Go Back  R/C Tech Forums > International Forums > Malaysian R/C Racers
TT EP FUN RACE 12 Aug 2018 @ Titiwangsa >
Old 07-09-2018, 01:47 AM
Default TT EP FUN RACE 12 Aug 2018 @ Titiwangsa
TT FUN RACE EP 2018
THE RACE FOR EVERYONE
TT FUN RACE:
Track Venue - Titiwangsa, Kuala Lumpur
Date - 12 August 2018
Time - Sunday (9:00am)
RACE CATEGORIES:
1. GRAN TOURISMO (GT) CLASS (17.5 non-boosted)
2. FRONT WHEEL DRIVE (FWD) (17.5 non-boosted)
3. Mchasis - Stock (17.5T non-boosted)
4. Tamiya Racing Truck (17.5t non-boosted)
RACE FORMAT:
- 3 Heats
- 3 Finals for A-Mains, 2 Finals for B Main and 1 Final for all other Mains
Grid position for Finals will be based on best 1 out of 3 Heats.
RULES AND REGULATIONS:
Motor
- 17.5 turn (Open Brand but must be approved by Roar)
- Motor timing - KV2600 or amp 2.0
Any attempt to modify or to influence the ability of the motor is not allowed (Ceramic bearing and rotor modification is NOT ALLOWED).
ESC
- Open brand but must be in blinky mode
Any attempt to modify or to influence the ability of the E.S.C is not allowed (Inclusive of adding additional capacitors and other E.S.C influencing device.) Only battery plugs can be changed.
Chassis
- Any 4wd 190mm chassis
- Chassis must have independent suspension to all four wheels. Each driven wheel must have a flexible joint (e.g. dogbone/s) in its driveshaft.
- No part of the chassis, including wheels/tires/axles/motor/battery or electronic equipment may protrude outside the body shell when viewed from above.
- Option parts that made for that model can be used.
- Open to all TC chassis
Body shell
- Only GT/DTM/WTCC/Some Drift (If looks like GT) style Body Shells allowed. Strictly no Touring bodyshells.
- Must be painted, front and rear lights may be painted or decals.
- All windows must be clear or paint clearly contrasted from the surrounding paintwork.**
- Optional wing which meant for body shell is allowed.
(Other Brands/Model On the discretion of Race Organizer)
Batteries
- Batteries: HV Lipos are allowed but voltage is restricted to 8.44 volt only and will be checked by officials prior to Heats/Finals. Please ensure lipos are marked prior to each Heats/Finals.
Weight
- 1400 grams minimum
Wheels & Tires
- Open brand
- Limited to ONE SET ONLY for the whole race duration.
Motor
ESC
Chassis
- Chassis must have independent suspension to all four wheels. Each driven wheel (Front) must have a flexible joint (e.g. dogbone/s) in its driveshaft.
- Two (2) wheel drives (front only) is allowed.
Body shell
- Recommended Bodyshells
TAMIYA 51339*Volkswagen Golf , 51473 Volkswagen Scirocco GT24-CNG, TAMIYA 50968*Beams Integra, 51339*Volkswagen Golf , 51473 Volkswagen Scirocco GT24-CNG, 51421*Honda Civic, 51431 Honda Civic Type R, 51452*Honda CR-Z, 84137*Volvo 850, 84138* Honda Accord 1996 , 84139*Peugeot 406 ST, 84140*Alfa Romeo 156, 84143*Tomís EXiV, *84144*Renault Clio, 84145*Tomís Levin
- Wing Only Original wing which came from Original body shell is allowed.
Batteries
Weight
- 1350 grams minimum
Wheels & Tires
- Open brand rim and tyre
Mchasis - Stock
Motor
ESC
Tires/Rims/Insert
- Open mini rubber tires.
Bodyshell
- Only realistic ABC, Tamiya, HPI, mini bodyshell are allowed.
- High Roof (Wing that comes with the bodyshell is allowed)
Drive Train & Transmission
- 6.4 (Max) Final Drive Ratio.
- M05/M03/M07 pinion 18,
- Gambado: 20T/30T pinion 28
- No speed gear modification allowed.
- Front Lock Diff Situation is NOT ALLOWED.
- Gear differential is allowed.
Chassis
- M03, M04, M05, M06, M07 and Gambado only are allowed.
