News @ Mini Z Element
#31
2wd class (MR015 , MR02 , MR03)
Name / Chassis / Robitronic transponder Yes / No.
01) Alex / MR03 / Yes
02) Joe Van Persie / Yes
03) Jay Ramos / Yes
04) Edric Messi / No
05) Jeff / MR015.5 / Yes
06) Khairul / MR03 / Yes
07)FlipKing /03/ yes
08)
09)
10)
F1 (MF010 / MF015) Fun race
01) Alex / MF015 / Yes
02) Jay Van Persie / Yes
03) Jeff / MF010 / Yes
04) Flipking / MF015 / yes
05)
06)
07)
08)
09)
10)
03) Jay Ramos / Yes
08)
09)
10)
05)
06)
07)
08)
09)
10)
#32
#33
Mini Z Element;12178179]
Hi All Mini Z Racer,
2013 Mini Z Element Stock & F1 Fun Race .
Track : Mini Z Element
Pv128 , 2-23 A , 2nd Floor , Jalan Genting Klang, Setapak ,KL
Date : 9-June - 2013
Time: 2:00 pm Start
Registration Fees:
2wd Class - RM 50
Race class
1) 2WD - Stock Class
2) F1 Fun - Stock Class
MOTOR
Motor:* Atomic US Spec. Motor (MO-017-US) 60T (2WD & F1 Class)
*** No illegal tampering is allowed.
PCB/Electronics
Kyosho MIni-Z*27Mhz/2.4Ghz ASF / Ad band
RV Project Fine-Tuned unit board*
Changing or stacking of FETs is allowed
Option Parts: Open, GYRO allowed.
*** No aftermarket electronic or ESC such as NOVAK or TEKIN.
2WD Chassis
2WD, *(86mm to 98mm wheelbase)
MR01, MR02, MR015, MR03, Only.
Min. Weight: (With batteries) 175g
Max Wheel Base: 98mm
Max Car Length: 178mm
Max Car Width: 80mm
Max Car Height: 45mm
F1 Chassis
F1 MF010 / MF-015
Body
Kyosho Mini Z Auto Scale , R246 and TRP*Scale Body Only
All windshield and window must be installed
*** Pan Cars, Le Mans, Lexan*GT Bodies are NOT ALLOWED
Batteries
Cars must be powered by four AAA batteries, Alkaline,
Ni-Mh or Ni-Cd battries*only.
*** No other types of batteries are allowed.*
Wheel rims
All brand plastic and aluminum rims are allowed.*
Maximum front wheel width is 8.5mm.*
Maximum rear wheel width is 11mm.
Maximum wheel diameter is 21mm.
Rims must fit within the width of the car body.
Tires
Any Brand of rubber / silicone tires may be used.*
Tire warmers are allowed.*
*** Form tires & Traction compount are NOT allowed .
*Transponder :
Robitronic personal transponder RS-163,
Transponder will be provided for those who do not own a personal transponder.
P/s: Please inform us in advance to loan personal transponder.
Results
3 X Qualifying . (Qualifying result base on the 1 heat. )
3 X Final. ( Final result base on best of 2)
Qualifying - 10 minutes
Final - 10 minutes
For further enquires, please email to [email protected]
Please register at RCtech.net or email us your detail , we will arrange the nessasarry.
02) Joseph /MR03 / Yes
03) Jason / MR03 / Yes
04) Edric / MR03 / No
05) Jeff / MR015.5 /Yes
07) Flipking MR03 / Yes
08)
09)
10)
02) Joseph / MF015 / Yes
04) Flipking / MF015 / Yes
05)
06)
07)
08)
09)
10)
Time: 2:00 pm Start
Registration Fees:
2wd Class - RM 50
Race class
MOTOR
PCB/Electronics
2WD Chassis
Max Car Width: 80mm
F1 Chassis
F1 MF010 / MF-015
Body
Batteries
Wheel rims
Tires
*Transponder :
Results
Final - 10 minutes
08)
09)
10)
05)
06)
07)
08)
09)
10)
#34
Time: 2:00 pm Start
Registration Fees:
2wd Class - RM 50
Race class
MOTOR
PCB/Electronics
2WD Chassis
Max Car Width: 80mm
F1 Chassis
F1 MF010 / MF-015
Body
Batteries
Wheel rims
Tires
*Transponder :
Results
Final - 10 minutes
08) Tofusan / MR03 / Yes
09)
10)
05) Tofusan / MF015 / Yes
06)
07)
08)
09)
10)
#35
Congratulation All Mini Z Racer,
2013 Mini Z Element Stock & F1 Fun Race Result
Champion : Jason Wong
1st Runner up : Joseph Wong
2nd Runner up : FlipKing (TQQQQQ....)
4th - Jeff
5th - Alex
6th - Tofusan
7th - Edgerd
F1 Fun race:
Champion : Joseph
1st Runner Up : Jeff
2nd Runner Up : Jason
4th : Alex
Once again thank you all participation to make this race happen.
4th - Jeff
5th - Alex
6th - Tofusan
7th - Edgerd
F1 Fun race:
Champion : Joseph
4th : Alex
#36
#37
Hi,
Please PM price for MR03 set. Thx.
