[WTS] Sanwa M11X Transmitter with RX451 FHSS Receiver >
Old 04-21-2016, 09:00 PM
Thumbs up [WTS] Sanwa M11X Transmitter with RX451 FHSS Receiver
Address:
Penn-Mart Toys (M) Sdn Bhd
No 106 (Ground Floor, 1st Floor 2nd Floor), Jalan Raja Laut, 50350 Kuala Lumpur.
Tel: 603-26920725
Contact:
Kent +60124646778 Whatsapp/Wechat/SMS Only
Henry +60125521788 Whatsapp/Wechat/SMS Only
Website:
www.rcworld.com.my
!! Limited 6 Unit Only !!
SANWA M11X 2.4G Digital High Response System Transmitter only RM750.00 !!
Description:
  • This is the Sanwa M11X 2.4G Digital High Response System with RX451 FHSS Receiver
  • System Features:
  • 2.4GHz FHSS3 Transmitter and Receiver
  • New HighPower FHSS3 Technology
  • 2 or 4Channel Mode Selectable
  • 6 Cell Rechargeable NiMH Battery
  • Large Backlit LCD Display(White or Blue LCD Display Options), come with LCD Protection Cover
  • Left or Right Hand Grip
  • Digital Trim
  • KeyLock Switch
  • Display Switch
  • KeyLock Switch
  • Adjustable Handle
  • Adjustable Steering Wheel Tension
  • ThreePage Programming
  • Timer Vibration
  • Battery Monitor
  • AntiLock Braking
  • Adjustable Servo Speed
Feature:
  • Frequency Hopping Spread Spectrum 3 (F.H.S.S.3) highest security, speed, and reliability
  • Since M11X technically based on "SANWA M11" the world championship winner model, it features great pistol grip design, outstanding balance and best control ablility as well as M11.
  • Functional gun grip design for outstanding balance and best control
  • Large, highresolution, backlit LC display (white or blue)
  • LCD Protection Cover
  • Transmitter Can be Adjusted for Left or Right Handed Drivers
  • Grip Switch
  • Lap, Interval and Countdown Timers
  • 30 model memories
  • Model Select, Model Naming, Model Copy and Model Clear
  • Digital Dual Rate steering
  • ARC steering and throttle
  • Expo steering and throttle
  • Electronic AND mechanical End Point Adjustment
  • Adjustable throttle trigger Tension
  • Traction Control
  • Brake Mixing, AntiLock Braking
  • Two Compensation Mixers
  • Programmable Switches and Dial Knob
  • Custom Menu
Transmitter:
  • Model: M11X
  • Transmitting Frequency: 2.4GHz
  • Modulation: FHSS3
  • Output Power: 100MW
  • Power Supply: 7.2V 1500mAH
  • Weight: 785g (with Battery)
Reciever:
  • Model: RX451
  • Receiver Frequency: 2.4GHz
  • Modulation: FHSS3
  • Input Voltage: 4.8V 6.0V
  • Dimensions: 36.5 x 24.0 x 15.0mm
  • Fail Safe Limit: 3.8V Default / 3.5V 5.0V Adjustable
  • Weight: 9g
Included:
  • M11X 2.4G Digital High Response System (with LCD Protection Cover) (1pc)
  • RX451 Receiver(1pc)
  • Instruction (1pc)
leonluah is offline
