Go Back  R/C Tech Forums > International Forums > Malaysian R/C Racers
Real Body Stock Race RD2 - 27 Oct 2019 @ Kota Raja >
Old 09-09-2019, 11:54 PM
Default Real Body Stock Race RD2 - 27 Oct 2019 @ Kota Raja
REAL BODY STOCK RACE (RBSR)
THE RACE FOR EVERYONE
RBSR FUN RACE:
Track Venue - Kota Raja, Klang
Date - 27 October 2019
Time - Sunday (9:00am)
RACE CATEGORIES:
1. GRAN TOURISMO (GT) CLASS (17.5 non-boosted)
2. TAMIYA GT Class (17.5 non-boosted)
3. FF Pro Class (17.5 non-boosted, Pro Driver n regular racer)
4. FRONT WHEEL DRIVE (FWD) (17.5 non-boosted)
5. Mchasis - Stock (17.5T non-boosted)
6. Tamiya Racing Truck (17.5t non-boosted)
7. F1 - Stock (21.5t/17.5t non-boosted)
RACE FORMAT:
- 3 Heats
- 3 Finals for A-Mains, 2 Finals for B Main and 1 Final for all other Mains
Grid position for Finals will be based on best 1 out of 3 Heats.
RULES AND REGULATIONS:
Motor
- 17.5 turn (Open Brand but must be approved by Roar)
- Motor timing - KV2800
Any attempt to modify or to influence the ability of the motor is not allowed (Ceramic bearing and rotor modification is NOT ALLOWED).
ESC
- Open brand but must be in blinky mode
Any attempt to modify or to influence the ability of the E.S.C is not allowed (Inclusive of adding additional capacitors and other E.S.C influencing device.) Only battery plugs can be changed.
Chassis
- Any 4wd 190mm chassis
- Chassis must have independent suspension to all four wheels. Each driven wheel must have a flexible joint (e.g. dogbone/s) in its driveshaft.
- No part of the chassis, including wheels/tires/axles/motor/battery or electronic equipment may protrude outside the body shell when viewed from above.
- Option parts that made for that model can be used.
- Open to all TC chassis
Body shell
- Only GT/DTM/WTCC/Some Drift (If looks like GT) style Body Shells allowed. Strictly no Touring bodyshells.
- Must be painted, front and rear lights may be painted or decals.
- All windows must be clear or paint clearly contrasted from the surrounding paintwork.**
- Optional wing which meant for body shell is allowed.
(Other Brands/Model On the discretion of Race Organizer)
Batteries
- Batteries: HV Lipos are allowed but voltage is restricted to 8.44 volt only and will be checked by officials prior to Heats/Finals. Please ensure lipos are marked prior to each Heats/Finals.
Weight
- 1400 grams minimum
Wheels & Tires
- MUST use controlled tires
Brand: Xpress
Model No.: XP-40079
- Limited to ONE SET ONLY for the whole race duration.
TAMIYA GT Class
Motor
ESC
Chassis
- Only Tamiya TT01 & TT02 chassis (Any type is allowed)
Gear Ratio
- Controlled gear ratio as below
- TT02 SPur 70T pinion 25T (7.28)
- TT01 SPur 61 pinion 22T (7.21)
Body shell
Batteries
Weight
- TBA grams minimum
Wheels & Tires
Brand: Xpress
Model No.: XP-40079
FF Pro Class
Motor
ESC
Chassis
- Chassis must have independent suspension to all four wheels. Each driven wheel (Front) must have a flexible joint (e.g. dogbone/s) in its driveshaft.
- Two (2) wheel drives (front only) is allowed.
Body shell
- Recommended Bodyshells
TAMIYA 51339*Volkswagen Golf , 51473 Volkswagen Scirocco GT24-CNG, TAMIYA 50968*Beams Integra, 51339*Volkswagen Golf , 51473 Volkswagen Scirocco GT24-CNG, 51421*Honda Civic, 51431 Honda Civic Type R, 51452*Honda CR-Z, 84137*Volvo 850, 84138* Honda Accord 1996 , 84139*Peugeot 406 ST, 84140*Alfa Romeo 156, 84143*Tomís EXiV, *84144*Renault Clio, 84145*Tomís Levin
- Wing Only Original wing which came from Original body shell is allowed.
Batteries
Weight
- 1300 grams minimum
Wheels & Tires
Brand: Xpress
Model No.: XP-40079
Racer
- Pro driver, sponsored driver and regular racer
Motor
- Motor timing - KV2600
ESC
Chassis
Body shell
Batteries
Weight
Wheels & Tires
Brand: Xpress
Model No.: XP-40079
Racer
- First time racer
Mchasis - Stock
Motor
ESC
Tires/Rims/Insert
- Open mini rubber tires (55 size)
- Example: team power, rush, sweep, xpress
Bodyshell
- Only realistic Old Skool High Roof 1980 bodyshell are allowed.
