TEAMPOWER PRODUCT NEW AND SUPPORT FOR MALAYSIA
http://s16.postimage.org/mwgd8rg0h/3..._4972976_n.jpg
XPS Series Speed Control:70A sport COMBO set and 140A pro version http://s15.postimage.org/7pe5tjs9z/xps_esc_s2.jpg http://s11.postimage.org/z5k1lzg3z/xps_esc_s1.jpg http://s18.postimage.org/cla13khw5/settingcard_s2.jpg
XPS Series Speed Control LCD Setting Card: Features: * Support all kinds of sensor/sensorless brushless motors in RC model 1/10th, 1/12th Car & Truck * XPS Pro and Sport Speed control can support Turbo mode function for modify and stock mode motor. * Support Running Mode: Forward with brake, Forward/Reverse, Forward/Reverse with Brake * Manual Power profile: It can adjust the setting of the throttle/ brake power profile * One touch On/Off switch which are built on top of speed control. It can eliminate the problem of the switch wire being cutting off under collision and can save some room on the rc car chassis * Use the pocket-size LCD program card to program the controller settings * Multiple protection functions: Low voltage cut-off protection, Overheat protection, Throttle signal loss protection. Plutonium Brushless Motor(Sensor) Inprove Version V2 sensor Board and new Stator! Item no. TP-BLM-0XX100PL Plutonium Brushless Motor(Sensor)
Features: - Design Specification: Based on IFMAR/ROAR/EFRA/BRCA - Motor Dimensions (Diameter x Length) 35.8mm x 51mm - Shaft Diameter: 3.17mm - Magnet Dimensions (Diameter x Length): 12.35mm x 24mm(3.5turn~9.5turn), 12.3mm x 24mm(10.5turn~17.5turn) - Variable End bell with changing the output power and torque of the motor - Weight: ~165g (5g lighter than the old version) - Recommended RC Model Car: 1:10 model car, Buggy, MINI Car - Available Turns: 3.5T, 4T, 4.5T, 5T, 5.5T, 6.5T, 7.5T, 8.5T, 9.5T, 10.5T, 11.5T, 13.5T, 17.5T, 21.5T Item no. TP-6800-70C-2s 7.4V 6800mAh 70C LiPo battery http://s18.postimage.org/lhtzyzn9x/6800_70c_2s_ps1.jpg Features: - Battery Capacity: 6800mAH - Continuous Discharge Capacity: 70C - Hard Case Dimension: ~138mm(Length) x ~47mm(Width) x ~25.1mm (Height) - Weight: ~315g Team Power Primus Low Profile TI gear Servo http://s16.postimage.org/5u9r1fx01/servo_p3.jpg Item no. TP-HDB-002BL/LB High Downforce Body Holder Features: Usage: - It can increase Car Rear Traction, suitable in low or normal traction condition. - Suitable in stock mode competition, can allow to use smaller toe-in in rear side to increase top-end speed running in straight Weight: ~2g -Dimensions:- Mounting Hole (Diameter: ~6mm, Length:~32.5mm, Width: ~ 6mm) -Available Color: black or blue color http://s17.postimage.org/scfyxa2kr/HBD_p1_s.jpg |
Top Racing Cup 2012 at ShenZhen(KRC)
Modify Class A1: Derek Hung - He use Team Powers 6800mah,70C battery, Plutonium 4.0T and XPS Pro Speed Control F1 Class A1: P-Tom - He use Plutonium 17.5T and XPS Pro Speed Control http://s16.postimage.org/yx29sv4cx/Wong_and_DH.jpg XPS Pro Speed Control Setup with Plutonium 4.0T motor on 1:10 Touring Car Dead Band: 9% Punch = 0 Fwd Freq = 2 Start RPM: 6000 Power Band: 100% Timing Burst: 75% Timing Boost: 10% Turbo Delay: 0.1s Turbo Boost: 15 Gear Ratio: 8.8 Motor: Plutonium 4T with 0 degree timing XPS Pro Speed Control Setup with Plutonium 17.5T motor on F1 car Dead Band: 5% Punch = 0 Fwd Freq = 1 Start RPM: 3000 Power Band: 100% Start RPM: 3000 Timing Burst: 50% Timing Boost: 30% Turbo Delay: 0.1s Turbo Boost: 40 Gear Ratio: 3.2 Motor: Plutonium 17.5T with 0 degree timing TAC & F1RCGP 2012 HONG KONG Round 2 TQ, A1: P-Tom He use Plutonium 17.5T motor and XPS Pro Speed Control http://s13.postimage.org/g9wa7jpzn/P_Tom_F1.jpg XPS Pro Speed Control Setup: Dead Band: 3% Drag Brake =15% Punch = 0 Start RPM: 1000 Power Band: 100% Timing Burst: 50% Timing Boost: 45% Turbo Delay: 0.1s Turbo Boost: 40 Gear Ratio: 3.05 Motor: Plutonium 17.5T with 0 degree timing PYC 10.5T Stock Race at Mar-25 in Hong Kong http://s16.postimage.org/mkn8zg66p/DH_10_5_T_A1.jpg Got 1st prize: Derek Hung Got 3rd prize: Racing Woo They use Plutonium 10.5T motor+ XPS Pro Speed Control XPS Pro reference setting: Forward Freq Level: 1 Drag Brake = 3% Punch = 0 Start RPM: 3000 Power Band: 100% Timing Burst: 70% Timing Boost: 35% Turbo Delay: 0.1s Turbo Boost: 35 Plutonium Motor timing at -1 position, FDR = 7.2, 12.5mm ROAR Spec Rotor
