Charging Question - help
#47
Originally Posted by James khoo
Play 23 turn stock,under gear a bit then you will be safe!
I have blown Two 23turns Stocks and one 11turn Mod motors !
#48
i must order 1 3turn brush motor to play,if not Proceed5 will woops my ass!
Ok the next time we meet (need be in Ipoh or KL) you tell me what you will be using.. brushed motors or brushless.. I use same to play with you
#51
Proceed5,
what brand motor you're using,i had never blow a motor before even stock(gearing 5.0 and modify(10 turn gearing 7.30).and hope it will stay that way!
Cannot lar type online which brand(s) of motors blew up. Got to be a bit courteous to the branding interests of local LHS lar... :
#52
proceed5,
tonight u playing car or not
#54
Originally Posted by Flam3b0y
proceed5,
I would love to. Will be at the usual place [hopeful].. will try to sneak out from office by 7pm
#55
Originally Posted by proceed5
Hi Flameboy,
#56
dont take ur 3.5 out ar. play stock enough liow, if not car too fast i cannot control.
#57
Like that meaning bring out my TA05 or AME ???
aiyah bring bring lar ur mre. i think tonight its speed night. all sure go all out wan.
ur mre cannot play stock??
#58
#59
discharge
Something i don understand , as NiMH battery has no memory effect, then
1) what is the reason we need to discharge on NiMH?
2) when is the time to discharge?
3) how frequent should this practice be?
#60
cell 1 discharged with resistance 1.5 ohm.
cell 2 discharged with resistance 1.8 ohm.
then cell 2 is slower to discharged,when cell 1 finish discharged at cut off 0.9v,cell 2 still got some power on it.
So,it best to discharge individual cell down to 0.9v cut off before charging,all cell will received equal charge and it will put out equal power.
We do this discharging just after use on that battery.
hope this help
