Go Back  R/C Tech Forums > International Forums > Malaysian R/C Racers
MNC EP Touring 2018 - Rd 1 @ Titiwangsa >
Old 01-15-2018, 06:56 PM
Default MNC EP Touring 2018 - Rd 1 @ Titiwangsa
Dear racers...
MNC 2018 will continue with fair and less cost for racer.
However, the ESC and Motor brand for Blinky touring, mchasis and Truck (motor)
still under discussion by organizer and because of limited time that we give to LHS, we
want to give more time for them to finalize the price.
For round 1, ESC and Motor brand for above category will be open as per below posting.
We expect racer for blinky category(Touring, Mchasis & Truck) will be using existing
motor and esc for round 1 which will minimize the cost effort.
An official announcement on the ESC and Motor will be posted soonest(For round 2).
Please look out for it.
For Control Tyre, we are still in the midst of testing and decision will update soon.
We wish to apologise for any inconvenienced caused by this delayed.
Regards.
shukrihashim is offline
Old 01-15-2018, 06:57 PM
Default MNC 2018 rd1
Malaysian National Championship (MNC) EP 2018
A FEMCA & IFMAR-sanctioned series via RC Malaysia
MNC 2018 Round 1:
Track Venue - Titiwangsa, Kuala Lumpur
Date - 11 Febuary 2018
Time - Sunday (9:00am)
RACE CATEGORIES:
1. Touring Car - Modified
2. Touring Car - SuperStock (13.5t boosted)
3. Touring Car - Stock (13.5T non-boosted) -only for rd1
4. Mchasis - Stock (17.5t non-boosted)
5. Tamiya Truck- 17.5t
RACE FORMAT:
- 3 Heats
- 3 Finals for A-Mains, 2 Finals for B Main and 1 Final for all other Mains
Grid position for Finals will be based on best 1 out of 3 Heats.
Race result will be based on IFMAR rules.
MNC CHAMPIONSHIP POINTS:
Top 20 drivers (A Main dan B Main) qualify for championship points in the following order (22,20,18,17,16,15,14,13,12,11,10,9,8,7,6,5,4,3,2, 1).
TQ will earn an additional 1 bonus point.
RULES AND REGULATIONS:
Motor - 10.5 turn and below (open to all brands - must be ROAR/IFMAR/EFRA/JMRCA/BCRA approved)
Motor timing - no restriction
Esc - Open
Tires/Rims/Insert - Controlled Tires (RUSH 36X). 2 sets only
Bodyshell - IFMAR rules apply
Min Weight: 1350gm (with transponder)
Motor - 13.5 turn (open to all brands - must be ROAR/IFMAR/EFRA/JMRCA/BCRA approved)
Motor timing - no restriction but max 3000kv and 2.0amp draw
Esc - Open (timing and turbo functions ALLOWED)
Tires/Rims/Inserts - Controlled Tires (RUSH 36X). 2 sets only
Drivers - Regular racer and pro
Touring Car - Stock
Motor: 13.5t turn (open to all brands - must be ROAR/IFMAR/EFRA/JMRCA/BCRA approved) -only for rd1
Motor timing - no restriction but Max 3000kv and 2.0ampdraw -only for rd1
ESC: Open to all brands but must be blinky -only for rd1
Bodyshell - compliance with IFMAR rules encouraged
Batteries: HV Lipos are allowed but voltage is restricted to 8.44 volt only and will be checked by Officials prior to Heats/Finals. Please ensure lipos are marked prior to each Heats/Finals.
Drivers - First time racers, newbies and beginners
Mchasis - Stock
Motor: 17.5 turn (open to all brands - must be ROAR/IFMAR/EFRA/JMRCA/BCRA approved) -only for rd1
Motor timing - no restriction but Max 2600kv and 2.0ampdraw
Any attempt to modify or to influence the ability of the motor is not allowed (Ceramic bearing and rotor modification is NOT ALLOWED).
Any attempt to modify or to influence the ability of the E.S.C is not allowed (Inclusive of adding additional capacitors and other E.S.C influencing device.) Only battery plugs can be changed.
Tires/Rims/Insert: - DS Racing (36R,34R) only
Bodyshell: Only realistic ABC, Tamiya, HPI, Blitz, SPICE mini bodyshell are allowed.
High Roof (Wing that comes with the bodyshell is allowed)
Drive Train & Transmission: 6.4 (Max) Final Drive Ratio.