#38
#39
#40
#41
#42
Kyosho Mini Z Malaysia Season Race 2013 is here.
This year, we have Mini Z Dynasty and Mini Z Element cooperate to organice the event. Please don't miss it.
Grand Lucky Draw for racer who have attend 5 of 5 races. Let's get your race machine reeeeeeady!!!!!!
Rules And Regulations.
(Update July 2013)
Car Specification
Chassis
- Open to all 1/27 on road cars, i.e. Kyosho Mini Z AWD, MR02, MR015, MR01, Firelap, Iwaver and X-mod.
Body Shell
- Kyosho, TRP and Firelap Body shell are allowed.
- Pan Car and Lemans body are not allowed in both stock and modified class.
- Judges reserve the right to disqualify a body for excessive material removal.
- All windscreens must be remaining secure in the body shell.
- Lexan Body are not allowed
Motor
- PNWC Official 70 Turns Stock Motor for the 1st race.
- Atomic Standard Motor 60T
- 1st race all racer must run with PNWC 70T motor
- 2nd race until last race, A Main top 3 driver must remain on PNWC 70T motor, others racer can choose Atomic Standard Motor 60T or PNWC 70T motor to use.
- Silver and carbon brush allowed to change.
- Motor must run with original motor can, original magnet and original armature.
Wheel
- Unlimited.
PCB Board
- Only original Kyosho, Atomic, Firelap or X-mod PCB boards are allowed. FET upgrade is allowed. External Turbo is allowed.
Battery
- Car must be powered by four AAA size batteries. No more, No less.
- Batteries must be Alkaline, NiMH, or NiCd.
- No other type of battery is allowed. / For example: Lithium Polymer batteries are not allowed.
- Extra Capacitor is allowed.
Tyre
- Any Brand: Rubber/silicone tyre only.
- No foam tires allowed.
- No traction compounds allowed on tires, or race surface.
- Tire warmers are allowed / Tires only cleaned with a 70% alcohol solution.
WEIGHT, WIDTH & HEIGHT
- Minimum weight (170g)
- Max wheel base (98mm)
- Max car length (180mm)
- Max car width (80mm)
- Max car height with wings (45mm)
Transmitter
- Any brand transmitter.
Lap counting system
- Robitronic transponder system
- Race organizer will on the lap counting system 1 hour for testing. Driver are encourage to test and make sure the transponder is place in the correct matter.
- In our pass experience, miss lap is due to driver handle the transponder not correct. Miss lap is responsible by the racer.
- Race organizer final result is the final result.
Marshal
- Drivers are responsible and compulsory to be a marshal when the other groups or mains is in racing. For example A main drivers need to be B Main marshal when B main is racing or vice versa. Penalty will be imposed for drivers who fail to be a marshal.
Race Detail
Date
03-08-2013 Dynasty Saturday 8pm
31-08-2013 Dynasty Saturday 8pm
05-10-2013 Element Saturday 8pm
09-11-2013 Dynasty Saturday 8pm
14-12-2013 Element Saturday 8pm
Mains Grouping
- Main will be justified by the qualifying hits on the race day.
Registered
- Last date to register, please refer to the race calendar
Qualifying Hits
- 3 x 5 minutes qualifying time, starting grid position to determine by the qualifying hits.
- There will be three qualifying runs for each class.
- Each run will last 5 minutes.
- For the first run, the starting grid will be staggered in a random order.
- For the second run, the starting grid will be reversed.
- For the third run, racers will be re-shuffled into heats based results from the
previous two qualifier runs.
- The starting order for each run will be based on the number of laps run in
the time allowed.
Race Format
- A Main
3 x 10 minutes final.
- B and C Main
- 2 best final result will recorded at point system.
- Point system is according to following
1st 100p
2nd 99p
3rd 98p and so on
- If there is same point occur between drivers, driver who get the best result in the best 2 final will be the champion.
- Example:
Driver A best 2 results are 1st and 3rd. Total point is 198.
Driver B best 2 results are 2nd and 2nd. Total point is 198.
Driver A best lap is 52 laps 10.00.00 for 3 races
Driver B best result is 52 laps 10.01.000 for 3 races
- Champion goes to driver A because Driver A have the best result.
Fees
- RM50 per race including track fees.
- RM5 for transponder rental for who do not have personal transponder.
Result
- There will be 5 races in 5 months. The best 4 results will be chosen to calculate position.
Point System
1st - 25 point
2nd - 20 point
3rd - 16 point
4th - 13 point
5th - 11 point
6th - 10 point
7th - 9 point
8th - 8 point
9th - 7 point
10th - 6 point
11th - 5 point
12th - 4 point
13th - 3 point
14th - 2 point
15th - 1 point
Top qualifier (Qualifying A Main 1st)
1 point
Note:
Due to limited pit stop place in Mini Z Dynasty and Mini Z Element. Participants are encouraged to well organize the pit stop area.
Any loss, broken or stolen item are not responsible by Mini Z Dynasty and Mini Z Element.
Rules will be update from time to time.
Organized by:
MINI Z DYNASTY
MINI Z ELEMENT
Sponsor by:
ATOMIC
PN RACING
Management reserves the right to change and update the rules and regulation without prior notice.
#43
#44
#45
