MALAYSIA FEMCE SERIES 2023 RD4 (FINAL ROUND)
Round 4 is upon us and we are happy to announce that the new Malaysia FEMCA Series Overall Champion would be crowned on the 24th of Sept 2023. Just to recap what can be won by the respective winners of each class and there are
Overall 1st position:
1 x return ticket to Bangkok Thailand to join the FEMCA finals in HUGE RC Circuit,
1 x RM500 accomodation subsidies
1 x Entry fee for the respective class that you have won
Overall 2nd position:
Overall 3rd position:
Overall winners of each class MUST advice the organizer of their intent to enter or not for the FEMCA FINALS in Bangkok no later than the 2nd of October as to facilitate flight ticket booking. If there is no response by the end if the day of the 2nd of October, the winner would be deem as NOT entering the FEMCA Finale in Bangkok.
In the event, the winner decides not to attend the FEMCA final in Bangkok Thailand, you would be given a voucher of equivilant value to the prize given to be used at Asia RC for Sweep and/or ORCA products. Transferring of the prize to another person is not permitted. The winner of each of the position of each class would only be awarded with 1 (ONE) prize from 1(ONE) category only, the Prize would be from the HIGHER finishing category.
Pls note that all, SPONSORED/SUBSIDIZED/RC AFFLIATED/TRACK OWNER/RC SHOP OWNER/ RC BRAND DISTRIBUTORSWILL NOT BE INCLUDED AND POINTS WOULD NOT BE TAKEN INTO CONSIDERATION
For the Final Round there would be a change in the tires that would be used for the touring categories. The change is caused by 2 reasons. 1) being the current EXX tires that is being used is NO LONGER available from SWEEP Tires due to raw material constrains. 2) Tires use for the FEMCA Finale and 2024 would be changed to the newer D36-R3PGSX. For racers who has New in Pack (Tires centre line not cut, no additional glue added) are eligible to have it returned to Asia RC for a 1 to 1 swap of the new tires at no additional cost to the racer. The organizer apologizes for the change and are trying to make the impact as low as possible to all racers involved.
For the FWD category, the tire would remain the same as before.
Your kind attention is highly appreciated.
The classes for the Malaysia FEMCA Series are:
13.5T Boosted Touring Class (Superstock 13.5T)
17.5T Blinky Touring Class (Stock 17.5T)
17.5T Spec ESC Blinky FWD Class (FWD Stock 17.5T)
The entry fees for 17.5T FWD class would be RM90/round, for all other classes, it would be RM120/round. As the Spec ESC class would be subsidized by ORCA.
MALAYSIA FEMCA SERIES 2023 RD1
DATE: Sept 24th 2023
VENUE: SACC RC PARK
LAYOUT:
Rule & Regulations:
RACE CATEGORIES:
1. 13.5T Boosted Touring Class (SuperStock 13.5T)
2. 17.5T Blinky Touring Car Class (Stock 17.5T)
3. 17.5T Spec ESC FWD Class (FWD Stock 17.5T)
RACE FORMAT:
- 3 Heats (Fastest 2 Heats combined)
- 3 Finals for A-Mains, 2 Finals for all other Mains
Grid position for Finals will be based on best 2 out of 3 Heats.
Final Race result will be based on IFMAR rules.
RULES AND REGULATIONS:
PLEASE NOTE THAT ALL TIRES THAT WILL BE USE FOR RACE WILL BE MARKEDWITH A NUMBER FOR EASY CHECKING AND REFERENCE FOR THE ORGANIZER. THE MARKED TIRES WOULD BE READY FOR SALE ON THE WEEK OF THE RACE. TIRES THAT DO NOTHAVE THE NUMBERED STICKERS WILL NOT BE ALLOWED FOR RACE USE. PLSEASE MAKE SURE YOU PURCHASE THE TIRES FOR RACE SEPERATELY FROM THOSE THAT ARE FOR PRACTICE. THE TIRES WILL BE AVAILABLE FOR PURCHASE AT ASIA RC SHOP IN 3 STONE PARK 7 DAYS BEFORE RACE DATE.
Motor : 13.5 turn (open to all brands)
Motor timing : No Limit on Kv and Amp, only impedance would be check. 0.019Ω Motor MUST BE CHECK AS A WHOLE (No Stator only Checking)
Esc : Open (timing and turbo functions ALLOWED)
Tires/Rims/Inserts : Controlled Tires (Sweep D36-R3 Tires with Asia RC Logo)1 SET only/2nd SET for A-Main (Heats and Finals).
Bodyshell : IFMAR Bodyshell Rules Applies
Min Weight : 1320gm (with transponder)
Batteries : HV Lipos are allowed but voltage is restricted to 8.44 volt only and will be checked by officials prior to Heats/Finals. Please ensure lipos are marked prior to each Heat/Final.
Batteries are to be below 290g. Any batteries over 290g are NOT ALLOWED
Drivers Skill Level : All drivers welcome
Motor : 17.5 turn (open to all brands)
Motor timing: No Limit on Kv and Amp, only impedance would be check. 0.037Ω (+-5% tolerance is allowed 0.035Min) Motor MUST BE CHECK AS A WHOLE (No Stator only Checking)
ESC: OPEN (Changing of capacitors are Allowed). ESCs MUST NOT BE OVER THE PRICE OF RM499(USD115) AS OF DEC 31 2022.
