KRCC SSGP Championship Round 2 & GP Race
KRCC GP Race & SSGP Championship Round 2
Kuantan RC Club (KRCC) and Wanda Imperial, with Round 1 completed, are bringing you the Round 2 of the Championship. With Round 1 being the introductory round, this round will see drivers competing with championship points at stake.
KRCC and Wanda Imperial are not going to stop at SSGP only. Initially planned as a separate race; GP drivers, we have heard your request and are going to organize the 1st GP race after a long long break, in Kuantan.
So drivers, what are you waiting for? 2 race in 1 day. Details are as follow:-
SSGP
Fees: RM50
With more than a handful of races completed, SSGP is proving to be race that is meant to more realistic in scaled speed while having a low maintenance and cheap race.
We will be awarding points to drivers throughout the whole championship. At the end of the year, the driver with most points will win the championship. More info along with Rules & Regulations on SSGP will be explain in the post below as it will be too long to try to explain here.
GP
Fees: RM60
Ahh.. The long awaited GP race. Friends and fans, we are here to deliver the promise of organizing a GP race. Again, GP will have it's own post below for the Rules & Regulations.
Date: 24th April 2010 (Saturday)
Time: 9:00am
Venue: Wanda Imperial Speedway
Timing: I-LapRC
Prize: Trophy
Time: 9:00am
Timing: I-LapRC
Prize: Trophy
SSGP
Fees: RM50
GP
Fees: RM60
SSGP
Rules & Regulations:-
Points & Weight / Ballast:-
So, for example, in Round 2, Driver A finish 1st and Driver B finish 2nd.
The minimum weight is 1550g.
Finishing 1st adds 75g weight and 2nd adds 50g.
So for Round 3, Driver A start with 1625g and Driver B start with 1600g.
See the weight with minus sign? Now, if you finish 10th or above, weight will be removed accordingly.
Taking the same example, in Round 3, Driver A finish 15th (-30g) and Driver B finish 11th (-10g).
Hence for Round 4, Driver A start with 1590g and Driver B will be 1590g.
The maximum limit is 1750g and 1550g, does not matter how much the weight is over or under.
So, if Driver A finish Round 2 1st (75g), Round 3 1st (75g) and Round 4 1st (75g); the total should be 1775g for Round 5 (225g).
But because limit is 1750g, Driver A has to only add 200g weight.
Same for finishing 10 or below.
If Driver C finish Round 2 15th (-30g), he/she cannot go below to 1520g.
Driver C has to still start Round 3 with 1550g.
Look at the .xls attachment for more examples.
Race Format:-
Qualifying
3 Heat per Group (5 minute each)
To rank, the best number of laps is taken first.
If there is a tie in laps, the least time taken to achieve the laps is taken first.
If there is still a tie, the second best number of laps is taken and then time to achieve it.
Final
3 Final for A-Main (5 minute each)
2 Final for B-Main (5 minute each)
1 Final for subsequent Main(s) (5 minute each)
-ranking will be added later-
Track layout:-
- Total minimum weight without ballast/weight = 1550g (including transponder)
- Only realistic bodyshell / Non-touring bodyshell is permitted
- CANNOT use: Protoform Mazda Speed 6, Dodge Stratus, LTCR, etc
- CAN use: Subaru Impreza, Nissan Silvia, Nissan GT-R, Ford Mustang, Arta Garaiya, Advan Courage, etc
- Only 1/10 Electric Touring Car chassis is permitted
- Any battery type & capacity is permitted
- Handout 48T brush motor only. This motor will be returned by the end of the race.
- Motor cannot be disassembled.
- No modification on the motor is allowed. This includes modification on motor brush (ie: cut, serrated, changed, etc)
- Forward and Reverse function of ESC (Electronic Speed Controller) are permitted
- Any rubber-based tyre brand is permitted.
- Any type of rims is permitted except dish-type.
