XRAY 808 2011 specs
XRAY 808 2011 specs
The 2011 version of the XRAY's 808 is coming soon. With major improvements the new 808 brings higher performance, higher reliability and higher enjoyment.
2011 main news:
• New chassis
• New and improved handling
• New suspension geometry
• New improved weight balance
• New diff bulkheads
• New central drivetrain system
• New central drive shafts
• New pinion gears
• New diff ball-bearings
• New shock -rings
• New rear brace
• New front and rear alu suspension holders
• New composite eccentric bushings
• New suspension pins
• New high-downforce body
• New lightweight diff outdrives
• New graphite radio plate
new version every single year going to have a big hole in wallet again...
Let us wait and see the new outstanding XB808 2011....
Cheers...!!!!
I think this is Martin Hudy XB808 2010 car during World's. look like the rear arm has more holes for shock position and the rear block push arm slightly away from the bulkhead.....
second picutre show the centre drive terian is different from current 808. hope this will work very well for coming 2011 model.....
new xray 808 2011
http://www.teamxray.com/teamxray/new...kategoria=2327
Suah malaysia Ready?i think Other Country Is ready!
Guys…!!!
This 808 beauty will be estimate available on 24th to 25th Feb 2011. Please call us @ 03-56365163 or you may contact your nearest local hobby shop for your reservation. First shipment stock are limited units only.
Thank you and hope to receive good news from you.
