Go Back  R/C Tech Forums > International Forums > Malaysian R/C Racers
How to store rechargeable battery >
Old 12-09-2006, 07:10 PM
tkhoo's Avatar
Trader Rating: 45 (98%+)
Default How to store rechargeable battery
Hello all the sifu, just want to check with all of you how you store your rechargeable battery after playing? Maybe going to store for a month long. Please advise on below 2 types:
Ni-Cd
Ni-Mh
Thank you.
tkhoo is offline
Old 12-09-2006, 07:12 PM
Hiwatari's Avatar
4 nimh...2 store 4 a month i think need to charger it around 1000mah
correct me if i'm wrong
nicd dunno
Hiwatari is offline
Old 12-09-2006, 07:31 PM
jfc_tech's Avatar
im a nitro guy but i got enough exp on batteries. my old batteries still functioning till now after 1 1/2 yrs rest.
Ni-CD: full charge at last use.
Ni-MH: half charge(eg.3300 -charge at 1500 or 2000).
when start using again: recycle back. charge, discharge, charge discharge.
im still using my nicd and nimh till now.
i charge back my nicd using Flex mode to waken it back. but for nimh, use linear as always. even after idling 1 yr, my 3300 still can fully charged at 3280. not bad i think. thats 1 yr. u know. but i guess, i use LRP charge. maybe becoz of that... kekekeke. shop promoter this.
jfc_tech is offline
Old 12-09-2006, 08:05 PM
proceed5's Avatar
Hi,
This is what I usually do to my batteries:
NiMH - discharge & equalise to 0.9v per cell. To store it for longer than 1 week, I normally re-charge with 500 or 1000mah after discharging & cooled down. If I plan to use the batteries again within 1 week, I just store it after equalising to 0.9v per cell.
NiCD - I fully discharge them and store it in a discharged state. In most cases, I even leave the NiCD in a discharge tray for 2 or 3 days before storing them in box.
That's just my 2cents. Cheers.
proceed5 is offline
Old 12-09-2006, 08:23 PM
James khoo's Avatar
Trader Rating: 15 (100%+)
Sifu-sifu,how about Lipo?n for nimh how many time need to cycle so that the battery will becomes active again?(back to normal power)
James khoo is offline
Old 12-10-2006, 04:37 AM
tkhoo's Avatar
Default Question
[/QUOTE]Ni-CD: full charge at last use.[/QUOTE]
Ok, this I can do with my charger
[/QUOTE]Ni-MH: half charge(eg.3300 -charge at 1500 or 2000).[/QUOTE]
Can a very cheap wall charger to charge until this rate? Mean how to calculate it to charge how long?
[/QUOTE]when start using again: recycle back. charge, discharge, charge discharge.[/QUOTE]
recycle back, mean discharge 1st then full charge, 2nd discharge again and full charge again then can start use?
[/QUOTE]im still using my nicd and nimh till now.
i charge back my nicd using Flex mode to waken it back. but for nimh, use linear as always. even after idling 1 yr, my 3300 still can fully charged at 3280. not bad i think. thats 1 yr. u know. but i guess, i use LRP charge. maybe becoz of that... kekekeke. shop promoter this. [/QUOTE]
tkhoo is offline
Old 12-10-2006, 04:39 AM
tkhoo's Avatar
Default How to
Originally Posted by proceed5
Hi,
Hi, how to charge each cell for 0.9V with cheap wall charger?
tkhoo is offline
Old 12-10-2006, 05:19 AM
proceed5's Avatar
Hi tkhoo,
I wrote Discharge to 0.9v per cell, NOT charge.
Maybe you should get James Khoo to help explain.
I do not think the wall charger has that function to charge or discharge to specific levels. You might have to buy a proper charger-discharger unit to do this.
Kindly consult James Khoo or the infamous Moey Chee Cheong (not sure where he is now these days).
Cheers
proceed5 is offline
Old 12-10-2006, 06:29 AM
tkhoo's Avatar
Default Sorry
Hi tkhoo,
Cheers
Ok, i also feel that cheap charger unable to discharger to 0.9V each cell....hehehehe, I am waiting my Prodigy II charger and I not sure this charger able to discharge to 0.9V each cell or not.....by the way James Khoo is from Pg Island? Moey now selling 1:1 car...and not 1:10.........hehehehe
tkhoo is offline
Old 12-10-2006, 06:16 PM
Default Charger
tkhoo,
Charging and discharging as a pack(side by side or stick pack) can be done by most charger with LED display to what ever voltage you one. But to individually discharge all six to 0.9v, I don't think so. That you have to purchase a discharger. Now the million dollar question -
Does it make a difference if you discharger all 6 cells individually to 0.9 v and charge it as a pack ??
Hope some experience bros there could give me some light on this
kowkl2 is offline
Old 12-10-2006, 10:33 PM
proceed5's Avatar
Originally Posted by kowkl2
tkhoo,
You got sms.
proceed5 is offline
Old 12-10-2006, 10:57 PM
proceed5's Avatar
Hi tKhoo,
Try sending a private message to JamesKhoo for his handphone number. He is a nice chap and have more than enough experience to hands on assist you. Maybe you should ask him where he and his members play so that u can join in the fun.
proceed5 is offline
Old 12-11-2006, 12:08 AM
tkhoo's Avatar
Default Ok
Get it proceed5
tkhoo is offline
Old 12-11-2006, 02:56 AM
Tpg racer's Avatar
What would happen if I discharge the newer generation batteries down to 0.7volts per cell???
Would this harm the battery???
I know that you can discharge older GP3300 batteries down to 0.7volts without harming the battery but what about newer cells like IB3800, IB4200, GP3700 and GP4300????
Tpg racer is offline
Old 12-12-2006, 12:20 AM
AdR|aN's Avatar
tkhoo,
If your using match packs, yes it does alot of difference.
But if the cells are just normal cells, the difference wont not be that much different.
Discharging cells down to 0.9v/cell is to avoid false peak when u charge them up.
AdR|aN is offline