PYC race at Oct-23,2011 in Hong Kong: 10.5T Stock race: Got 1st prize: Tse Kwok Cheong. He use Plutonium 10.5T motor+ XPS Pro http://s7.postimage.org/6ilmvmwiv/PYC_10232011.jpg XPS Pro reference setting: Forward Freq Level: 1 Drag Brake = 2% Punch = 0 Start RPM: 3000 Power Band: 100% Timing Burst: 60% Timing Boost: 45% Turbo Delay: 0.2s Turbo Boost: 50 Motor timing at -2 position, FDR = 7.7 TKOR(YMC) race at Nov-22,2011 in Hong Kong: Modify race: Got 1st, 2nd and 3rd prize: Derek Hung, Fai Ho and Racing Wu. They use Plutonium 4.0T motor+ XPS Pro XPS Pro reference setting: Forward Freq Level: 2 Punch = 0 Start RPM: 6000 Power Band: 80% Timing Burst: 80% Timing Boost: 12% Turbo Delay: 0.1s Turbo Boost: 28 Motor timing at +1 position, FDR = 9.3~9.5 TKOR(YMC) race at Jan-8,2012 in Hong Kong: Modify race: http://s15.postimage.org/63vydamhz/ymc1122_result.jpg Got 1st and 3rd prize: Derek Hung and Tse Kwok Cheong. They use Plutonium 4.0T motor+ XPS Pro XPS Pro reference setting: Forward Freq Level: 2 Drag brake = 8% Punch = 0 Start RPM: 5000 Power Band: 80% Timing Burst: 80% Timing Boost: 15% Turbo Delay: 0.1s Turbo Boost: 25 Motor timing at 0 position, FDR = 9.3~9.5 |
Go Team Power ! :D
Just got the xps pro, running it on my TeamC T2 Hope to get info & tips on Teampower products Cheers |
Originally Posted by FlyinHigh
(Post 10873299)
Go Team Power ! :D
Just got the xps pro, running it on my TeamC T2 Hope to get info & tips on Teampower products Cheers For the Day for Sure.we will shared our setup here.we have some Teampower User around 1 malaysia now!! this thread for we all to shared and get support!@ |
Originally Posted by sangyi41
(Post 10876439)
this is for sure.thanx you for support Teampower!Our Esc Is Best Bang For Money!What u Pay is More than u Get!:):)
Originally Posted by AmAr_D
(Post 10876507)
:nod::nod::nod:
Good, TeamPower ESC Xps Pro 140a.. Fast.. Turbo.. Boost...
Originally Posted by hondawong
(Post 11010133)
great touring and mini tires!
Hi guys
What is a good fdr start point for 17.5 boosted TC? I have the Plutonium 17.5 motor on a GT2 ESC Thanks |
Originally Posted by Mornedn
(Post 11110271)
Hi guys
New Team Power XPS PRO V1.2 140A Coming Soon!October In Malaysia!
http://www5.picturepush.com/photo/a/...0/10466823.jpg http://www2.picturepush.com/photo/a/...0/10466835.jpg NEW!! XPS EL V1.2(40A) + Cup Racer Sensor Motor Combo Set - Best for club racing and Drift is available now!! 40A SENSOR ESC+9.5 10.5 13.5 and 17.5 Sensor MOtor Include and Retail RM299 Only best value sensor 540 combo for no timing racing! http://www3.picturepush.com/photo/a/...0/10466856.jpg http://www5.picturepush.com/photo/a/...0/10466863.jpg New!! High grip Medium and softer Tire Insert are available now!! http://www5.picturepush.com/photo/a/...0/10466878.jpg http://www4.picturepush.com/photo/a/...0/10466882.jpg Please COntach Ur Local Hobby Shop for more detail thanx you. |
JMRCA 2012 Race in Japan- 28th Sept, 2012
http://www2.picturepush.com/photo/a/...0/10466925.jpg http://www1.picturepush.com/photo/a/...0/10466934.jpg http://www2.picturepush.com/photo/a/...0/10466940.jpg Open Class 13.5T Race: Namura Got the 2nd for the race with the use of Team Powers battery, motor and speed control. XPS Pro V1.1 reference setting: Forward Freq Level: 3 Drag Brake = 0% Punch = 0 Start RPM: 2000 Power Band: 100% Timing Burst: 100% Timing Boost: 42% Turbo Delay: 0.1s Turbo Boost: 55% Plutonium 13.5T Motor timing at -1.5 position, FDR = 6.29, 12.3mm ROAR Spec Rotor |
1 Attachment(s)
New!! 7.4V 7200mah, 75c Battery - Coming Soon!!
LATEST TEAMPOWER LIPO! ARRIVE ASAP!RESERVED IT NOW>HOT SALE! |
1 Attachment(s)
Bai Lok RC Model Car Cup Race at Dec-16 at in China:
Modify Class: TQ A1 prize: Ho Wing Fai Got 3rd prize: Derek Hung They use Plutonium 4.0T motor+ XPS Pro Speed Control ESC! XPS Pro V1.2 reference setting: Forward Freq Level: 2 Drag Brake = 9% Punch = 0 Start RPM: 15000 Power Band: 85% Timing Burst: 80% Timing Boost: 20% Turbo Delay: 0.15s Turbo Boost: 40 Plutonium 4.0T Motor timing at 0 position, FDR = 8.6 |
