Go Back  R/C Tech Forums > International Forums > Malaysian R/C Racers
Mini-Z GP IRC & MRCH 09 - 7 Series GP >
Old 05-03-2009, 07:35 PM
Default Mini-Z GP IRC & MRCH 09 - 7 Series GP
RESULT GP#1 - FIXED POINT
Points & Standing
1.Zainy=10
2.Anip=8
3.Hairy=6 (Best Lap 8.13s)
4.Fzhal = 0
5.Roy=5
6.Zaidi=4
7.RedEnzo=3
8.Jack=2
9.Aaren=1
10.Kamal=0
11.Amir=0
RESULT GP#2 - FIXED POINT
Points & Standing
1.RedEnzo=10 (Best Lap 9.39s)
2.Zainy=8
3.Shahrin=6
4.Hairy=5
5.Fliz = 0
6.Anip=4
7.Jack=3
8.Iskandar=2
9.Aaren=1
10.Zaidi=0
RESULT GP#3 - FIXED POINT
Points & Standing
1.RedEnzo=10
2.Shahrin=8
3.Zainy=6
4.Deen=0
5.Hairy=5
6.Mikail=4
7.Faizhal=0
8.Jack=3
9.Anip=2
10.Iskandar=1
11.Kamal=0
12.Roy=0
13.Abil=0
14.Zaidi=0
RESULT GP#4 - FIXED POINT
Points & Standing
1.Shahrin = 10
2.RedEnzo = 8
3.Zainy=6 (Best Lap 9.16s)
4.Hairy= 5
5.Deen = 0
6.Iskandar = 4
7.Mikail = 3
8.Jack = 2
9.Kamal = 1
10.Abil = 0
11.Najib = 0
NEXT RACE IS 27 JUNE 2009 @ IRC KLANG
Starting from 16 May 2009...
IRC & MRCH Proudly Presents:
Mini-Z GP Series IRC & MRCH 2009 (MiniZ GP Race 2009)
Buat julung-julung kalinya GP Mini-Z yang melibatkan kerjasama dua mini-z shop iaitu Indoor Racing & Cafe dan Mini-RC Hobbies akan diadakan bermula daripada 1st GP di MRCH pada 9 Mei 2009. GP yang mempunyai 7 siri iaitu 3 di IRC & 3 di MRCH dan 1 Siri di Luar (Gabungan 4 Track Kyosho - Race Mini-Z Terbesar di Malaysia ).
Format race ialah pengumpulan point bagi setiap race, point yang terbanyak akan memenangi RTR Set
Hadiah for Finals
1st Place - Mini-Z MR02/MR015 RTR Set
2nd Place - ASC Skyline R35 GT Body + 98mm Atomic Body Extension Set
3rd Place - ASC Non-GT Body + Team Orion 900HV AAA Battery
4th Place - Atomic Stock Ball Bearing Motor
5th Place - Kyosho X-Speed Motor
6th Place - Mini-Z Micro LED System
Rules & Regulations.
Car Specification
Chassis
Only open to all 1/28 on road cars:-Kyosho Mini Z AWD, MR02, MR015,
MR01, Firelap, Iwaver and X-mod.
Body Shell
- All Kyosho, Firelap and Iwaver body shell.
- No Pan Car and Lemans body are allowed.
- The IRC&MRCH mgmt reserve the right to disqualify a body for excessive material,removal and windscreens must be remaining intact the body shell.
Motor
~no limit to motor use; (open)
Wheel
- Unlimited.
PCB Board
Only original Kyosho, Atomic, Firelap or X-mod PCB boards are allowed.
FET upgrade is allowed. External Turbo is allowed.
Battery
- Car must be powered by four AAA size batteries. No more, No less.
Batteries must be Alkaline, NiMH, or NiCd.
- No other type of battery is allowed. / For example: Lithium Polymer
batteries are not allowed.
- Extra Capacitor is allowed.
Tyre
- Any Brand: Rubber/silicone tyre only.
- No foam tires allowed.
- No traction compounds allowed on tire, or race surface.
- Tire warmers are allowed / Tires only cleaned with a 70% alcohol solution.
Transmitter
- Any brand transmitter.
Lap counting system
- Participants must purchase their own transponder except for those who already have (Core Speedway Transponder Tag)
(RM25.00 each for one time purchase)
Marshal
- Drivers are responsible and compulsory to be a marshal when the other
groups or heat is in racing. For example heat 1 drivers need to be heat 2
marshal when heat 2 main is racing or vice versa. Penalty will be imposed
for drivers who fail to be a marshal.
Heats Grouping
- Grouping will be justified by the qualifying hits on the race day and will be divided into HEATS / total of participants
- Example:10 participants = 2 HEATS (5 car per heat)
Heat 1 - 2X3min QUALIFYING + Race 8min
Heat 2 - 2X3min QUALIFYING + Race 8min
Heat 1 & 2 Position will be merge to decide FINAL HEAT 1 & 2
Final Heat 1 & 2 = Race 8min (Position will be determined from Heat 1 & 2)
Final Heat 1 & 2 result will be merge to decide for position and points
Qualifying Hits
Open Class
- 2 x 3 minutes qualifying time, starting grid position to determine by the qualifying hits.
