E Crawler
#46
Tamiya CR-01 crawler
Indoor crawling...
wish can take to workplace to work on this during breaks
#47
AX10 SCORPION ROCK RACER (RTR) for sale .....
RM 1,300.00
interested pls PM me..
Brand New
• Rock Crawler: Takin' it slow - swap out the 20t pinion to the 14pt pinion and install the front locker (parts included). The Rear locker is already installed. This will give you true crawling performance.
• Rock Racer: Attack the rocks at full speed out of the box.
Features
• Complete ready to race/crawl out of the box
• 4WD
• 27T Electric Motor: Tear up the terrain in-door or out-doors. Easy Operation: No Tuning, No Fuel, No Loud Exhaust Noise. Just Plug'n'go!
• 20T pinion paired with an 87T spur gear gives you a quick rock racer ratio, or install the included 14T pinion for a slower rock crawling ratio.
• True Beadlocks: No Messy Glue!
• Hi-quality Composite Plastic and Metals
• Durable (ESC) Electronic Speed Controller: Hi-quality durable forward and reverse speed controller.
• Hi-Torque Servo help hold your line when rock crawling
• Solid Rear Axle lockouts improve ground clearance when crawling
• Slipper Clutch: Reduces gear wobble for a more efficient drivetrain. Allows a motor to work more efficiently and greatly enhances the durability of the drivetrain.
• Aluminum Chassis plates with a molded nylon skid plate provide a solid and rigid chassis
• Ultra compact and lightweight transmission
• Open front diff for smaller turning radius, or install the included front locker for more traction when rock climbing!
• Rear axle is locked for better traction.
• Full Ball bearings
• Overall gear ratio range from 15:1 to 74:1
• Transmission: 2.6:1; center mounted
• Differentials: Front - gear differential; Rear - locked (spool)
• Transmission: Single-speed
• Tires: Axial 2.2 Rock Lizards
• Wheels: Axial 2.2 8 Hole Beadlocks (Satin Chrome)
• Suspension: 3 Link
• Drive Shafts: Universal front and rear
Chassis
Wheelbase: 304mm~320mm (12”~12.6”)
Width: 254mm (10”)
Height: 156mm (6.125”)
Weight: 1588g (3.5 lbs)
Articulation: 70°
Ground Clearance: 79mm (3.125”)
Body
Length: 450mm (17.75”)
Width: 190mm (7.50”)
Height: 125mm (5.00”)
Electronics
Radio: 2 Channel
Servos: 1 Hi-Torque (Standard Size)
Forward/Revers ESC
Motor: 27T 540/550 Size
Required Items
(1) 7.2v Stick Pack Battery
(8) AA size Batteries
RM 1,300.00
Brand New
Features
• 4WD
Chassis
Width: 254mm (10”)
Articulation: 70°
Body
Electronics
Radio: 2 Channel
Forward/Revers ESC
Required Items
#48
ISKANDAR,
Sorry, Please move your posting to another thread "RC Equipment Sale".
Anyway, here is the update of my AX10 tuber chassis.
#49
wheelbase mismatch
Speed demon
great effort on customization...!
As for my crawler, pic 1 (side angle), looks like Tamiya should have made the body shell longer where the wheelbase is concerned... those concerned about scale looks sure tak berapa berkenan, me included. From other angles, it's ok.
#50
managed to mount the axle last night. But too late to post pics.
The delrin skid plate is custom made for double triangulation.
Linkage is home made using 6mm alloy rod.
Yet to be mounted is the MAMBA MAX, 80T motor, Spektrum rcvr and HITEC 5955TG servo. Will have to visit tire shop to but the balancing lead to add weight into wheels.
Also, body panel is still not mounted... will keep you guys posted..
BTW, any other crawler here??? come on... show what u have???
#51
Show? willll do when i get it crawling kekeke i've got nothing custom work to show lor hahaha...
#52
A'lil update on my tuber Scorpion
After trying some materials for the body panel, I went for some plastic sheet. It is flexible and easy to work with....
here's some pics without electronics. Still waiting for a 10A voltage regulator to power up the servo. The Hitec HS 5955TG is capable for 24kg/cm and so the current at stall on 6.0V is around 4.2A. The MAMBA Mac has a BEC only for 3A... this will smoke your esc to useless matchbox. The 10A BEC is from Castle Creations. It is designed to gives 10A max with a wide range input voltage. Bonus is, the BEC voltage is adjustable. The max input voltage is 24V..amazing!
#53
Trader Rating: 23 (96%+)
sd,
looks like you are never gonna need to buy body shells again....
hehe congrad on your cool ride.....ehem..super cool ride..
so far this the best looking for custom tube frame, the isuzu also nice..
congrad guy keep up th good work.....
i guess this type of R/c will never go out of style or become old model...
#54
Yo Speed,
Nice 1! Just make sure it doesn't stop there ...
Edited:
I just bought these: "RCD-HL 1:10 Suspension Shocks". RM75 with shipping, some more adjustable, alu body. Items arrived, 1 bent rod, shock travel is not too smooth.. but acceptable for SLOW CRAWLER....
Edited:
#56
yiela,
Yes and No..
You can convert the current truck into crawler.. but, to do this, you need to have some fab skill...
For crawling, independent arm is not the choice. We normally go for those solid axle like the TLT and Clod or AX10 Scorpion.
Also, the differential effect is not desired or required at all. Most will go for "locked" diff.
As for the
1. Hex is 17mm - you need to convert it to accept 12mm so you can mount the beadlock wheels or depending on the type of wheel you want to use.
2. Motor Mount - Again, this will need some creativity and some fabrication skills. You have to fabricate a gearbox where you also mount the motor. The gearbox must have output drive to feef the drive shaft to your axle.
3.Center DIff? - Not really a diff, but a locked gearbox / or gear reduction.. again, some creativity and fabrication skill.
If you really want to go into crawler, with minimal spending, assuming you already have the servo (high torque), esc with reverse and transmitter, go for the AX10.
What I mean with minimal spending is, the kit is basically crawler ready where the diff is locked and the gearbox is also locked. All you need is the electronics. I wouldn't go for the RTR version though...
just my opinion... hope this helps....
cheers...
Yes and No..
As for the
cheers...
#58
Hi Yiela,
I have done a similar conversion, take a look:
The full build thread is here:
http://www.rccrawler.com/forum/showt...ight=keiseng79
