Engine condition
Engine condition
Hi, it's me again with questions . from the pic below, i have few questions, 1. look the the pic of my engine head, is it ok, it looks like few pieces of aluminum chipped off (in red circle) and got 'pot holes' what happened to it? No, I didn't drop it. Is because of detonation?. 2, look at my sleeve and piston pic, are they in good condition? sorry for pic quality, i'm using camera phone.
Originally Posted by devious17
Your plug seems to say the engine is running very lean.
It looks like something went into the combustion chamber that would have caused those indent.
I have experienced it before on my Nova 21-3 and it was due to two of the ball from the main bearing cracked and chiped, the residue went into the combustion chamber then turned it into the surface of the moon!
It could be bad air filteration too.
Agree with you i do Master Devious17. (read like you are Darth Vader)
filter oil you put before running the engine,did you?(read like master yoda)
Originally Posted by TeeKuang
Yeah, I applied some ATF on the air cleaner sponge, perhaps the previous owner didn't.
(like master yoda said) secondhand engine you use did you?
come on laaaa leng chai...secondhand item must got little bit defect punya loo
