Go Back  R/C Tech Forums > International Forums > Malaysian R/C Racers
MNC EP Touring 2019 - Rd 2 @ Kota Raja, Klang >
Old 06-12-2019, 11:34 PM
Default MNC EP Touring 2019 - Rd 2 @ Kota Raja, Klang
Malaysian National Championship (MNC) EP 2019
A FEMCA & IFMAR -santioned series via RC Malaysia
MNC+BittyDesign 2019
With the collaboration of RCPITSTOP @ BITTY DESIGN and MNC 2019, for this season we would like to introduce to Malaysia Racers there will be 6 categories to be carried out and 2 of it are fresh categories. To encourage new racers participation and inspire hardcore RC racers, little change in rules and regulations will be made to meet the needs of Racers and we emphasize the balance of costs, skills and technology of RC Product. Bitty will be our official Premier Sponsor for this season and there will be benefit for all RC community.
Organized by MNC2019 committee.
MNC 2019 Round 2:
Track Venue - Kota Raja RC Track, Klang Selangor
Date - 28 July 2019
Time - Sunday (9:00am)
RACE CATEGORIES:
1. Touring Car - Modified
2. Touring Car - SuperStock (13.5t boosted)
3. GT Touring Car - Stock (17.5T non-boosted)
4. Mchasis - Stock (17.5t non-boosted)
5. Tamiya Truck- Stock (17.5t non-boosted)
6. Formula 1- Stock (21.5t /17.5t non-boosted)
RACE FORMAT:
- 3 Heats
- 3 Finals for A-Mains, 2 Finals for B Main and 1 Final for all other Mains
Grid position for Finals will be based on best 1 out of 3 Heats.
Race result will be based on IFMAR rules.
MNC CHAMPIONSHIP POINTS:
Top 20 drivers (A Main dan B Main) qualify for championship points in the following order (22,20,18,17,16,15,14,13,12,11,10,9,8,7,6,5,4,3,2, 1).
Overall champion will be base on 3 of 4 round for Super Stock, Stock, Truck and M chassis
TQ will earn an additional 1 bonus point.
RULES AND REGULATIONS:
MODIFIED Touring Car
Motor : 10.5 turn and Below (open to all brands - must be ROAR/IFMAR/EFRA/JMRCA/BCRA approved)
Motor timing : no restriction
Esc : Open (timing and turbo functions ALLOWED)
Tires/Rims/Inserts : Controlled Tires (RUSH 40X). 2 sets only (Heats and Finals)
Bodyshell : IFMAR rules apply
Min Weight : 1350gm (with transponder)
Batteries : HV Lipos are allowed but voltage is restricted to 8.44 volt only and will be checked by officials prior to Heats/Finals. Please ensure lipos are marked prior to each Heats/Finals.
Drivers : Professional Racer, Subsidize Racer and Regular racer
SUPERSTOCK Touring Car
Motor : 13.5 turn (open to all brands - must be ROAR/IFMAR/EFRA/JMRCA/BCRA approved)
Motor timing : no restriction but max 3400kv and 2.5amp draw
Drivers : Regular racer
BITTY GT Stock Touring Car
Motor : 17.5 turn (open to all brands - must be ROAR/IFMAR/EFRA/JMRCA/BCRA approved) Any attempt to modify or to influence the ability of the motor is not allowed (Ceramic bearing and rotor modification is NOT ALLOWED).
Motor timing : MAX KV2800
ESC : OPEN ESC BUT MUST BE IN BLINKY MODE (open to all brands - must be ROAR/IFMAR/EFRA/JMRCA/BCRA approved)
Any attempt to modify or to influence the ability of the E.S.C is not allowed (Inclusive of adding additional capacitors and other E.S.C influencing device.) Only battery plugs can be changed.
HW XR10 Just Stock is allowed.
For those who are not using TRUE BLINKY ESC, please ensure ESC have LED blinking and prepare prog card for organizer to do checking (upon request)
Bodyshell : controlled BITTY Design Bodyshell, Venom or AGATA 1/10 GT 190mm
Min Weight: 1350gm (with transponder)
Batteries: HV Lipos are allowed but voltage is restricted to 8.44 volt only and will be checked by officials prior to Heats/Finals. Please ensure lipos are marked prior to each Heats/Finals.
Drivers : First time racers, newbies and beginners
M-CHASSIS Stock 17.5T
Tires/Rims/Inserts : Controlled Tires (DS Racing (36R,34R)). 1 set only (Heats and Finals)
Bodyshell : Only realistic ABC, Tamiya, HPI, Blitz, SPICE mini bodyshell are allowed.
High Roof (Wing that comes with the bodyshell is allowed)
Min Weight: 1280gm (with transponder)
Drive Train & Transmission: 6.4 (Max) Final Drive Ratio.(M05/M03/M07 Pinion 18, Gambado: 20T/30T pinion 28).
No speed gear modification allowed.
Front Lock Diff Situation is NOT ALLOWED.
Gear differential is allowed.