Gear Ratio: 3.5(3.3 for any shaft driven cars, this would be trialed at RD 1 and adjusted accordingly if there are any advantage noticed)
Tires/Rims/Inserts : Controlled Tires (Sweep D36-R3 Tires with Asia RC Logo)1 SET only (Heats and Finals).
Bodyshell : IFMAR Bodyshell Rules Apply
Min Weight: 1320gm (with transponder)
Batteries : HV Lipos are allowed but voltage is restricted to 8.44 volt only and will be checked by officials prior to Heats/Finals. Please ensure lipos are marked prior to each Heats/Finals.
Driver Skill Level: All Drivers Welcome, easier for new RC entrants
Motor : 17.5 turn (open to all brands - must be ROAR/IFMAR/EFRA/JMRCA/BCRA approved) Any attempt to modify or to influence the ability of the motor is not allowed (Ceramic bearing and rotor modification is NOT ALLOWED).
Motor timing : No Limit on Kv and Amp, only impedance would be check. 0.037Ω (+-5% tolerance is allowed. 0.035Min) Motor MUST BE CHECK AS A WHOLE (No Stator only Checking)
ESC : ORCA BP1001/TOTEM ONLY (Changing of capacitors are Allowed).
Gear Ratio: 3.5
Tires/Rims/Inserts : Controlled Tires (Sweep SF36AWPG Treaded Tires with ASIA RC Logo)1 SET only (Heats and Finals).
Bodyshell : Any bodyshells are allowed
Min Weight: 1250gm (with transponder)
Batteries are to be below 220g. Any batteries over 290g are NOT ALLOWED
ENTRY FEE:-
Deadline for Entry Fee: 5 days before actual Race date (Jan 31st 2023)
Touring (Superstock) -RM120
Touring (Stock 17.5T) – RM120
FWD Spec 17.5T – RM90
Two Categories –
For 2 Classes, RM20 would be reduced.
(Racing fee includes race fee, lunch & drinks on Race-day ).
ENTRY FEES RECEIVED LATER THAN THE DUE DATE WOULD BE SUBJECTED TO EXTRA RM20 LATE CHARGE.
Please bank in to
Bank:CIMB BANK
NAME: Sovereign Newstar (M) Sdn. Bhd.
A/C No.: 8000886685
Pleaes send all payment screenshot or photo of bank in slip to 016-9167772 Azri Amri, or alternatively you can pay your entry fee at Asia RC Pro Shop.
VENUE: SACC RC PARK
LAYOUT:
Rule & Regulations:
RACE CATEGORIES:
RACE FORMAT:
Gear Ratio: 3.5
ENTRY FEE:-
Two Categories –
Please bank in to
Bank:CIMB BANK
A/C No.: 8000886685
Name/Chassis/ESC/Motor/Battery/PT #/Team
1) Wong KokWai/Awesomatix A800MMX/ORCA OE1/ORCA Boostreme/ORCA Infinite/*******/Team Awesomatix ORCA
2) Azri Amri/Xpress XQ10R/ORCA OE1/ORCA Boostreme/ORCA Infinite/*******/Team Xpress ORCA
3) Leelin/Awesomatix A800MMX/ORCA OE1/ORCA Boostreme/ORCA Infinite/*******/Team Awesomatix ORCA
4) Ivan Lee/Awesomatix A800MMX/ORCA OE1/ORCA Boostreme/ORCA Infinite/*******/Team Awesomatix ORCA
5) Alex Lee/Awesomatix A800MMX/ORCA OE1/ORCA Boostreme/ORCA Infinite/*******/Team Awesomatix ORCA
6) Ah Kit/Awesomatix A800MMX/ORCA OE1/ORCA Boostreme/ORCA Infinite/*******/Team Awesomatix ORCA
7) Eric Ang/Awesomatix A800MMX/ORCA OE1/ORCA Boostreme/ORCA Infinite/*******/Team Awesomatix ORCA
8) Wee Yuan/Awesomatix A800/ORCA OE1/ORCA Boostreme/Zombie/Team Awesomatix
9) Kew SG/Awesomatix A800TRV/HW/HW/LRP/Team TR
10)
11)
12)
13)
1) Yewyew/yokomo BD11/Teampowers
2)
3)
4)
5)
6)
7)
8)
9)
10)
1) Wong KokWai/Awesomatix A800FX Evo/ORCA BP1001/ORCA Blitreme 2/ORCA Infinite/*******/Team Awesomatix ORCA
2) Ivan Lee/Awesomatix A800FX Evo/ORCA BP1001/ORCA Blitreme 2/ORCA Infinite/*******/Team Awesomatix ORCA
3) Alex Lee/Awesomatix A800FX Evo/ORCA BP1001/ORCA Blitreme 2/ORCA Infinite/*******/Team Awesomatix ORCA
4) Ah Kit/Awesomatix A800FX Evo/ORCA BP1001/ORCA Blitreme 2/ORCA Infinite/*******/Team Awesomatix ORCA
5) Wee Yuan/A800 FX/ORCA BP1001/ORCA Blitreme 2/ Zombie/Team Awesomatix
6) Kew SG/A800 FX Evo/ORCA Totem/??????/LRP/??????/Team TR
7)
8)
9)
10)
10)
11)
12)
13)
2)
3)
4)
5)
6)
7)
8)
9)
10)
7)
8)
9)
10)
10)
11)
12)
13)
2)
3)
4)
5)
6)
7)
8)
9)
10)
7) Arep perak /ffv3/Orca/blitreme 2/ptxxxxx/SCOTTUNED ACADEMY
8)
9)
10)
10)
11)
12)
13)
2)
3)
4)
5)
6)
7)
8)
9)
10)
8)
9)
10)
10) Heikal / MTC2R / Zombie / Zombie / Zombie / Team Aboo Motorsport
11) Affat / MTC2R / HW / Zombie / Zombie / Team Aboo Motorsport
12)
13)
2)
3)
4)
5)
6)
7)
8)
9)
10)
8)
9)
10)
12)
13)
2)
3)
4)
5)
6)
7)
8)
9)
10)
8)
9)
10)
Dear racers,
The points for all eligible racers are already up and I can only say that there are still chances for many racers and the fight for the top 3 spots are very tight. The points are based on 2 out of 3 where applicable and for the points below 50 are for racers who has only entered 1 round of the series.
