How to remove scratches from carbon fiber chassis?
#16
i dont have the part number..u need to check with rc-planet..its already pre cut according to the shape of the chassis with all the screw holes too..just need to peel and stick it from front to rear like a sticker..i have been told that its an accessory from hongkong..
You can check with rcsmart.com.my
#17
#19
What chassis is that?
#20
#21
leongyooi,
assuming that your carbon fiber sheet is not badly scratched, you can actually take it to a car painter to get it sanded down and recoated with a clearcoat. Many 1:1 scale cars with cf do get tarnished from exposure to the sun and and this is how they restore the "look"
Hope this helps!
Hope this helps!
#22
leongyooi,
Hope this helps!
Hope this helps!
#23
rstoring chassis scratches
i used to spray a layer of clear paint on scratched surfaces but not sure if that help the carbon chassis... if u r not sticking protecting film you can try spraying those UV protection spray for car interior/plastic.. will tone down 1 shade for those scratches...
#24
leongyooi,
Hope this helps!
Hope this helps!
#25
old-man,
Thanks man! Actually just look see look see here only. Milo offered to lend me one of his car to play play on the 8th ORCA race. So come in here to kpc lah. May get to race with you soon! Give chance ok? Have not held a 3ch Tx for a long time!
#26
leonggyooi,
As much as all of us like our chassis to be scratch free, but it's just not possible unless you keep it as a shelf queen or run on carpet tracks only.
Not much help using chassis protector as your ride height will be totally out and handling will be affected.
Another note is that used/older CF chassis will lose it's strength and will flex unpredictably. So time for a new chassis!
Just enjoy the hobby and not worry about the chassis too much!
#27
You can try using a 14ch tx for the race! (becoz I know you can!)
#28
Machead,
Wa can drive 7 cars at one time!
#29
u mean selicon spray?
#30
leonggyooi,