- Conversion to Evo or other carbon chassis is not allowed.
- Cars have to retain original wheel drive concept, no 4WD of twin motor configuration will be allowed.
Weight
- 1300gm (with transponder)
Tamiya Racing Truck
Motor
ESC
Chassis
- TAMIYA TT01 Truck Racing chasis (all factory standard from box)
- Option part
- Standard Bevel gear only allowed
- Diff lock is not allowed
- Diff oil, putty is not allowed.(diff kosong)
- Organizer will do diff checking
BodyShell
- Standard from Box (Tamiya Truck Racing Bodyshell)
- 4pcs bodyset must be applied. If any chance the truck head peel off, the truck must go to the pit stop to attach back the bodyshell.
- Additional hole for reduce weight or aerodynamic is not allowed
FDR
- ratio >= 7.21 (fast gears not allowed)
must used spur 61 and pinion 22 (hard coated pinion is allowed)
Tires
- Tamiya truck rubber tyre (Standard from box)
- Insert is not allowed
- Rim: Open brand
Batteries
- HV Lipos are allowed but voltage is restricted to 8.44 volt only and will be checked by officials prior to Heats/Finals. Please ensure lipos are marked prior to each Heats/Finals.
Min Weight: TBA(with transponder)
Motor KV will be checked by organizer officials prior to start of event. Please ensure that the motor is marked or you will be prohibited from racing or be disqualified.
RACING FEE:-
All Category -RM50
(Racing fee includes race fee, lunch & drinks).
*Tyre is not included. Please get from Local Hobby Shop
PRIZES
ē Trophy for all.
PIC CONTACT Ė Any info regarding to rule and any unclear information please contact PIC below.
Joe Aziz -0169200984
Boy -012370076
shukrihashim is offline
Old 07-09-2018, 01:48 AM
Additional info
Old 07-09-2018, 01:51 AM
Default Registration
1.
2.
3.
4.
5.
1.
2.
3.
4.
5.
1.
2.
3.
4.
5.
1.
2.
3.
4.
5.
Old 07-09-2018, 03:59 AM
(Name / Kit / PT no. / Team / State)
1. Azlan / T4 18 / PTxxxxx / Jimbitters / Kajang
2.
3.
4.
5.
1.
2.
3.
4.
5.
1.
2.
3.
4.
5.
1. Amirul / TT01 / PTxxxxx / BBRCC / KL
2. Daniel / TT01 / PTxxxxx / BBRCC / KL
3.
4.
5.
Old 07-10-2018, 04:21 AM
2. Khalid / TRF419XR / PTsewa / Tamiya Malaysia / Selangor
3. Zairi / T4 18 / PTxxxx / Team XRAY Malaysia / Selangor
4. Twochu /A800X / PTxxxx / Neka RAcing Team / Selangor
5. Shukri / TT02 evo / PTxxxx / Neka Racing Team / Selangor
6. Boy / Durango / Ptxxxx / Songkok / Selangor
7. Zamree / BD7 / PTxxxx / Team Sembang / Selangor
8.
9.
10.
1. Joe Aziz / MTS V3 / PTxxxxx / Songkok UK / KL
2. Wafie / S411 / PTxxxxx / Songkok Gombak / KL
3. Ropi / MTS V3 / PTxxxxx / Songkok Penchala / KL
4. Wak Rose / FF03 zombie / PTxxxx / Songkok UG / KL
5. Zairul / S411 / PTxxxx / Songkok Keramat / KL
6.
7.
1. Fariso / M07 / PTxxxx / Tamiya Malaysia / KL
2. Wak Rose / M07 / PTxxxx / Songkok UG / KL
3. Roselan / ABC / PTxxxx / Neka Racing Team / KL
4. Sham Sakura / ABC / PTxxxx / Neka Racing Team / KL
5. Baha lewandoski / M05 / PTsewa / Team Banting / Selangor
6. Arin lukaku / M03 / PTSewa / Team Banting / Selangor
7. Zairul / M07 / PTxxxx / Songkok keramat / KL
8. Tapero / m07 / PTxxxx / / KL
9. Zaidi TPJ / ABC / PTxxxx / SOngkok PJ / Selangor
10.