- High Roof (Wing that comes with the bodyshell is allowed)
Drive Train & Transmission
- 6.4 (Max) Final Drive Ratio.
- M05/M03/M07 pinion 18,
- Gambado: 20T/30T pinion 28
- No speed gear modification allowed.
- Front Lock Diff Situation is NOT ALLOWED.
- Gear differential is allowed.
Chassis
- M03, M04, M05, M06, M07 and Gambado only are allowed.
- Conversion to Evo or other carbon chassis is not allowed.
- Cars have to retain original wheel drive concept, no 4WD of twin motor configuration will be allowed.
Weight
- 1300gm (with transponder)
Tamiya Racing Truck
Motor
ESC
Chassis
- TAMIYA TT01 Truck Racing chasis
- Option part
- Standard Bevel gear only allowed
- Diff lock is not allowed
- Diff oil, putty is allowed.(must not lock)
- Organizer will do bevel gear checking
BodyShell
- Standard from Box (Tamiya Truck Racing Bodyshell), BittyDesign Iron Truck, Montech Truck bodyshell
- All pcs bodyset must be applied. If any chance the truck head peel off, the truck must go to the pit stop to attach back the bodyshell.
- Additional hole for reduce weight or aerodynamic is not allowed
- Reduce height or increase height (modification) of truck head for aerodynamic is not allowed.
FDR
- ratio >= 7.21 (fast gears not allowed)
must used spur 61 and pinion 22 (hard coated pinion is allowed)
Tires
- Tamiya truck rubber tyre (Standard from box)
- Insert is not allowed
- Rim: Open brand
Batteries
- HV Lipos are allowed but voltage is restricted to 8.44 volt only and will be checked by officials prior to Heats/Finals. Please ensure lipos are marked prior to each Heats/Finals.
Min Weight: 1550g (with transponder)
F1 CLASS
Motor
- 17.5/21.5 turn (Open Brand but must be approved by Roar)
- Motor timing - TBA
ESC
Chassis
- Any F1 chasis
Body shell
- Open F1 bodyshell (must be F1 look bodyshell)
- Must be painted.
- Optional front or rear wing which meant for body shell is allowed.
Batteries
Weight
- TBA
Wheels & Tires
- Any brand F1 tyres
Motor KV will be checked by organizer officials prior to start of event. Please ensure that the motor is marked or you will be prohibited from racing or be disqualified.
RACING FEE:-
Deadline for Entry Fee: October 20th 2019
All Category -RM60 (After deadline, additional RM10)
Two Category -Discount RM10
(Racing fee includes race fee, lunch & drinks).
*Tyre is not included. Please get from Local Hobby Shop
Fee to be paid to below account details
CIMB Bank
7618126718
JOKHAIRINIZAM BIN AB AZIZ
Receipt must be whatapp to Joe Aziz -0169200984
PRIZES
ē Trophy for all.
Registration will be closed by 20th Oct 2019.
PIC CONTACT Ė Any info regarding to rule and any unclear information please contact PIC below.
shukrihashim is offline
Old 09-09-2019, 11:55 PM
Default Layout
To be update
Old 09-09-2019, 11:57 PM
Default Registration
(Name / Kit / PT no. / Team / State)
1.
2.
3.
4.
5.
1.
2.
3.
4.
5.
FF Pro Class​​​​​​​ (17.5 non-boosted)
Pro driver, sponsored driver & regular racer
1.
2.
3.
4.
5.
1.
2.
3.
4.
5.
1.
2.
3.
4.
5.
1.
2.
3.
F1
1.
2.
3.
4.
5.
Old 09-10-2019, 12:52 AM
kennysham's Avatar
Default Registered
1.
2.
3.
4.
5.
1. Kenny / TAMIYA / Tt02rr / PT......../ TEAM BLS
2. ADWIN / TAMIYA / TT02R / PT....../ TEAM BLS
3. BEAN LEE / TAMIYA / TT02 / PT...... /TEAM BLS
4. RAYMOND Chong / TAMIYA / PT.......
5.
FF Pro Class (17.5 non-boosted)
1.
2.
3.
4.
5.
1.
2.
3.
4.
5.
1.
2.
3.
4.
5.
1.
2.
3.
F1
1.
2.
3.
4.
5.
kennysham is offline
Old 09-10-2019, 02:19 AM
1.
2.
3.
4.
5.
