Hissing sound when charging battery
hi guys,
i am using EP4200 and GP3800 and when i was charging them last night, I heard hissing sound. Is this normal? Is this what the called venting?
The hissing sound is more pronounce and longer in the EP vs GP. It started to 'hiss' before it peaks and after i removed the batts from the charger, it continued to on and off a few times.
pls advise EP gurus.... i do not want to blow up my room...
batt "bad" experience
hi bro
Im not a guru but my brother had an experience once and he heard the same hissing sound while charging. He notice that the temp of the batt is not warm but high and quickly discontinue the charging and leave the batt to cool down. The hissing sound still there, on and off. A few minutes later, much to the horror, the cell blew up. and I mean totally blew up..with shrapnels flying off and everything. Luckily theres a white board blocking between the batt and a few guys (my bro included), otherwise...who knows. Until now were not sure the r/cause of it.
Trader Rating: 45 (98%+)
This is not RC related, last time when I was drilling something using cordless drill, suddenly the battery pack exploded.. BOOOMMM.. so damn loud, luckily the shrapnel didn't penetrate my skin.
All this is because over charging!we must discharge every cells,i mean single cell,so that all cell are equal discharge,this way the cell will full charge equally.the problem you faced is one or fews cell is over charging cause it to vent.
I had used my battery for more then 1 1/2 years,it still good for racing.
Remenber this,discharge before charging.
i am charging at 5A and discharged my cells to 5.4V before charging it. using Integy 030 for discharge.
like u said, maybe one or more cells has gone bad.
anyway, i am most prob goin to seberang jaya track trmw. Hope to meet u guys there for advice...
i rasa la kan......................
ada serpent kut around there
u discharge till 5.4v or at 5.4v rate?
as far as i know la kan
NiMh for safe keeping...u can't fully discharge the battery kan?
i think u discharge it till around 0.9v ( discharger or cell conditionner
can serve u well )
NiCad u must discharge it till 0v
kalau i salah jangan ikut..
Here is my way of battery care;
1,Always discharge to 0v before charge
2,if not use for more than 2 days,discharge till 0.9v,then charge 300 sec
3,if plan not to use for more than a week,charge full,then store.
I'm using this guideline for more than a year,never had a problem with my battery.this guideline is given by my friend from Japan(Friend to Masami at Nagoya)
That is for safe keeping,
like that aaa master james
thanks
