(WTS)Extra Latest VISTA POWER 25A 350W charger for clear!
Details:
http://www.ev-peak.com/en/productview.asp?id=117
Specifications:
1 Input voltage range DC11.0~24.0V
2 Charge current range 0.1~25.0A
3 Discharge current range 0.1~20.0A
4 Discharge cut-off voltage 3.0V~4.0V
5 Charge power max.350W
6 Normal discharger power limited max.25W
7 Energy transfer discharge power limited max.200W
8 Balance tolerance ±0.01V
9 NiCd/NiMH battery cell count 1~18cells
10 Lithium battery types Li-Po, Li-Ion,Li-Fe
11 Lithium battery cell count 1-6cells
12 Pb battery voltage 2-20V
13 Digital Power 3~24V
14 Weight 610g
15 Dimensions 175 x 150 x 67 mm
brand new unit.
only rm320
COD/Taiping
Postage Rm12 only.
Call/PM
0175007932
WIliam TIong
Details:
Specifications:
14 Weight 610g
brand new unit.
only rm320
COD/Taiping
Postage Rm12 only.
Call/PM
0175007932
WIliam TIong
boss check PM...
AP625
This charger will not do as advertised.. Buy something else.IMHO this is junk
it took unit 2.5 hours to charge 2 nimh 2300 mah at .75 amp..from 2.35v to 2.53v
It took 95 minutes to charge a 4000 mah 2 cell lipo from 7.75v to 8.48 volts what 8.48 No its 8.400000..I also charged lipo at 5c thats 20 amps..This charger is a dud in my opinion.I have a $20 X charger that does a faster better job..