1. KENNY TAMIYA TT02RR PT........ TEAM BLS
2. ADWIN TAMIYA TT02R PT...... TEAM BLS
3. BEAN LEE TAMIYA TT02 PT...... TEAM BLS
4. RAYMOND CHONG TAMIYA PT.......
5.
1. Wak Rose / Serpent / PTxxxx / Team Songkok / KL
2. Zairul / T4F / PTxxxx / Team Songkok / KL
3. Wafie / T4F / PTxxxx / Team Songkok / KL
4. Joe Aziz / T4F / PTxxxx / Team Songkok / KL
5.
6.
1.
2.
3.
4.
5.
1. Mekdi / M07 / PTxxxx / PPRCC / Penang
2.
3.
4.
5.
1. Wak Rose / TT01 / PTxxxx / Team Songkok / KL
2. Zairul / TT01 / PTxxxx / Team Songkok / KL
3. Wafie / TT01 / PTxxxx / Team Songkok / KL
4. Joe Aziz / TT01 / PTxxxx / Team Songkok / KL
5.
6.
F1
1. Bob Jitra / Xray X1 / PTsewa / TRS Racing / Kedah
2.
3.
4.
5.
Old 09-10-2019, 11:33 PM
1.
2.
3.
4.
5.
5. Epin / TT02 / PTxxxx / Team Songkok / Selangor
6.
7.
5. Wandy Moore / Serpent / PTxxx / Team Melaka / MLK
6.
1.
2.
3.
4.
5.
2. Epin / M05 / PTxxxx / Team Songkok / Selangor
3.
4.
5.
5.
6.
F1
2.
3.
4.
5.
Old 09-11-2019, 03:40 AM
1.
2.
3.
4.
5.
6.
7.
6.
1.
2.
3.
4.
5.
3.
4.
5.
5. Lee Lin / Tt01 / PTxxxx / Team xxx / KL
6.
F1
2. Lee Lin / xxx / PTxxxxxx / team xxxx / KL
3.
4.
5.
Kienlin is offline
Old 09-13-2019, 03:01 AM
1. Azam Nordin / T418 / PTxxxx / Neka Racing Team / Selangor
2.
3.
4.
5.
6.
7.
6.
1.
2.
3.
4.
5.
3.
4.
5.
6.
F1
3.
4.
5.
Old 09-13-2019, 08:43 AM
2. Neslo / *ahem* / 9652958 / Team Xray Malaysia / Selangor D.E
3.
4.
5.
6.
7.
6.
1.
2.
3.
4.
5.
3.
4.
5.
6. Neslo / TT01 / 2586951 / Team Xray Malaysia / Selangor D.E
F1
3. Neslo / Xray X1 / 3950836 / Team Xray Malaysia / Selangor D.E
4.
5.
cheapskate.brok is offline
Old 09-18-2019, 07:32 PM
azlie kr's Avatar
3. Azlie Kr
4.
5.
6.
7.
6.
1.
2.
3.
4.
5.
3.
4.
5.
F1
4.
5.
azlie kr is offline
Old 09-26-2019, 07:08 PM
shahrin's Avatar
3. Azlie Kr
4.
5.
6.
7.
6. Shahrin / Xray T4F / PT***** / Team XRAY Malaysia
7.
8.
9.
10.
1.
2.
3.
4.
5.
3.
4.
5.
F1
4.
5.
shahrin is offline
Old 09-28-2019, 11:52 PM
nuar9w2rlw's Avatar
3. Azlie Kr
4. Salem JB / PTxxxxxx / XRAY / EPJB / JDT
5.
6.
7.
7.
8.
9.
10.
1.
2.
3.
4.
5.
3.
4.
5.
7. Anuar JB / PT4464766 / TT01E / EPJB / JDT.
8.
9.
10.
F1
4.
5.
nuar9w2rlw is offline
Old 09-28-2019, 11:54 PM
nuar9w2rlw's Avatar
3. Azlie Kr
5. Arman Ahmad / PTxxxxxx / XRAY / EPJB / JDT
6.
7.
6.
7.
7.
8.
9.
10.
1.
2.
3.
4.
5.
3.
4.
5.
8.
9.
10.
F1
4.
5.
Old 09-29-2019, 11:55 PM
3. Azlie Kr
6.
7.
6. Roselan / Tt02 / Ptxxx / Team Songkok
7.
7. Azri Amri / Xpress / PTxxxx / Team Xpress
8.
9.
10.
1.
2.
3.
4.
5.
3.
4.
5.
8.
9.
10.
F1
4.
5.
Old 10-04-2019, 08:15 AM
3. Azlie Kr
6. Haikal
7.
7.
8.
9.
10.
1.
2.
3.
4.
5.
3.
4.
5.
8.
9.
10.
F1
4.
5.
waktc is offline
