Go Back  R/C Tech Forums > International Forums > Malaysian R/C Racers
Atria Car Park Speedway >
Old 03-13-2006, 12:43 AM
  #23446
InitialD's Avatar
Originally Posted by tommi
I only learn from the best... Oi...I'm still using MX3 laa...
Wooi ! Clean car already or not?
InitialD is offline
Old 03-13-2006, 12:44 AM
  #23447
InitialD's Avatar
Eii...don't be mean laa...
Well, it's just surprising that his name just comes out like that.
InitialD is offline
Old 03-13-2006, 12:51 AM
  #23448
InitialD's Avatar
I found that it's quite confusing theoretically and practically...
The reason is because it depends on your front caster setting.
If your rear diff is tight and you use a lot of front caster (front upper arm moves more towards behind), you get more off power AND on power steering.
Generally, a looser rear diff will give better off power steering but to a certain extend only lah. Too loose and the car is very unstable like what you've mentioned.
InitialD is offline
Old 03-13-2006, 03:57 AM
  #23449
tommi's Avatar
Originally Posted by thamjk
All these are compromise. I think the best rear setup is corner entry rear diff tight, mid corner slightly loose depending on traction and corner out depending on traction and engine power. This is call dynamic rear diff.... F1 diff....
What are you waiting for? Put on your thinking cap and get IVTEC working!
tommi is offline
Old 03-13-2006, 03:59 AM
  #23450
tommi's Avatar
You BET.....
tommi is offline
Old 03-13-2006, 04:01 AM
  #23451
tommi's Avatar
You DA man...
Thanks!
tommi is offline
Old 03-14-2006, 07:34 AM
  #23452
Default bag of 1/10 nitro car
anyone selling a bag which can put everything in it like the car, transmitter, some tools, tyres.. etc?
leonggyooi is offline
Old 03-14-2006, 07:08 PM
  #23453
pink's Avatar
I agree with you actually...
Theoretically with a looser rear diff, both left and right wheels have more ease to spin on their own, hence generate the grip in corners. But then, with a tighter rear diff, the RESISTANCE of the tires to generate individual spin MAY also bring about some level of grip, UNTIL the resistance grip gave way and then causing the rear to break loose. And practically, I found that with a looser rear diff, the car tends to behave unpredictably entering into corners...no confidence on the rear end. Play tell I guess, different tracks will have different kind of traction characteristics that require different theories and setups...
Foooohhhhhhh!
Talk like world champ onli.......
pink is offline
Old 03-14-2006, 07:11 PM
  #23454
pink's Avatar
Woi woi..... the prophet getting old ka? Wrong comment on the wrong person la........
duh.................
pink is offline
Old 03-14-2006, 07:14 PM
  #23455
pink's Avatar
Aiyaaaa................. kotak plastik cap toyogo laaaaa........... apa mau susah
pink is offline
Old 03-14-2006, 07:18 PM
  #23456
pink's Avatar
Ok.... got it.....
But then I have been severely affected by under steering on throttle..... diff is loose.....
any remedies?
pink is offline
Old 03-15-2006, 02:29 AM
  #23457
Darth Vader's Avatar
Originally Posted by pink
Ok.... got it.....
any remedies?
Assuming you are running 1 way...
1) Make sure you are running the right tyre dia. and the right shore.
2) Set front ride height slightly lower, 0.5mm, than rear.
3) Tighten rear diff...
Try these 3 first, if still cannot quit and give me all your stuff...
Darth Vader is offline
Old 03-15-2006, 02:30 AM
  #23458
Default KO Propo servo repair
I may need to send my KO 2343 servo for repair.
Anyone has experience of sending stuff back to KO(Japan) for repair?
Plase help...
Thanks...
Old 03-15-2006, 03:48 AM
  #23459
tornado
Guest
Posts: n/a
KNN you yourself got one with wheels cap STANLEY........you go and ask people to get TOYOGO kah ? ....... people want something better mah.......
Old 03-15-2006, 05:46 AM
  #23460
pink's Avatar
SHHHHHH.............!
Toyogo good ma..... made in Malaysia some more......
ABS Plastic wor......
pink is offline