M05/M03/M07 inion 18, Gambado: 20T/30T pinion 28
No speed gear modification allowed.
Front Lock Diff Situation is NOT ALLOWED.
Gear differential is allowed.
Chassis: M03, M04, M05, M06, M07 and Gambado only are allowed.
Conversion to Evo or other carbon chassis is not allowed.
Cars have to retain original wheel drive concept, no 4WD of twin motor configuration will be allowed.
Min Weight: 1200gm (with transponder)
Batteries: HV Lipos are allowed but voltage is restricted to 8.44 volt only and will be checked by officials prior to Heats/Finals. Please ensure lipos are marked prior to each Heats/Finals.
Drivers - First time racers, newbies, beginners and regular racer
Tamiya Racing Truck
Chassis: TAMIYA TT01 Truck Racing chasis (all factory standard from box)
- option part is allowed
Diff & Bevel gear
-Standard Bevel gear only allowed
-Diff lock is not allowed
-Diff oil, putty is allowed, but diff must not lock
-Organizer will do diff checking
BodyShell: Standard from Box (Tamiya Truck Racing Bodyshell)
-4pcs bodyset must be applied. If any chance the truck head peel off, the truck must
go to the pit stop to attach back the bodyshell.
-Additional hole for reduce weight or aerodynamic is not allowed
FDR: >= 8.35 (standard gears from box, fast gears not allowed)
must used spur 61 and pinion 19 from Box (hard coated pinion is allowed)
ESC: Tamiya TBLE-02S ESC (STandard from box)
Tires: Tamiya truck rubber tyre and rim (Standard from box)
-Insert is not allowed
Motor KV (Stock class, Mchasis and Truck) will be checked by organizer officials prior to start of event. Please ensure that the motor is marked or you will be prohibited from racing or be disqualified.
RACING FEE:-
Touring Category -RM70
Mchasis/Truck -RM60
2 category will be discount RM10
(Racing fee includes race fee, lunch & drinks).
*Control tyre is not included. Please get from Local Hobby Shop
PRIZES
• Trophy for Amain and Top 3 for other main. Other drivers will be given a token of appreciation.
PIC CONTACT – Any info regarding to rule and any unclear information please contact PIC below.
Nik -0122098174
Azam -0102743489
Old 01-15-2018, 06:58 PM
Controlled Tires MNC 2018
1/10 Touring (Mod, Superstock, Blinky)
Brand and Type:
-Brand RUSH 36X
-RU0418
Price:
RM95 included GST
Racer can buy the tyre from MASPRO and other LHS
Mchasis
Brand and Type:
-DS Racing (36R,34R)
Racer can buy the tyre from RCPlanet and other LHS
Truck
-Standard Tamiya Truck tyre
For MNC2018, organizer will not include tyre into the race Fees. Racer need to get the controlled tyre from Local Hobby Shop.
Any inquiries, please do contact PIC above.
Old 01-15-2018, 06:59 PM
Default Registration
Name/Car/PT#/Club/State
1.
2.
3.
4.
5.
Touring Car - Super Stock
1.
2.
3.
4.
5.
Touring Car - Stock
1.
2.
3.
4.
5.
Mchasis - Stock
1.
2.
3.
4.
5.
Truck Racing - Stock
1.
2.
3.
4.
5.
Old 01-16-2018, 02:49 AM
shahrin's Avatar
1. Shahrin / xxx / PT7263323 / Kuala Lumpur
2.
3.
4.
5.
1.
2.
3.
4.
5.
Touring Car - Stock
1.
2.
3.
4.
5.
Mchasis - Stock
1.
2.
3.
4.
5.
1.
2.
3.
4.
5.
shahrin is offline
Old 01-18-2018, 01:53 AM
Asoi's Avatar
Touring Car - Modified[/B]
2.
3.
4.
5.
1.
2.
3.
4.
5.
Touring Car - Stock
1.Muza/4X/PTxxxx/PPRCC
2.Asoi/Xray/PTxxxx/PPRCC
3.
4.
5.
Mchasis - Stock
1.
2.
3.
4.
5.
1.Lah/TT01E/PTxxxx/PPRCC
2.MCD/TT01E/PTxxxx/PPRCC
3.
4.
5.
Asoi is offline
Old 01-18-2018, 05:52 AM
2.
3.
4.
5.
1.
2.
3.
4.
5.