Keep fighting and good luck to all racers.
12)
13)
2) Farouq Aboo/MTC2R/ORCA/ZOMBIE/PT*******/SOBER SNACK
3) ZAKI/XQ10R/ORCA/ORCA/PT*******/ TEAM FLYSKY
4)
5)
6)
7)
8)
9)
10)
8)
9)
10)
12)
13)
4)
5)
6)
7)
8)
9)
10)
8)
9)
10)
12)
13)
4) Thomas Teo / Awesomatix A800MMX / ORCA BP1001 / Zombie / Coddar / 3657676
5) Tommi / Awesomatix A800MMX / ORCA BP1001 / ORCA Blitreme 2 / Coddar / 6587660
6)
7)
8)
9)
10)
8)
9)
10)
12)
13)
6)
7)
8)
9)
10)
8)
9)
10)
12) Yewyew/yokomo BD11/Teampowers
13)
1) Farouq Aboo/MTC2R/ORCA/ZOMBIE/PT*******/SOBER SNACK
2) ZAKI/XQ10R/ORCA/ORCA/PT*******/ TEAM FLYSKY
3) Thomas Teo / Awesomatix A800MMX / ORCA BP1001 / Zombie / Coddar / 3657676
4) Tommi / Awesomatix A800MMX / ORCA BP1001 / ORCA Blitreme 2 / Coddar / 6587660
5)
6)
7)
8)
9)
10)
8)
9)
10)
13)
5)
6)
7)
8)
9)
10)
8)
9)
10)
13) Boy Mada/Awesomatix/Team KIRC
14) ZAKI/XQ10R/ORCA/ORCA/PT*******/ORCA/ TEAM XPRESS FLYSKY
2) Thomas Teo / Awesomatix A800MMX / ORCA BP1001 / Zombie / Coddar / 3657676
3) Tommi / Awesomatix A800MMX / ORCA BP1001 / ORCA Blitreme 2 / Coddar / 6587660
4) Eddie/XQ10R/ORCA TOTEM/TEAM POWER/PT*****/ORCA/TEAM XPRESS FLYSKY
5)
6)
7)
8)
9)
10)
8) Mat Arief/Destiny/ORCA/Trinity/PT*******/Max Power/ Team Destiny
9)
10)
5)
6)
7)
8)
9)
10)
9)
10)
5) Dino / 4634214
6)
7)
8)
9)
10)
9)
10)
5) Dino / 4634214
6)
7)
8)
9)
10)
9)
10)
15) CK Bong / Serpent /
5) Dino / 4634214
6)
7)
8)
9)
10)
9)
10)
5) Dino / 4634214
6)
7)
8)
9)
10)
9)
10)
5) Dino / 4634214
6) Ery / Ptxxxx / HW / HW / Coddar / Team 3Racing MY
7) Azam / PTxxxx / HW / Zombie / Team 3Racing MY
8)
9)
10)
9) Shukri / Cero FWD / Orca / HW / zombie / PTxxxx / Team Sobersnack 3Racing MY
10)
5) Dino / 4634214
8)
9)
10)
10)
16) Shahrin / Mugen MTC2R / HW / Zombie
5) Dino / 4634214
8)
9)
10)
10)
5) Dino / 4634214
8)
9)
10)
10)
5) Dino / 4634214
6) Ery / CERO / Ptxxxx / HW / HW / Coddar / Team 3Racing MY
7) Azam /CERO / PTxxxx / HW / Zombie / Team 3Racing MY
8) Izzudin / X4 / PTxxxx / ORCA / HW / LRP / TEAM XRAY MALAYSIA
9)
10)
10)
5) Dino / 4634214
9)
10)
10)