3. Ayie / TT01E / PTxxxx / GTM / KL
4. Joe Aziz / TT01E / PTxxxx / Songkok UK / KL
5. Wak Rose / TT01E / PTxxxx / Songkok UG / KL
6. Wafie / TT01E / PTxxxx / Songkok Gombak / KL
7. Ayen / TT01E / PTxxxx / Team Sembang / Selangor
8. Epin / TT01E / PTxxxx / Songkok Awana / KL
9. ilyas / TT01E / PTxxxx / Team Lori Buah KR / KL
10. Aziz Sham / TT01E / PTsewa / Team MTRT / KL
11.
12.
Old 07-10-2018, 06:14 AM
ThunderSaw's Avatar
8.
9.
10.
6. Adwin Wong / MTS V3 / PTxxxxx / Team BLS / KL
7. Kenny Sham / MTS V3 / PTxxxxx / Team BLS / KL
8. Bean Lee / Grande Gambado / PTxxxxx / Team BLS / KL
9. Tony Wong / MTS V3 / PTxxxxx / Team BLS / KL
10. Alex Saw / MTS V3 / PTxxxxx / Team Chicken / KL
11. Alex Tan / MTS V3 / PTxxxxx / Team Iron Man / KL
10.
11.
12.
ThunderSaw is offline
Old 07-10-2018, 09:45 AM
niezam's Avatar
8. Niezam jb / BD8 / PTxxxx / Epjb / johor bahru
9.
10.
10.
11. Kenit jb / TT01E / PTsewa / EPJB / Johor bahru
12.
niezam is offline
Old 07-10-2018, 07:09 PM
9. Wazir HKL / Xray / PTxxxx / Neka Racing Team / KL
10. Nik Rojak / Xray / PTxxxx / / KL
6. Arin / M03 / PTSewa / Team Banting / Selangor
10. Samsudin / M07 / PTsewa / Tamiya Malaysia / KL
11. Sofian / M07 / PTxxxx / Malaysia Hobbies / KL
12. Faiz / M07 / PTxxxx / Malaysia Hobbies / KL
13.
14.
1. Amirul / TT01 / PTxxxxx / KLRC / KL
2. Daniel / TT01 / PTxxxxx / KLRC / KL
12. Nasa / TT01E / PTxxxx / BBRC / KL
13.
14.
Old 07-10-2018, 08:07 PM
ammaramira's Avatar
12. Norazam / FF03 / PT xxxxxx / Team RCAC / KL
13.
14.
13.
14
ammaramira is offline
Old 07-10-2018, 10:06 PM
azlie kr's Avatar
11. Azlie Kr / Xray / pt no 2622974 / Kotaraja Klang
12.
13
14.
15.
13.
14.
15.
13.
14.
15.
13.
14 .
15.
azlie kr is offline
Old 07-10-2018, 11:18 PM
beanlee's Avatar
12.
13
14.
15.
6. Adwin Wong / MTS FF V3 / PTxxxxx / Team BLS / KL
7. Kenny Sham / MTS FF V3 / PTxxxxx / Team BLS / KL
9. Tony Wong / MTS FF V3 / PTxxxxx / Team BLS / KL
10. Alex Saw / MTS FF V3 / PTxxxxx / Team Tiong Nam/ KL
11. Alex Tan / MTS FF V3 / PTxxxxx / Team Iron Man / KL
13. Harry / MTS FF V3/ PT xxxxxx / Team Cendol / KLANG
14.
15.
13.
14.
15.
13.
14 .
15.
beanlee is offline
Old 07-10-2018, 11:39 PM
12. Leykapan / T4 18 / PT4040914 / GG KR RC / Selangor
13. Shah KR / BD7 / PTxxxxx / GG KR RC / Selangor
14.
15.
14.
15.
13.
14.
15.
13. Shah KR / TT01E / PTxxxxx / GG KR RC / Selangor
14 .
15.
Old 07-12-2018, 08:46 AM
14.Adik Haikal/XQ1/PTxxxxx/Expres
15.
14.
15.
13.
14.
15.
14 .
15.
waktc is offline
Old 07-16-2018, 01:06 AM
Dear all,
We changed the location from Titiwangsa to Kota Raja.
Please ignore this thread and refer to the new thread
EP Fun Race 12 Aug 2018 @ Kota Raja.
All registered user have been updated to the new post.
Sorry for any inconvenience cause.
