HUDY PRODUCTS NEWS....!
#61
#107050 HUDY Ultimate Engine Tool Kit for .12 Engine
#107051 HUDY Ultimate Engine Tool Kit for .21 Engine
Bearing puller & presser
Ultimate engine maintenance tool kit
Pulls out front & rear bearings
Presses in front & rear bearings
Complete set includes puller & presser
Universal for .12 and .21 engines (optional adapters)
Exchangeable bushings
Optional collets available for different engines
HUDY Spring Steel
CNC-machined with highest precision
Black hard-coated aluminum 7075 T6 & hardened steel parts
Lightweight design and compact size
Comfortable and easy to use
Incredible lifespan & durability
Ultimate engine maintenance tool kit set includes puller and presser for pulling out and pressing in front & rear engine bearings. Universal components will work with either .12 or.21 engines; exchangeable bushings and optional collets are available for use with different-sized engines.
Made from HUDY Spring Steel and black-hardcoated aluminum 7075 T6 for unsurpassed lifespan and durability, all parts are CNC-machined for ultra-high precision. Lightweight design and compact size, easy and comfortable to use.
If needed a tool for use with both .12 and .21 engines, HUDY offers separate collets and presser adapters to make the bearing tool universal.
Adapters and collets for different engines are available separately as well:
#107061 Collet 11.5mm for .12 Engine Bearing
#107063 Collet 13mm for .21 RB & SH Engine Bearing
#107064 Collet 14mm for .21 Engine Bearing
#107072 Bearing Presser Adapter for .12 Engine - Set
#107073 Bearing Presser Adapter for .21 Engine - Set
HUDY Spring Steel
#64
how much this one cost? the one for 1/10 ep car & 1/8 touring.
#65
HUDY Spring Steel
HUDY Spring Steel
PM me the price..
#67
Pin Adapters for Electric Screwdriver
ψ3.0mm / ψ3.5mm adaptors for electric screwdrivers
allows use of standard tips from regular tools
World-renowned HUDY Spring Steel
Part of HUDYs huge range of tool tips
New ψ3.0mm & ψ3.5mm adaptors for electric screwdrivers allow for use of standard tips from regular tools. Made from world-renowned HUDY Spring Steel. HUDY offers a large range of tool tips that can now be used with pin adapter for electric screwdrivers.
#111030 Pin Adapter ψ3.0mm for El. Screwdriver
#111035 Pin Adapter ψ3.5mm for El. Screwdriver
Please contact your local Hobby shop or call us @ +603-56365163
#68
#69
#107771 HUDY Body Gauge for 1/10 Electric Touring Cars
Unique body gauge for measuring electric touring bodies and wings
Conforms to IFMAR, ROAR, FEMCA, EFRA rules
Track-width, body height, rear body clearance
Wing side dams, wing angle
Must have" for tracks, clubs, serious racers
Unique body gauge for checking electric touring body and wing sizes for IFMAR, ROAR, FEMCA and EFRA rules. Measures track-width, body height, rear body clearance, wing side dams, and wing angle. A "must have" for tracks & clubs and serious racers.
#70
#71
Hi...Hi...Hi...., that day i when to Abedey house accidently nampak satu di meja makan lah. hihihihihihihihihi.....
I got Japanese Body shell By Central Japan coming in next month. that is better to test lah... hihihihihihihihihihihi...
Huh..nasib baik Abedey tak simpan itu gauge lah save cost sikit... hihihihihihihihihiihi....
