best break-in method for nitro engine??
alrite, i have heard a lot, tried a few, heat cycle method lah, 1 tank off the ground then do a '8' lah or simply just run the fellow... share your view please wat do u reckon is the best break-in method for your nitro engines???
well i belive there is alot of way...
but basicly
new engine
1 must not overheat
2 must no high rev
3 must no empty for the 1st few tank.. .because when empty the engine will lean..
4 setting must be rich...
5 take care ur engine macan amoi.. the most important... belum kasar
my way ahh
1 put afterun 1st... to prevent damage.. <:::: that my style
2 make sure is rich setting very richhhhhhhh
3 start braaa braaaa babababababbabaraaa 1st fulltank
4 half tank left fill fuel untill full baaaaaa braaaa braaa braaaaaa braaa...
5 continues untill 5tank..
6 let it jalan jalan no full thottle..
7 jalan jalan sikit sikit rev
8 jalan jalan abit more rev
9 continues few days..
10 volia... tune for performace....
my break-in need manyak hari.. because i really take care alot my RC car..
just bear in mind only few issuse must think of it for a new Baby engine like i mention at 1st
diff ppl diff break-in style
but basicly
new engine
1 must not overheat
2 must no high rev
my way ahh
Here you are, something I learned Let me know if it is not clear enough, I can email them to you Good Luck!!!!!
Aiyoaiya......my method is very close to Drake's(the one i sent you).....please read this article that Razor showing us......1st tank with a very rich setting ....and opening the main needle to 1 or 2 turns counterclockwise(richen) ....and closing(5mins or less of a turn) the main needle after every tank........every tank tend to go up slowly in temperature.....cool article Razor!!!.......................... ..somehow i have been doing this to most engines i owned, the last and still running is my Axe Mamba converted X1!! Hehe.....Merry Christmas Guys!!!
Merry christmas (a.k.a Happy Shopping) to all and Happy New Year!!
I would say mine is a bit different in technique, quite similar in theory......heat cycle method.......as i always believe in gradually UP on temperature, but starting at a very Rich & cold Temperature.....gradually Up....is always best.....that is my opinion ..............
wicked guys, thanks for the info... but from wat i understand the so called 'new school method' is in the trend now as doing 3 mins x 5 times then 5 mins x 3 times thingy... but i guess the most important is always keep it at BTC...
Now this is the one i love. Josh cyrul style. Nowadays most engine built with ABC material. much stronger and much resilient.
Check my article on this - done with my buggy on an engine that known to break in few gallons only - BUT mine still intact until now. The compression still there - in fact still snug tight. This is done on 2006.
check the video at Engine Break In / Run-in Wide Open Throttle (WOT)
you can also read why Josh Cyrul did it here
whatever it is, if you're not confident enough.. just do it slowly. Remember, its your engine paid with your own money. Like vios said, treat it as your most loving girl or wife.. hehehehe.. betul juga tu vios
i guess doesn't matter wat method it is, just be patient and be rewarded... the best, use up 1 gallon of nitro for break-in, and time to go LHS for nitro...
nitro break in
hi
try search at youtube for nitro engine brake in....they using traxxas as a model and they hv 1 - 20 (if i right)....from 1st tank till up to tune for performance....also they show very danger situation such as how lean and rich...dont do this and that....
dun have to be break-in???? hmmmm... that's news to me...
