Nitro TC3
Old 11-11-2003, 06:00 PM
thamjk's Avatar
Lightbulb Nitro TC3
Dear all,
Like to find out is there any way to change the bearing at the second gear. This bearing is located between the clutch shoes at the spear and the first spear gear. The bearing is locked tight. Another question is where do we find such bearing size. Even thomas tan does not have the bearing only and he advice to change the whole thing.
thamjk is offline
Old 11-11-2003, 06:19 PM
crashed_1's Avatar
Default Re: Nitro TC3
Originally posted by thamjk
Dear all,
Try contacting tp racing...they are the dealers for NTC3.
crashed_1 is offline
Old 11-11-2003, 09:22 PM
lee82gx's Avatar
if the bearing is already gone,just hammer it out.
bring it to any bearing shop and u can get it ,prolly at a fraction of the cost.
lee82gx is offline
Old 11-11-2003, 10:03 PM
InitialD's Avatar
Lee is your man !
InitialD is offline
Old 11-11-2003, 10:49 PM
lee82gx's Avatar
no problem i personally understand the pain of finding stuff for AE cars!!
but the handling is so 1st class many ppl are willing to put up with it
lee82gx is offline
Old 11-12-2003, 07:07 AM
crashed_1's Avatar
You took the words right outta mah keyboard!!!
Old 12-01-2003, 05:50 PM
thamjk's Avatar
Dear all,
I am sure every NTC3 owner should have problem with replacing bearing. Because the bearing at the wheel is broken easily. Anyone has a solution to oversome this.
thamjk is offline
Old 12-01-2003, 06:12 PM
spawn's Avatar
Dear all,
dont whack into the walls or barriers then you will not have this problem. I have another solution!!, get another car!!.
spawn is offline
InitialD's Avatar
Easy. More maintenance needed as these bearings are small and spoil easy. You need to keep them clean and lubed to get them to last longer. Keep more spares for these bearings. Cheaper would be to go to a bearing shop and get these bearings yourself.
InitialD is offline
Old 12-01-2003, 06:13 PM
InitialD's Avatar
How can you be so cruel to your former rakan seperjuangan?
InitialD is offline
Old 12-01-2003, 06:17 PM
tommi's Avatar
Traitor...
tommi is offline
Old 12-01-2003, 06:25 PM
spawn's Avatar
i only broke 1 bearing coz I hit the wall, try driving properly and you will never break a bearing but it will still wear out and break if you dont oil it often.
spawn is offline
spawn's Avatar
Originally posted by tommi
Traitor...
Moogen for you?
spawn is offline
Old 12-01-2003, 07:06 PM
InitialD's Avatar
Ummm, I think he was referring to the bearings failing prematurely due to dust entering the bearings...
InitialD is offline
Old 12-01-2003, 07:15 PM
spawn's Avatar
cant be, the bearings are rubber sealed unless he bought the RTR version. I never had any dirt in the bearings. The bearings at the wheel breaks because of frequent hammering (wall and hard objects) and inadequate oiling. Anyway I drive carefully after smashing 1 wheel bearing and oil them regularly. I also do change the bearing once they get gritty. NOTHIN LAST FOREVER especially at those high speed and hard knocks.
spawn is offline