Touring Car - Stock
3. Zairi/Xray/PTxxxx
4. Khalid/TRF/PTsewa
5. Ijad/Xray/PTsewa
Mchasis - Stock
1.
2.
3.
4.
5.
3.
4.
5.
khalid_ms is offline
Old 01-22-2018, 12:29 AM
Default Controlled tyre updated
Dear all
For controlled tyre, please refer post 1 and 2
Old 01-22-2018, 06:48 PM
2.
3.
4.
5.
1.
2.
3.
4.
5.
Touring Car - Stock
5. Ijad/Xray/PTsewa
Mchasis - Stock
1. G-TA / M05 / PTSEWA / Ketapang RC / Beranang
2. G-TJ / M05 / PTSewa / Ketapang RC / Beranang
3. Shukri / M07 / PTxxxxx / Neka Racing Team / Selangor
4.
5.
3.
4.
5.
Old 01-22-2018, 07:49 PM
epin_78's Avatar
2.
3.
4.
5.
1. JOE/XRAY/PTxxxx/SONGKOK SENAPAS
2.
3.
4.
5.
Touring Car - Stock
1. Muza/4X/PTxxxx/PPRCC
2. Asoi/Xray/PTxxxx/PPRCC
5. Ijad/Xray/PTsewa
6. AYOP/ARC/PTxxxx/SONGKOK CEDOK
Mchasis - Stock
4. SHAMKALAI/ABC/PTxxxx/SONGKOK PUCHONG
5. SHAMSAKURA/ABC/PTxxxx/SONGKOK AMPANG
6. ZAIRUL/MO7/PTxxxx/SONGOK KERAMAT
7. HJ AKID/MO7/PTxxxx/WANGSA MELAWATI
8. AYIE/MO7/PTxxxx/TITIWANGSA
9. RAMBO/ABC/PTxxxx/SONGKOK KG JAWA
10. DIN/MO7/PTxxxx/ TITIWANGSA
1. Lah/TT01E/PTxxxx/PPRCC
2. MCD/TT01E/PTxxxx/PPRCC
3. EPIN/TT01E/PTxxxx/SONGKOK AWANA
4. JOE/TT01E/PTxxxx/SONGKOK SENAPAS
5. WAK/TT01E/PTxxxx/SELANGOR
epin_78 is offline
Old 01-22-2018, 08:37 PM
halim6's Avatar
2.
3.
4.
5.
2. Halim Hafni/Infinity IF14/8051965/Infinity Malaysia
3.
4.
5.
Touring Car - Stock
5. Ijad/Xray/PTsewa
Mchasis - Stock
11. Halim Hafni/M-07/PT ceruk usang tiga-lima
halim6 is offline
Old 01-22-2018, 09:08 PM
2.
3.
4.
5.
3.
4.
5.
Touring Car - Stock
5. Ijad/Xray/PTsewa
7. Zamree / BD716 / PTxxxx / Team Sembang / KL
9.
10.
11.
Mchasis - Stock
12.
13.
14.
6.
7.
8.
Old 01-23-2018, 01:33 AM
halim6's Avatar
2.
3.
4.
5.
3. Marcus Tan/XRay/5592990/XRay Malaysia
4. Ryan Tan/XRay/9159334/XRay Malaysia
5.
6.
7.
8.
9.
10.
Touring Car - Stock
5. Ijad/Xray/PTsewa
9.
10.
11.
12.
13.
14.
15.
Mchasis - Stock
12.
13.
14.
15.
6.
7.
8.
9.
10.
halim6 is offline
Old 01-23-2018, 09:32 PM
2.
3.
4.
5.
5.
6.
7.
8.
9.
10.
Touring Car - Stock
5. Ijad/Xray/PTsewa
9. WazirHKL / A700 / PTxxxxxxx / Team Sembang / KL
10.
11.
12.
13.
14.
15.
Mchasis - Stock
12.
13.
14.
15.
6.
7.
8.
9.
10.
azamnordin is offline
Old 01-24-2018, 12:10 AM
ammaramira's Avatar
2. Norazam / xxx / PT 7628137 / kuala lumpur
3.
4.
5.
5.
6.
7.
8.
9.
10.
Touring Car - Stock
5. Ijad/Xray/PTsewa
10.
11.
12.
13.
14.
15.
Mchasis - Stock
12.
13.
14.
15.
6.
7.
8.
9.
10.
ammaramira is offline
