Muchmore CTX-C charger
#16
http://www.muchmoreusa.com/chargers/mmrp1000.html
rated to 10.0amp and 8S leh...
#18
is this the charger?
But for Li-ion & LiPo only can max to 1.0amp
mine one is
#19
Don't confuse between 1C and 1S
C is the charge rating in Amps
S is the no of cell count and in your case is 2
Your is a 2S (7.4v) 5000mah pack to be charged at 2S (7.4v) at 1C (5.0amps)...
#20
for example if your battery is
3800mAh you charge at 3.8A
4000mAh you charge at 4.0A
5000mAh you charge at 5.0A
your lipo is indeed 2 cell. so your selection has to be 7.4V in series as each cell is 3.7V.
#21
Can't find the exact charger on muchmore's website, if you are sure that the charger maximum is 1.0amp for lipo then you are out of luck... Which means you will need 300mins to charge your 5000mah pack at1.0amp, so you will need to charge 4 times and each time 90mins...
#22
ok..just let u know how i doing lipo setting while i charge
1. go to lipo function-->
2. CHG/DCH (i choose CHG)-->
3. no. of Cells ( 1cell-->2cell-->3cell-->i choose 2cell)-->
4. choose amp (0.1a, 0.2, 0.3, 0.4, 0.5, 0.6, 0.7, 0.8, 0.9, 1.0)1.0 is max already--->i choose 1.0
5. start charge
5. start charge
#23
#25
It is like filling up a swimming pool with a bucket...
From the website I gave you it seems your charger is capable to charge at 10.0amp leh...
#26
Page E12, Section 13 LI-ION CHG
http://manuals.hobbico.com/mmr/pt-ctxc-manual.pdf
Can't you change the charging amp to something higher than 1.0A on the 4th screen?
#28
#29
State-of-the-art, our brand new charger, the CELL MASTER, is the perfect battery management unit for charging and discharging all Ni-MH & NiCD batteries (also charges Li-Po). The Cell Master's Super Linear Current is the most pure linear charge available, and is UNMATCHED in the industry.
MAIN FEATURES
- PEAK CHARGE.......Super linear charge(3 memories-customizable)
- CTX CHARGE.....1/3-2/3-3/3 step charge(3steps charge, 3memories-customizable)
- Li-Ion & Li-Polymer CHARGE.......upto 11.1V(3cell)
- DISCHARGE.....0.1~10A , 0.1~6.0V cutoff
- CYCLE...............upto 3 times repeatition
- LAST DATA...save CHG, DCH, CYC data
- DC 10.0-16V input
- 1-8cells, 0.1-10A charge, 0.1-10A discharge
CM has current limit as belows.
Charge
1cell 0.1~5A
2cell 0.1~6.5A
3cell 0.1~8A
4-8 0.1~10A
Discharge
1~6cell 0.1~10A
7cell 0.1~8A
8cell 0.1~6A
Cycle(1~3times), Latest data display.
Super-fine peak sensitivity 3mV/pack~99mV/pack, Zero delta peak
Auto start timer charge(count down from up to 18 hours)
Auto repeak(0~3) comes with delay time and capacity limit
Trickle(on/off)-0.1A
Flex charge option (off~9steps)
Temp. sensor included.(15~70deg.C)
Temp. start (for cold batteries)
Capacity cut, Temp cut, Peak cut, Negavolt (one of four messege is shown after charge)
Key tones off~3, 3 kind of selectable melody for start, end, error IC controlled cooling dual ball bearing fans
Charge Amp, capacity, delta peak, Temp. cutoff, fan starting Temp.
values can be changed during Peak charge
White back lit LCD, Gold plated alligator clips in/output, Blue state indicator LED
Fan/Battery warmer control output
Easy key operations
Input and output protection against overloads, reverse polarity and short circuits,low or high input voltage, low battery temperature. Also, the auto restart system after power failure
MAIN FEATURES
- DC 10.0-16V input
Charge
1cell 0.1~5A
2cell 0.1~6.5A
3cell 0.1~8A
4-8 0.1~10A
Discharge
1~6cell 0.1~10A
7cell 0.1~8A
8cell 0.1~6A
Easy key operations