Chassis: M03, M04, M05, M06, M07 and Gambado only are allowed.
Conversion to Evo or other carbon chassis is not allowed.
Cars have to retain original wheel drive concept, no 4WD of twin motor configuration will be allowed.
Drivers : First time racers, newbies, beginners and regular racer
TAMIYA Racing Truck
Chassis: TAMIYA TT01 Truck Racing chasis (all factory standard from box)
- option part is allowed
Diff & Bevel gear
-Standard Bevel gear only allowed
-Diff lock is not allowed
-Diff oil, putty is allowed, but diff must not lock
-Organizer will do diff checking
BodyShell: Open Brand, Tamiya Truck Racing Bodyshell ( MAN TGS & BUGGYRA FAT FOX) & BittyDesign IRON 1/10 TRUCK
-Standard pieces body set must be applied. If any chance the truck head peel off, the truck must
go to the pit stop to attach back the bodyshell.
-Additional hole for reduce weight or aerodynamic is not allowed
FDR: >= 7.2 (standard spur from box 61, option pinion 22)
Tires: Tamiya truck rubber tyre (Standard from box)
-Insert is not allowed
Rim: Open brand
Min Weight: 1550g(with transponder)
Formula 1 Class
Motor:17.5/21.5 turn (Open Brand but must be approved by Roar)
ESC: Open brand but must be in blinky mode
Chassis:
- Any F1 chasis
- Option parts that made for that model can be used.
Body shell:
- Open F1 bodyshell (must be F1 look bodyshell)
- Must be painted.
- Optional front or rear wing which meant for body shell is allowed.
(Other Brands/Model On the discretion of Race Organizer)
Weight: - TBA
Wheels & Tires :
- Any brand F1 tyres
- Limited to ONE SET ONLY for the whole race duration.
Motor KV (Super Stock class, Mchasis and Truck) will be checked by organizer officials prior to start of event. Please ensure that the motor is marked or you will be prohibited from racing or be disqualified.
RACING FEE:-
Deadline for Entry Fee: July 21st 2019
Touring (Modified, Superstock, GT) -RM70 included FEMCA fees (After deadline, additional RM10)
Other category -RM60
Two Category -Discount RM10
(Racing fee includes race fee, lunch & drinks).
*Tyre is not included. Please get from Local Hobby Shop
Fee to be paid to below account details
CIMB Bank
8602102342
HDRC ENTERPRISE
Receipt must be whatapp to Nik Ehzan -0122098174
PRIZES
Trophy for all.
Registration will be closed by 21st July 2019.
PIC CONTACT Any info regarding to rule and any unclear information please contact PIC below.
Nik -0122098174
Azam -0102743489
shukrihashim is offline
Old 06-12-2019, 11:36 PM
Default Additional info
Controlled Tires MNC 2019
1/10 Touring (Mod, Superstock, GT)
Brand and Type:
-Brand RUSH 40X
Price:
RM95
Racer can buy the tyre from MASPRO and other LHS
Mchasis
Brand and Type:
-DS Racing (36R,34R)
RM95
Racer can buy the tyre from RCPlanet and other LHS
Truck
-Standard Tamiya Truck tyre
-RIM open brand
F1
-Open brand F1 tyre
-Racer can get from SamMaspro, RC Planet and other LHS.
For MNC2019, organizer will not include tyre into the race Fees. Racer need to get the controlled tyre from Local Hobby Shop.
BittyDesign which MNC2019 main sponsor giving special price for the BittyDesign bodyshell below,
1. Gt Bodyshell (Venom) retail RM120
For MNC registered racer only *RM110 !!!*
2. Gt Bodyshell (AGATA) retail RM***(TBU)
For MNC registered racer only *RM***(TBU) !!!*
3. IRON Truck retail rm160
For MNC registered racer only *RM150 !!!*
4. Bitty touring bodyshell retail RM100
For MNC registered racer only *RM90 !!!*
5. F1 bodyshell retail RM140
For MNC registered racer only *RM130 !!!*
Racer can buy the bodyshell at RC Pitstop at One Utama.
Old 06-12-2019, 11:37 PM
Default Registration
Name/PT#//Car/Motor/ESC/Battery/State
1.
2.
3.
4.
5.
Touring Car - Super Stock
1.
2.
3.
4.
5.
Touring Car - Bitty GT
1.
2.
3.
4.
5.
Mchasis - Stock
1.
2.
3.
4.
5.
Truck Racing - Stock
1.
2.
3.
4.
5.
F1
1.
2.
3.
4.
5.
Old 06-13-2019, 12:17 AM
1.
2.
3.
4.
5.
1.
2.
3.
4.
5.
1.rojak/ptsewa/Xray T4/Orca/Orca/Orca/KL
2.
3.
4.
5.
Mchasis - Stock
1.
2.
3.
4.
5.
1.
2.
3.
4.
5.
F1
1.
2.
3.
4.
5
rojak86 is offline
Old 06-13-2019, 01:00 AM
zairi's Avatar
1.
2.
3.
4.
5.