HTML Code:
Position Points Ballast/Weight 1 50 +75 2 43 +50 3 36 +30 4 33 +20 5 30 +10 6 27 +5 7 24 +5 8 22 0 9 20 0 10 18 -5 11 16 -10 12 14 -15 13 12 -20 14 10 -25 15 8 -30 16 6 -30 17 4 -35 18 3 -35 19 2 -40 20 1 -40
HTML Code:
Minimum Weight Driver Round 2 Round 3 A 1550g 1625g (1st = +75g) B 1550g 1600g (2nd = +50g)
HTML Code:
Minimum Weight Driver Round 3 Round 4 A 1625g 1590g (15th = -30g) B 1600g 1595g (11th = -10g)
HTML Code:
Minimum Weight Driver Round 2 Round 3 Round 4 Round 5 A 1550g 1625g (1st = +75g) 1700g (1st = +75g) 1750g (1st = +75g, reach max so +50g only)
HTML Code:
Minimum Weight Driver Round 2 Round 3 C 1550g 1550g (15th = -30g, reach min so -0g)
Race Format:-
Qualifying
Final
Track layout:-
GP
Race Format:-
Qualifying
Final
A-Main (45 minute)
B-Main (30 minute)
Subsequent Main(s) (15 minute each)
Position will be based on finishing position in each group.
Track layout:-
- Engine .12 - 3 port only
- Nitro - 16% only
- Pipe - IFMAR approved only
- Body Dimension - according to IFMAR approved bodyshell & specification only
- Fuel Tank - 75 CC including fuel line
Race Format:-
Qualifying
Final
A-Main (45 minute)
B-Main (30 minute)
Track layout:-
Participant list
Participant list:-
SSGP <name|chassis|frequency>
GP <name|chassis|engine|frequency>
- Wanda | TF5 | 2.4GHz
- Nurim Shah | TC3 | 27.xxx
- Kakarott | TF5 | 2.4GHz
- XMIE | Yokomo DM | 2.4GHz
- Alex Ng | Yokomo BD5 | 2.4GHz
- Billy Yow | Yokomo BD5 | 2.4GHz
- Jason | 416c | 2.4GHz
- --- | E4JS | 2.4GHz
- Goon | TA05 | 40.xxx
- Yoe | HL | 2.4GHz
- Najib | TA05 | 2.4GHz
- Reserved for Pekan
- Reserved for KT
- YieJack Presiden | 733 | Nova | 2.4GHz
- Madi Pokde | Mugen | Nova | 2.4GHz
- Easter | 733 | Nova | 2.4GHz
- PaulKC | xxx | T9 | 2.4GHz
- DiePolis | 733 | RB | 2.4GHz
- ZamRock | 733 | Nova | 2.4GHz
- PokYie | 733 | Nova | 2.4GHz
- TMA | NT1 | Nova | 2.4GHz
- ShukriBob | MTX5 | Nova | 2.4GHz
- AdyToyo | 720 | RB | xxx
- Azly Lemang Hangus | 3R | Nova | 2.4GHz
- Saiful | NT1 | Nova | 2.4GHz
- Wan | NT1 | RB | 2.4GHz
- Gedex | 733 | RB | 2.4GHz
- AbeJo | NT1 | Nova | 2.4GHz
Explaination
As mentioned previously, we are aiming primarily the East Coast crowd. Unfortunately, Terengganu & Kelantan have to work on Sunday. Hence, in order to accommodate the majority, the race will proceed on Saturday. We hope that everyone understands the difficult situation we are in. Thank you.
As mentioned previously, we are aiming primarily the East Coast crowd. Unfortunately, Terengganu & Kelantan have to work on Sunday. Hence, in order to accommodate the majority, the race will proceed on the Saturday. We hope that everyone understands the difficult situation we are in. Thank you.
geng pantai timur pun nk join gak
Updates updates updates.
Meh la blake main kat kuantan plok.......lama doh takdok race kat kuantan.
GP Race Tak Nampak
Kene up sikit thread ni la bro dan promo ke semua link tu...sebab orang tak perasan ada GP race.
Just my 5 cent
Just my 5 cent
Mari lah wehhhhhhh.........
main kat trek kuantan plok,bwk bini n anak skali..tinggal kat megamall tok laki main kete.waner