- There will be 2 qualifying runs for each HEATS.
- Each run will last 3 minutes.
- For the FIRST run, the starting grid will be staggered in a random order.
- For the SECOND run, racers will be re-shuffled into heats based results from the FIRST qualifier runs.
- The starting order for each run will be based on the number of laps run in
the time allowed.
Final Race Format
EVERY HEATS – 8 MINUTES
FINAL RACE GP(RACE 7) – 10 MINUTES
ALL RACER RACE TOGETHER (Example:Total of 14 participants race on only 1 HEATS & 2X5 Min QUALIFY)
Race entry fees: RM30.00 per race
Point System
Fixed Point System
1st Place - 10 pts
2nd Place - 8 pts
3rd Place - 6 pts
4th Place - 5 pts
5th Place - 4 pts
6th Place - 3 pts
7th Place - 2 pts
8th Place - 1 pts
TENTATIVE DATE
Race #1 :- 16th May 2009 (Bangi) - 11 AM
Race #2:- 30th May 2009 (Klang) - 3 PM
Race #3:- 13th June 2009 (Bangi)- 3 PM
Race #4:- 27th June 2009 (Klang)- 3 PM
Race #5:- 18th July 2009 (Bangi)- 2 PM
Race #6:- 25th July 2009 (Klang)
Final Race 1st August 2009 (Special Venue: T.B.A later)
The IRC & MRCH Management reserves the right to change and update the rules and regulation without prior notice.
Address utk Lokasi Race:
Indoor Racing & Cafe (IRC)
Indoor Racing & Cafe,
No.19A Jalan Sri Serawak 20B,
Taman Sri Andalas, 41200,
Klang,Selangor,Malaysia.
Contac :019- 399 88 37 (fzhal)
fliz is offline
Old 05-03-2009, 07:41 PM
Default Registration
GP#5 (18/7/09) OPENS FOR REGISTRATION
Mini-Z GP IRC & MRCH 09 Registration
5th GP (Bangi MRCH)
Name / Car Model / Frequency /
fliz is offline
Old 05-03-2009, 07:47 PM
fzhal's Avatar
Exclamation UPDATES
UPDATES
1st GP (Bangi MRCH)
1.ts4nkit/MA010 AWD TAKATA 94mm/27.145
2.MAT NOR
3.ZAINY
4.
5.
6.
7.
8.
9.
10.
11.
12.
Please bank-in RM30 to confirm your registration to this acc:
1. 12180010504057 (CIMB) - Faril Izaldi Salihuddin
2. 162339020285 (Maybank) - Norkhairuddin Noraidin
Free T-Shirt for every registration
fzhal is offline
Old 05-03-2009, 09:46 PM
ApengxiGT
Guest
Posts: n/a
Exclamation
Originally Posted by fzhal View Post
UPDATES
Apa maksud ni???
Old 05-03-2009, 10:07 PM
fzhal's Avatar
Talking maksud???!!
telah dijelaskan melaui panggilan telefon:- berita faham!! case close!!!
Originally Posted by ApengxiGT View Post
Apa maksud ni???
fzhal is offline
Old 05-03-2009, 11:41 PM
fzhal's Avatar
Thumbs up Core Transponder!!!!
Lap counting system
(RM25.00 only!!!for one time purchase)
fzhal is offline
Old 05-04-2009, 01:06 AM
gidz's Avatar
date for the 7 races fix yet?
gidz is offline
Old 05-04-2009, 01:21 AM
fzhal's Avatar
Smile Race Date:-
Race #1 :-16th May 2009 (Bangi)11:00am
Race #2:- 30th May 2009 (Klang)3:00pm
Race #3:- 6th June 2009 (Bangi)
Race #5:- 4th July 2009 (Bangi)
fzhal is offline
Old 05-04-2009, 02:00 AM
Updates...Map to MRCH
fliz is offline
Old 05-04-2009, 07:48 PM
fzhal's Avatar
Exclamation RACE NO.1
DATE:- 9TH MAY 2009, 11:00AM, LOCATION : MRCH BANGI
fzhal is offline
Old 05-04-2009, 09:48 PM
Default News Flash
Latest Update! Track layout for 1st GP Race MRCH
fliz is offline
Old 05-05-2009, 05:08 PM
Default T-Shirt
T-Shirt Size Available : M,L,XL
Color: Red & Black
Please List Your Size Here, TQ
fliz is offline
Old 05-05-2009, 05:14 PM
ApengxiGT
Guest
Posts: n/a
Color: Red & Black
1. Zainy : XL , Black
Old 05-05-2009, 06:10 PM
ts4nkit's Avatar
Color: Red & Black
aku nak 'M'....
ts4nkit is offline
Old 05-05-2009, 06:32 PM
fzhal's Avatar
Talking XXL?
harap XL leh muat la.....
fzhal is offline
