Futaba 3PJ-Super & Shock absorber
Old 10-14-2012, 04:21 PM
kimcstrike's Avatar
Default Futaba 3PJ-Super & Shock absorber
Hi All,
I nak letgo 2 items as per below
1) Futaba 3PJ-Super PCM 29Mhz FM (TX & RX)
- 1 x Transmitter + PCM module
- 1 x 3ch Receiver PCM module
- 1 x Original box + User Manual
- could convert to 2.4Ghz FASST system (compatible with futaba 3pk 2.4g module)
- age of item : 5 years +
- Item condition : used item & working fine (a little scratch at receiver's antenna wire)
2) G-Made XD Piggyback 75mm Shock Absorbers (1 pair)
- Titanium gray anodized aluminum shock body
- Red anodized aluminum aeration screw
- Silver anodized aluminum piggyback body
- Length (Mounting hole to hole): 75mm
- Shock Body Diameter: 14mm
- Spring Diameter: 19mm
- Spring Length: 40mm
- Full Shaft Travel Range: 17mm (without Rubber bump stop)
- Shaft Diameter: 3.5mm
- Adjustable pressure valve
- Item condition : Open box / pre-assembled
- Never been used (this is extra shocks that I have)
Price :-
1) Futaba 3PJ-Super : RM150
2) XD Piggyback Shock : RM100
Dealing method : only COD (Putrajaya/Bangi/Shah Alam/Klang Valley)
Contact : SMS/Whatsapp : kim (017-6846895)
Attached Thumbnails Futaba 3PJ-Super & Shock absorber-c360_2012-10-14-19-30-54_org.jpg   Futaba 3PJ-Super & Shock absorber-c360_2012-10-14-19-31-33_org.jpg   Futaba 3PJ-Super & Shock absorber-c360_2012-10-14-19-33-18_org.jpg   Futaba 3PJ-Super & Shock absorber-c360_2012-10-14-19-34-28_org.jpg   Futaba 3PJ-Super & Shock absorber-c360_2012-10-14-19-35-08_org.jpg
kimcstrike is offline
Old 10-20-2012, 05:12 AM
kimcstrike's Avatar
bump..
Old 11-05-2012, 01:07 AM
kimcstrike's Avatar
bump..
Old 11-06-2012, 11:41 PM
kimcstrike's Avatar
bump
Old 11-11-2012, 11:30 AM
kimcstrike's Avatar
BUMP..
Old 11-28-2012, 09:46 AM
kimcstrike's Avatar
BUMP
Old 12-04-2012, 04:14 AM
kimcstrike's Avatar
BUMP..
