeng pwede so u can get the feel.
evaa is offline
Old 05-25-2004, 10:58 PM
  #1642
Default thank you!
In behalf of the organizers and sponsors, i would like to thank everybody who joined the race (Race of Champions2) last Saturday. too bad we were not able to finish the race but as what Mang has posted we will be continuing it as agreed upon by the sponsors and organizers ( details to follow) To all those who have prayed for good weather thank you. We were blessed for at least 3/4 of the day with good weather. Thank you Sta. Clara.
To the Bacolod and Cebu boys thank you very much for taking time out to come over and join us. We hope to see you in the continuation of the race.
To our sponsors: Gadgets Magazine, ERG Alcotonic, SMC, Sparadiso, Auto Extreme, Toyota Auto Club of the Philippines, Club Morocco, Crystal Clear, GMA 7, Manila Times, Manila Bulletin, Auto Industriya, Pitshop and Connecticut Speedway - THANK YOU VERY MUCH!!!!! Hope they could sponsor the continuation of the race as well.
Again thank you for making the event a success and a race to look forward to every year - of course without the rain.
Maebelle
maebelle is offline
Old 05-25-2004, 11:20 PM
  #1643
ROBORAT's Avatar
Arrow NEW CGM/SD Parts
pitshop: order ka na nito! lalo na yung blue motor Cam na pang CGM! gotta replace that cast iron version! i-tatak mo na panggalan ko dun!
SD-008HG Heavy Duty Graphite Lower Suspension Arms
SD-340CM Blue Aluminum Motor Cam (CGM)
SD-503G Graphite Ring Gear / Drive Gear Set (for diff.)
SD-643G Graphite Ring Gear / Drive Gear Set (for one way)
ROBORAT is offline
Old 05-25-2004, 11:40 PM
  #1644
Maddafunker's Avatar
Cool
Robo: Mr. Dream Boy, punta ko mamaya. Anong gear ratio mo sa 19T?
Maddafunker is offline
Old 05-26-2004, 12:20 AM
  #1645
chambalero's Avatar
mga bradeer!!!
baka meron dyan may setup para sa rayspeed sd. susugod ako sa kapitolyo para kumarera mamaya hindi ko pa alam setup kasi hindi ko pa napapatakbo ito to those who are using rayspeed springs, what are you using? anyways, wag lang kalimutan isigaw "lapping!!!"
btw, ano nga pala dapat final drive ratio for the chameleon2? Thanks!
chambalero is offline
Old 05-26-2004, 12:31 AM
  #1646
evaa's Avatar
Originally posted by chambalero
mga bradeer!!!
try mo mga 6.5, i used that fdr with my losi dati and it seemed good naman, lots of punch and very good top speed. pero lower, baka masunog na ung motor. buti ka pa makakatakbo
i have the hardware na to install the short arms for my FOC, haaaay, excited na ako.
evaa is offline
Old 05-26-2004, 01:23 AM
  #1647
pitshop's Avatar
Trader Rating: 56 (98%+)
chambs --> nakalimutan ko na yung sa rayspeed. sa cgm white springs all around w/ rayspeed retainers. shock oil 35 f/r 3 hole piston. siguro pwede nang starting point yan for you. You can always play around with yourself, este the shock positions so achieve different levels of traction
pitshop is offline
Old 05-26-2004, 01:49 AM
  #1648
evaa's Avatar
sorry Mang, cant make it to the race today, masyado na pala late magstart e, u know naman layo na bahay ko ngayon. haaaaaaaaaaaaay
saturday ba may race ulit?
evaa is offline
Old 05-26-2004, 06:05 AM
  #1649
Baluga's Avatar
Eksakto 10 driver na pala kayo sa b main. Di na ako pwede pumasok. Sali pa kaya si Elvin sa continuation round? Ako na lang kaya magrerepresent sa kanya. Maganda nga nasa huli eh, I always expect some accidents sa 1st corner. Kaya its better to play safe.
Baluga is offline
Old 05-26-2004, 06:25 PM
  #1650
rough512's Avatar
pwera na lang kung yung nasa Pole position eh beterano ng mod races, with a stock motor that will do good competing in the 19T class.
tayo yung "up and coming racers (from behind the pack)"
WENCY : sorry pre... got your PM kaya lang I have no experience with the GT7...
rough512 is offline