1. Zairi / PTXXXXXX / Xray T4'19 / Maclan / Maclan / Maclan / Kedah
2.
3.
4.
5.
1. rojak/ptsewa/Xray T4/Orca/Orca/Orca/KL
2. Khalid /ptsewa / Xray T4'19 / Team Orion / Team Orion / Maclan / KL
3.
4.
5.
Mchasis - Stock
1. Nman / PT sewa / Gambado / SP / TBA / Maclan / KL
2.
3.
4.
5.
1.
2.
3.
4.
5.
F1
1. Nman / PT sewa / Xray X1'19 / HW / TP / Maclan
2. Zairi / PT Sewa / Xray X1'17 / HW / HW / Maclan
3.
4.
5
zairi is offline
Old 06-13-2019, 01:14 AM
1.
2.
3.
4.
5.
2.billo/ ptxxxxx/ aweso / solo
3.
4.
5.
3.
4.
5.
Mchasis - Stock
2.
3.
4.
5.
1.
2.
3.
4.
5.
F1
3.
4.
5[/QUOTE]
Futaba4px is offline
Old 06-14-2019, 07:54 AM
zephuros's Avatar
1.
2.
3.
4.
5.
3.
4.
5.
3. Dino / 4634214 / ZEROTRIBE T4 / Orca / Orca / Orca / ZEROTRIBE
4.
5.
Mchasis - Stock
2.
3.
4.
5.
1.
2.
3.
4.
5.
F1
3.
4.
5
zephuros is offline
Old 06-14-2019, 06:32 PM
niezam's Avatar
1.
2.
3.
4.
5.
3.Arman Ahmad / Ptxxx / Xray t4 19 / Maclan / Maclan / Maclan / Epjb
4.
5.
4. Niezam jb / PtRent / serpent Evo / Orion / Orion/ Orion / Epjb
5.
Mchasis - Stock
2.
3.
4.
5.
1. Anuar jb / Ptxxx/ Tamiya / Muchmore / Muchmore / Muchmore / Epjb
2.
3.
4.
5.
F1
3.
4.
5
niezam is offline
Old 06-16-2019, 08:15 AM
1.
2.
3.
4.
5.
4.
5.
5. Abg Chon / PT 9645387 / Xpress / PPRCC / Penang
Mchasis - Stock
2.
3.
4.
5.
2.
3.
4.
5.
F1
3.
4.
5
fishol is offline
Old 06-17-2019, 07:19 AM
zephuros's Avatar
1.
2.
3.
4.
5.
4.
5.
3. Withdrawn
Mchasis - Stock
2.
3.
4.
5.
2.
3.
4.
5.
F1
3.
4.
5
zephuros is offline
Old 06-18-2019, 10:05 AM
1. Michael Lo / 2222228 / Awesomatix MMCX / ORCA / ORCA / ORCA / Team Awesomatix ORCA
2. Wong Kokwai / PT**** / Awesomatix MMCX / ORCA / ORCA / ORCA / Team Awesomatix ORCA
3.
4.
5.
2. billo/ ptxxxxx/ aweso / solo
3. Arman Ahmad / Ptxxx / Xray t4 19 / Maclan / Maclan / Maclan / Epjb
4. Michael Lo / 2222228 / Awesomatix MMCX / ORCA / ORCA / ORCA / Team Awesomatix ORCA
5. Wong KokWai / PT**** / Awesomatix MMCX / ORCA / ORCA / ORCA / Team Awesomatix ORCA
3. Withdrawn
Mchasis - Stock
2.
3.
4.
5.
2. Michael Lo / 2222228 / TT01E / ORCA / ORCA / ORCA / Team ORCA
3.
4.
5.
F1
3.
4.
5
mikecan8 is offline
Old 06-18-2019, 08:16 PM
3.
4.
5.
3. Bahar / PTxxxx / XQ1S / TP / SP / Gen Ace / Selangor
Mchasis - Stock
2. Bahar / PTxxxx / ABC / TP / SP / Gen Ace / Selangor
3.
4.
5.
3.
4.
5.
F1
3.
4.
5.
Old 06-18-2019, 11:20 PM
3. Nik Ejan / PTxxxxxx / SPT 4x / SP / HW / ORCA / K.L
4. Azam Nordin / PT9417745 / TRF419X / SP / SP / MaxPower / K.L
5.
6.
7.
8.
Mchasis - Stock
3.
4.
5.
3.
4.
5.
F1
3.
4.
5.
azamnordin is offline
Old 06-27-2019, 04:16 AM
5.
6.
7.
8.
5.
Mchasis - Stock
3.
4.
5.
3.
4.
5.
F1
3.
4.
5.
fishol is offline
Old 06-29-2019, 03:33 AM
5.
6.
7.
8.
5.
Mchasis - Stock
3.
4.
5.
3. Sin Chan / 2586951 / TT01E / Maclan x3
4.
5.
F1
3. Sin Chan / 3950836 / Xray / Maclan x3
4.
5.
cheapskate.brok is offline
