Go Back  R/C Tech Forums > International Forums > Malaysian R/C Racers
New Mini-Z Shop in Bangi Selangor (Mini-RC Hobbies) >
Old 05-16-2009, 10:43 PM
  #991
royrock's Avatar
huhu....maksud anip tu...tangan yang lagi satu tu...tangan gadis litar coming soon
royrock is offline
Old 05-17-2009, 12:01 AM
  #992
amboi ko.....eheheheh.....
akulesapelagi is offline
Old 05-17-2009, 12:06 AM
  #993
Default Yang mana satu ek???
Ferrari 360GTC Scudera Ecosse
atau
Ferrari 575GTC G.P.C Sport
adeh....
p/s: dalam dilema......
Old 05-17-2009, 12:13 AM
  #994
fzhal's Avatar
Smile
wah...terus tukar body baru hehehehe, sukar nak buat pilihan????sambar dua2 je...
Tahniah kepada semua pemenang semalam.....Zainy, anip...hairy....fzhal,
anyway....good job, semua org hepi rite????????.....
See you guys again 2 weeks from now at race#2 IRC Klang.....adakah anip akan melalukkan kejutan di gp klang????? atau mungkin jack a.k.a just jack????....or zaidi....roy.....aaron???...kamal???.....semua pun boleh menang.....janji practice lebih skit........
fzhal is offline
Old 05-17-2009, 02:56 AM
  #995
Default Notis @ MRCH
Kepada sesiapa yang mengalami masalah servo pot/steering glitch/alignment:
Taken from Mini-Z Racer Forum
I was just messing around with my MR02, which use to have a perfect, glitch free servo, however after some race time it eventualy developed the dreaded inaccurate steering sensor issue, the "Bad Pot Plague".
The common fix is to remove it and replace it... just to have it happen again. And since some shops are ripping ppl off and charing 15-30$ for this $2.00 part... its not the best of solutions.
It is also possible to shoot it with some motor/electrical cleaner, wich only works for a short time, before it starts doing it again, often before the first race is over.
As of now my current recomendation for steering issues, that are not related to the receiver obviously... is to LUBRICATE THE STEERING SENSOR POT! This should last longer than just shooting it with spray cleaner... since the cleaner/lube stays in there longer and does not just evaporate.
The stuff I used both cleans and lubricates switches, just typical switch lube should do the trick a small beed of it will work fine... Kyosho should have this done durring assembly, or TBM (the ppl that make the pots) should do it before being shipped to Kyosho... my guess is they are supose to, but they went cheap and skipped a step!
To get the lubricant in there, just pop the clear washer/cap off, and use a blade tip to put a drop in there... then put it backtogehter and move the steering back and forth to spread it around...
Before I did this, my car was not centering at all propperly, and while slowly going right, it would occationaly jerk left.. and visa versa... it was horible, I was going all over the track... now I can go super slow and it goes exactly where I tell it too with out taking an insane detour to the other side of the steering range.
I used: CaiLube L260Cp wich I got in surplus along time ago for other reasons... I have also used it as com drops , it works but its nothing special... but in the POT its a world of difference! If this works out I will tell the shop to stock some of this stuff... I knew I would find a good use for it some day . Some old mechanical speed controls came with switch lube you can might be able to use this stuff... but no clue if its the same as what I used.
I would like some others with similar issues, to test this on their cars, dont do it if it is your only race ready car, it could have side effects that I do not know about yet... so those that have spare cars, with steering issues... give this a try and report back here!
My guess is a lot of those with good lap times.. already do this .
I looked for posts saying to do this, but none turned up in the searches I did... What is odd is I had this idea a long time ago but I did not think the pot internals were exposed enough to get anything in there, then I took a closer look, and its all open inside once that clear plastic cap is removed...
http://www.minizracer.com/forums/showthread.php?t=23720
Sumber Lain:
http://www.mini-z-guide.com/othertips.htm
fliz is offline
Old 05-17-2009, 03:05 AM
  #996
ApengxiGT
Guest
Posts: n/a
Thumbs up WAH !!!!!! Dasyat !!!!
pastikan ada alum punya body holder !!!!
atau
adeh....
Old 05-17-2009, 05:32 PM
  #997
kompom ade...tak nak pisang berbuah 16 kali....
Old 05-17-2009, 05:58 PM
  #998
Default geng bukit dan geng klang...
nak tanyer dan mintak pendapat sikit....
masalah kete aku sekarang nie....cepat menjahanamkan diff standard depan....minggu nie aje aku dah beli 3 unit diff depan....2 baru 1 secondhad dari cikgu anip.....
so persoalan sekarang nie.....kalau aku pakai ball diff...aku tak berape minat....coz rase macam tak syiok....rase macam tayar tak grip....
ader suggestion tak......adeh....
p/s: dah nubis gilos.....tensi2....
Old 05-17-2009, 06:05 PM
  #999
ts4nkit's Avatar
atau
adeh....
...aku rasa ferari 575GTc lg mAsuk ar...tp bro...sayang bumper depan tu....dia bersegi...corner sangkut nti...pasti ang bosan bila main..kena kasi rata dlu atau modified letak bumper hand made
ts4nkit is offline
Old 05-17-2009, 06:11 PM
  #1000
ts4nkit's Avatar
...dah merapu la tuhhhhh...aku rasa ar...tak jadi la nak masukkan FET...risau nti terbakar, control susau, ...buat ms terdekat nie hanya nak tukar potensionmotor ja...n kasi tangan tak gigil n tak goyang n lat 6sense ngn keta...
ts4nkit is offline
Old 05-17-2009, 06:30 PM
  #1001
lubestars's Avatar
Originally Posted by ts4nkit
MRCH...tahniah atas penganjuran race GP mini-z yg cemerlang, gemilang dan terbilang...terima kasih semua..."saya menang hamper n trofi"
kepada geng2 lain..kalau tertewas, terTggl...jangan putus asa..k
ingat kata2 nie..."kita nie cam roda..kekdg d atas..kekdg d bwh"..terus kan usaha anda...tambah la apa2 patut kat keta tu...tambah tangan ke satu lg...hihihihi....aku pun nak tambah sesuatu...nanti kan....
betul la aku rasa nak tambah pendayung sebb naik bukit kat tak laju pakai dayung je huahuah
lubestars is offline
Old 05-17-2009, 06:34 PM
  #1002
royrock's Avatar
hehehe...aku nak tambah FET...
huhuhu....ni nak kene ade tow truck nie
bab ni nak kene tanya otai2 klang....
royrock is offline
Old 05-17-2009, 07:36 PM
  #1003
GT_CAPANG!!'s Avatar
Exclamation jangan paksa!!
bro!!,
jangan paksa kete lu jalan gak kalu kete lu sangkut kat devider!! itu salah satu sebab jadi cam tu!!! makna nyer cara lu main!!.. bukan masalah parts!!...... satu lagi lu pakai center shaft part??? kalu pakai titanium atau carbon!!.. shaft ni nyer gear kat depan tu besi!!!... gua pakai yg standard jer sebab plastic dia loose ckit so x kan jejaskan diff... sbb bila loose dia x kan paksa diff tu!!!!
GT_CAPANG!! is offline
Old 05-17-2009, 07:56 PM
  #1004
Default sedikit gambar GP1 bangi 15/05/09
terimalah....
Old 05-17-2009, 07:57 PM
  #1005
Default Sambungan kedua
